Profit switching/shifting pools diskusija (trademybit, wafflepool, clevermining...)
Meni se desavalo ranije na jednoj grafi kod koje je vent zaribao i brljavilo je ocitavanje obrtaja ventilatora.
Ja ovaj SGminer 5 nikako nem ogu da podesim. Uvek mi se ugasi. Kad otkucam pause, otane sgminer, al nema nista.
Nisu zaribali vent-ovi... nemam pojma šta je u pitanju.
Evo kod mene. Ćini mi se da je I 19 previoko, to ću probati da menjam.
EDIT: Asus 280x dc2t karte, klokovi 1050/1500, uv na 1.1
sgminer 4.2.1 - Started: [2014-06-14 14:41:27] - [0 days 00:47:33]
(5s):5.894M (avg):8.056Mh/s | A:1 R:0 HW:0 WU:0.109/m
ST: 0 SS: 2 NB: 152 LW: 2204 GF: 3 RF: 0
Connected to TMB_X13 (stratum) diff 0.005 as user aaaaa.2
Block: c63aefac... Diff:829 Started: [15:28:08] Best share: 1.085
[P]ool management [G]PU management ettings [D]isplay options [Q]uit
GPU 0: 46.0C 953RPM | 3.167M/2.684Mh/s | R: 0.0% HW:0 WU:0.038/m I:19
GPU 1: 53.0C 1012RPM | 3.172M/2.687Mh/s | R: 0.0% HW:0 WU:0.039/m I:19
GPU 2: 52.0C 923RPM | 3.163M/2.685Mh/s | R: 1.7% HW:0 WU:0.032/m I:19
[15:27:38] Accepted 12238e94 Diff 0.055/0.038 GPU 1 at TMB_X11
[15:27:47] Accepted 12cd66ce Diff 0.053/0.038 GPU 1 at TMB_X11
[15:27:59] Accepted 0df84fb7 Diff 0.072/0.038 GPU 0 at TMB_X11
[15:28:11] Accepted ebd98033 Diff 1.085/0.038 GPU 0 at TMB_X11
[15:28:21] Stratum connection to TMB_X13 interrupted
[15:28:23] Accepted 03d1afd2 Diff 0.262/0.038 GPU 1 at TMB_X11
[15:28:29] Accepted 12e06578 Diff 0.053/0.038 GPU 0 at TMB_X11
[15:28:53] Stratum connection to TMB_X11 interrupted
[15:28:57] TMB_X11 not responding!
[15:28:57] Switching to TMB_X11
[15:28:58] TMB_X11 not responding!
[15:28:58] Switching to TMB_X13
kako saltas izmedju x11 i x13 na 4.2.1 majneru? i kako vadis taj text iz sgminera? :p
Zasto ti je previsoko kada ti karta radi na 46C? Meni iste karte ko tvoje daju 3.4Mhs na onim klokovima.
Ipak ostaje I 19, na prethodnom mineru gde sam kopao x13 imao sam previsok R na I 19, ali je i worksize bio 256, ako to uopšte ima veze.
Stabilno radi na 1050/1500, na 1150/1500 mi puca drajver :(
@Roger_Waters kopiram tekst iz Command Prompt-a
Moze li neko da postavi bat file za sgminer V5 za x11 i x13 , i jel moguce uopste pokrenuti iz bat fajla.
Mislim da ne mozes sva podesavanja da stavis u bat fajl.
Odustao sam od tog X11 X13 kopanja jer po meracu struje to vise ne kopa nego sto kopa i karte su hladne ko spricer ... Pustam X13 pa emo videti kako ide ;)
Kod:
sgminer.exe -k x11mod -o stratum+tcp://eu.wafflepool.com:3331 -u x -p x --failover-only -o stratum+tcp://useast.wafflepool.com:3331 -u x -p x -I 18 --gpu-engine 1150 --gpu-memclock 1500 --thread-concurrency 8192 --lookup-gap 2 --gpu-powertune 20 --gpu-vddc 1.100 --gpu-threads 2
270x
X13=1.6
X11=2.1
Kacio je neko link o isplativosti vec..
Ja sam presao danas na wafflePool X11, tmb x13 je jako los zadnja 2 dana
Meni se konstantno doskonektuje sa TMB X11/X13 multi i prelazi na nicehash...
Juce je bas los dan na TMB X13 a i 11-og je isto bilo lose. Imate predlog za neki drugi pool?
Ja sam se prebacio na X11 na TMB jer je X13 slab ovih dana.
x11 daje dobre brojke danas kad god odem na home tab... videćemo isplatu
koliko je merodavno uopšte to što gledam?
x11 baca dobre brojke zato sto je 14.6 u 18h ubacen novi novcic FractalCoin (FRAC) a vredeo je 0.0032 sad je vec pao na 0.0018
Trademybit X13 je bas uporan da kopa Snakecoin, a bloka nema preko 4 sata.
Nesto tu nije u redu,ja sam ga kopao na dedicated-u za probu skoro sat vremena,i nista. A diff neka smejurija....
Da je cena izrazena u gramima zlata,pa da se cima covek. Ovako.... :d
TMB je ocaj zadnjih dana.Zadnja 4 dana daje oko 0,00236 po 1MH/s scrypt sto je skoro pola od uobicajenog.
Wafflepool skroz fino isplaćuje ovih dana pa probajte...
koliko tacno fino? :) x11 jel?
