Only the singleplayer portion is supposedly playable, with a “crack” available to bypass Origin and Battlelog (which is required on PC to play Battlefield 3). However, some are reporting virus and trojans bundled with the release as well.
Friend uses a Private Torrent Site, got some Info on this from him:
A. Its not yet been cracked. All they’ve done is found a way to bypass the Origin Date Check. SKIDROW posted some Serial Keys, but they were quickly used up. I’m curious to see how they’ll launch Campaign without Battlelog, since there’s no Game Menu on the PC Version.
B. BF3 Pirating will be low, because with Pirated Version all you get is Single-Player. Most people who are going after this game will buy it, because they’re after the Multi-Player Portion, not the Campaign.
Preko 8 miliona igrača probalo betu :sceptic:
Samo što njih dvojica ne priznaju javno da će uraditi preorder na drugom mestu, trolovanje za medalju :d
shvatili smo da necete da igrate bf3
pa sta sad, i onako je bf3 prosvetljenje u odnosu na tamu koju je cod doneo u vase zivote... sta vam smeta sto se nekom bf3 ne svidja i sto neko nije impresioniran?
Zato sto je opet 20 evra znas jeftinije nego 50! A DLC ce se uvek naci na akciji 😉 evo ti Vietnam za bc2 bio je 100x na nekoj akciji ja sam ga uzeo za 7 evra a moj brat za 3.............Interesantno je kako ste lako presli preko cinjenice da je " garantovano da ce biti LE verzija " pa je ispalo opet da je EA promenila politiku ? Bas ste neka tolerantna populacija ... Mislim jeste li sigurni da ce i back to karkand dlc biti samo 15 dolara po istom tom tvrdjenju ? I kakva ce vam biti reakcija kad ne bude ? 🙂
@ saint
Cancel-ovo sam preorder pa ocekujem od tebe da ne kupis igru 🙂
Nisi ti nista shvatio i dugo jos neces, najteze po tebe licno je sto ce ti spoznaja oko bitnih stvari u zivotu ostati u teskom sivilu. Biti povrsan govori dosta o coveku mozda ne toliko o karakteru koliko o odnosu prema konkretnoj stvari.
Iskoristio sam svoje pravo da kazem misljenje i da iznesem stav - Now, recognize it or gtfo :d
Kada jednom neko kaze da mu se ne svidja igra i da je ne planira uzeti - onda je ok.
Ali, ako neko ponavlja istu stvar 150X kao papagaj - onda je prosto dosadan.
