Evo ga review za i3-10100 https://www.youtube.com/watch?v=AAPq9Lthhnc
To je zapravo, review nekog drugog procesora. :d
+1 Znaju oni polozaj na trzistu mnogo bolje od nas i znaju da ce ljudi kupovati intel jos uvek zbog brenda koji je izgradio , sad koliko ce jos dugo moci da se oslone na to ....Zasto su se zeznuli? pa tako se prave pare
Otkud tolika razlika uzmeđu 2666 i 3200 MHz? Znači sad se i za Intel mora kupovati skuplji RAM da bi se u potpunosti iskoristio potencijal :dEvo ga review za i3-10100 https://www.youtube.com/watch?v=AAPq9Lthhnc
Dok će Asrock nuditi BFB od 125 W, MSI će izgleda ponudiiti 255 W: (za takozvane 65 W procesore)
Der8auer took 30 different 10900K processors, from exactly the same manufacturing batch, and tested them all with the exact same system, same settings, and same ambient room temperature too. He found that with the chips all running at 5.1GHz and at 1.25V six of them recorded a peak temperature below 80°C, 12 came in above the average temp of 82°C, while one extreme outlier hit 92°C.
He also tested the peak package power draw too, and measured the lowest at 232W while the highest hit 278W.
Ne, nego tice se OSD-a, dok sam bio na 2600K bila je opcija CPU clock tako da sam mogao pratiti frekvenciju procesora u realnom vremenu tokom igranja. Znaci kada otvorim MSI afterburner, settings > monitoring > graph, sve ostalo ima kao CPU usage i CPU temperature ali od kako sam na 10900K CPU clock ne postoji kao dio on screen display-a. Probao sam reinstalaciju MSI afterburner-a i razlicite verzije ali bez rezultata.
