LIKE!!!U novu betu poco launchera su ubacili i "double tap to sleep" opciju...kao kod lg-a
Послато са POCOPHONE F1 уз помоћ Тапатока
Sent from my POCOPHONE F1 using Tapatalk
Skoro 50k to jest tačno 52k. Lol, no thanks.Pojavila se u Gigatronu ali je skoro 50K.
A sad sam pokusao i preko miflash tool... (slika ispod).
Sta sad da radim, posto na sajtu nemam pojma sta hoce, jer je na kineskom ili da cekam 72h, pa da opet probam preko mi flash tool-a?
Ovo mi je prvi xiaomi fon pa se ne snalazim najbolje sa ovim otkljucavanjem...![]()
Sent from my SM-N930F using Tapatalk
Here is the whole story of tuch issues and screen bleeding :-
1) first batch - Xiaomi was using screen from some supplier and it had screen bleeding. (users facing screen bleeding but no touch issues)
2) Second Batch - Later xiaomi changed the whole panel and this time they fixed the screen bleeding but got the touch issues. (users facing touch issues but no screen bleeding like me)
3) Third and latest batch - Later again xiaomi changed the touch panel and this time they got all issues fixed. (third batch users facing no issues, neither screen bleeding nor touch issues, mostly from outside of India pocophone f1 users and poco f1 users in India having october or later manufactured units)
4) Now xiaomi is trying to fix the touch issue for second batch users by changing kernel values because screen bleeding can't be fixed by software updates.
5) if xiaomi fixes the issues for second batch people by increasing the current supply for touch planel to reduce touch delays by tweaking kernel then first batch people starts having issues like ghost touches because of over sensitivity due to over current values.
6) if xiaomi tries to fix the issues for the first batch people by reducing the current for touch panel again by tweaking kernel values then second batch people starts having issues like touch delay and lake of touch sensitivity because of reduced current values.
7) Meanwhile the third batch people has average values so they don't get affected by any of the above kernel changes so they don't have any kind of touch issues in any of the build.
8) Because there are three different touch panels being used in poco f1 and each one is using different current values its very difficult to control all of them from the same kernel values or by any universal Rom.
9) Xiaomi can provide the device specific build like different-different kernel values for different touch panel devices.
:svetius: Disclaimer - Above are my personal observations, nothing is confirmed by xiaomi officials and i may be wrong so don't take it seriously :svetius:
Kako se pokazao proximity senzor? Ja sam imao problema na rn3 i rn5 sa tim. Ne vidim po netu da se zali neko.
+1izasla nova open beta 8.12.27
Ja nisam primetio...mada neko je rekao na XDA da su se toga dana pojavile dve beta verzije 27.12 mozda sam ja ubo pravu.[emoji4]mizlim da se na poslednjoj beti ponovo vratio touch delay.
Aj da pitam i ovde posto me na drugoj temi ignorisu - ko ima bolju kameru, F1 ili A7?
Pazario ga i ja danas, za 290e sa dve godine garancije, vakum. Nema bolje kupovine za ovaj novac. Jedina mi je zamerka sto mi je nekako ruznjikav i sto ekran izgleda kao da ima zastitno staklo preko. Radi li na 9.0 gcam?
Posti mi je ovo prvi android zamolio bih forumase za pomoc! MIUI mi je uzas pa sam otkljucao bootloader, kako je navedeno.
Sta sada treba da uradim ivda li moze da se instalira mozda stock android kao na pixel-u? Unapred hvala
