Mare
The primary features of the GeForce FX 5600 Ultra are as follows:
TSMC's 0.13 Micron Process
80 Million Transistors
350MHz Graphics Processing Unit
700MHz (Effective) DDR Memory
128-Bit Memory Bus
11.2GB/sec Physical Memory Bandwidth
CineFX Architecture
Intellisample Technology
128-Bit Floating Point Precision
4x1 Pipeline Architecture
Lossless Color And Z Compression
Z Occlusion Culling
AGP 8X Interface
Integrated TV-Encoder, TMDS Transmitters
Dual Integrated 400MHz Ramdacs
Integrated Full Hardware MPEG-2 Decoder
According to NVIDIA, the GeForce FX 5600 Ultra is targeted to replace the popular GeForce4 Ti 4200, yet contains a processor and memory clock speed that exceeds that of the GeForce4 Ti 4600 (300MHz/650MHz). The GeForce FX 5600 Ultra will compete against ATI's Radeon 9500 (non pro model), but ATI's positioning in the performance segment may grow stronger with new products based on their R350 graphics chipset.
The GeForce FX 5200 Ultra (45 million transistors, 325MHz/650MHz effective DDR, 10.4GB/sec memory bandwidth) and GeForce FX 5200 (250MHz/400MHz effective DDR) are manufactured at 0.15-micron and contain support for DirectX 9 including vertex and pixel shader 2.0+. The GeForce 5200 Ultra and GeForce 5200 contain all the memory bandwidth maximizing features of Intellisample technology except hardware assisted color and z compression.
Here are some specs from 3DGPU on the newest members to the FX family:
GeForce FX 5600 Ultra:
Full GeForce FX feature support – including DX9 vertex & pixel shader 2. 0+
High precision rendering – up to128-bit floating point color
Performance 2x GeForce4 Ti Performance with AA
4 pipelines
Lossless Color & Z Compression
Z Occlusion Culling
3rd Generation nView Integrated TV- encoder, TMDS transmitters
Dual integrated 400 MHz Ramdacs
Integrated full hardware MPEG- 2 decoder
AGP8x
GeForce FX 5200 Ultra:
Full GeForce FX feature support – including DX9 vertex & pixel shader 2.0+
2X GeForce4 MX performance
DX9 optimizations and support
AGP 8X enables up to 2. 1GB/ sec bandwidth
Dual integrated 350 MHz RAMDACs
HDTV Support
Nije lose bar na papiru...
type;
:boom:
