rAMA
Sad sam našao ovo:
http://physxinfo.com/news/3590/mafia-ii-physx-usage/
I meni isto Physx indikator pokazuje da se vrši na CPU, izgleda da baguje instalacija novih PhysX drivera koji dolaze uz demo.
Edit: Sad sam pokrenuo Batmana i on radi na 20 fps, mora da je do ovoga, , sad ću da probam reinstalaciju physx-a, pa javljam.
UPDATE: Strange. According to PhysX Visual Indicator, PhysX effects in Mafia II are running on CPU, even if GPU PhysX is enabled in drivers – with this newest 09.10.0512 System Software.
I wonder if that’s the reason of low fps. Can anyone confirms this ?
SOLUTION: you need to reinstall PhysX drivers.
Uninstall current one, than install PhysX_10.05.12_9.10.0512_SystemSoftware package manually,
