A kako ga nadjem otvorim, posto nisam radio u cmd nesto puno, kako idu tacno te komande?
mark_o
skino sam recovery4.2 i update.zip, ali kada ih extract javlja mi neku šifru da moram upisat da mogu nastavit dalje sa time, pa ako mi je nešto promaknulo bio bi ti zahvalan??
"Prebacivanje" radi i bez softvera.
mark_o
koju komandu da koristim u cmd da dođem do Android SDK tools za nam koji nisu bas na ti sa cmd ,pa da neko objasni kako to točno ide bilo bi lijepo, ako se naravno ima volje..![]()
mark_o
In Windows it's easy to add the Android SDK Tools directory to your system path. Doing this lets you use the Android SDK tools anywhere and makes it easier for you.
On Windows XP: Go to Control Panel->System, Choose the 'Advanced' tab and then click 'Environment Variables' To do this on Vista/Windows7: Simply go to Control Panel->System and choose 'Advanced System Settings' and then 'Environment Variables'
Now that you've got here locate Path under System Variables and click Edit, then add the following to the end of the string displayed:
;C:\AndroidSDK\tools\
Then click OK until you get out of the menus.
Now that you've done this you should be able to bring up a command shell and type 'adb' and it should run straight away without needing to change path.
