Da li ce ovde biti povecanje brzine?
ping 92.60.224.14 -t
Pinging 92.60.224.14 with 32 bytes of data:
Reply from 92.60.224.14: bytes=32 time=1ms TTL=63
Reply from 92.60.224.14: bytes=32 time=32ms TTL=63
Reply from 92.60.224.14: bytes=32 time=84ms TTL=63
Reply from 92.60.224.14: bytes=32 time=159ms TTL=63
Reply from 92.60.224.14: bytes=32 time=107ms TTL=63
Reply from 92.60.224.14: bytes=32 time=138ms TTL=63
Reply from 92.60.224.14: bytes=32 time=187ms TTL=63
Reply from 92.60.224.14: bytes=32 time=200ms TTL=63
Reply from 92.60.224.14: bytes=32 time=199ms TTL=63
Reply from 92.60.224.14: bytes=32 time=198ms TTL=63
Reply from 92.60.224.14: bytes=32 time=194ms TTL=63
Reply from 92.60.224.14: bytes=32 time=205ms TTL=63
Reply from 92.60.224.14: bytes=32 time=2ms TTL=63
Reply from 92.60.224.14: bytes=32 time=51ms TTL=63
Reply from 92.60.224.14: bytes=32 time=380ms TTL=63
Reply from 92.60.224.14: bytes=32 time=296ms TTL=63
Reply from 92.60.224.14: bytes=32 time=502ms TTL=63
Reply from 92.60.224.14: bytes=32 time=503ms TTL=63
Reply from 92.60.224.14: bytes=32 time=514ms TTL=63
Reply from 92.60.224.14: bytes=32 time=533ms TTL=63
Reply from 92.60.224.14: bytes=32 time=553ms TTL=63
Reply from 92.60.224.14: bytes=32 time=319ms TTL=63
Reply from 92.60.224.14: bytes=32 time=331ms TTL=63
Reply from 92.60.224.14: bytes=32 time=347ms TTL=63
Reply from 92.60.224.14: bytes=32 time=367ms TTL=63
Reply from 92.60.224.14: bytes=32 time=389ms TTL=63
Reply from 92.60.224.14: bytes=32 time=669ms TTL=63
Reply from 92.60.224.14: bytes=32 time=690ms TTL=63
Reply from 92.60.224.14: bytes=32 time=204ms TTL=63
Са њима може да се преговара и нуде разне повољности па није лоше да се распиташ. Иначе може само интернет али није 35/5 него 50/5 по тој цени. Наравно, FTTH варијанта.BTW, ima li ExeNet neke popuste za OSI, 2 ugovora i sl.? Koliko sam razumeo 35/5 net je 1500 na UO od 2 godine, i moze samo net?
Не страхује, на почетку сам мислио да сам добио једнократан попуст али ми све продуже кад год продужим или променим па сад имам поверења у њих.Sto se tice agregacije kod ExeNet-a, sta mislis zasto 11+ godina koristim iskljucivo njihov internet?Jednostavno su izmislili internet u odnosu na ostale u Srbiji
Nego ne zelim da izgledam kao calexx... Izgleda da strahuje da ce mu vratiti paket koji placa ukoliko na svakih 3, maksimalno 4 dana ne pomene 140/14 paket![]()
Ниси пропустио него им је маркетинг успорен, као и телевизија. То је у понуди, како су ми малопре рекли, месецак дана, нема ни слова на сајту али има на флајеру. Сви дуо2, трио2 и већи пакети имају право на 120 сати уназад. Плус су се отворили и за СТБ па дају 2 за пакет 2 и 3 за пакет 3. Не знам да ли постоји варијанта да мањи пакети добију уз доплату.
Е да, ово је решено тако што дају андроид бокс на коме постоји и апликација за њихову телевизију па се практично своди на исто што користе у IPTV варијанти. Повежеш га на рутер (везом са или без жице) и онда се играш. Малопре пробао, у кутији није било упутство а ни батерије за даљинац и AV каблић (не знам да ли су грешком или намерно то избацили) па сам проваљивао. Пошто још немам ни телевизор, све је ишло на монитор, без звука ... али ипак ради.
OTT TV Box MXQ R9
Posto sam pre par strana citao nesto oko promene racuna za uplatu, ovaj broj racuna koji pise na papirnoj verziji racuna je aktuelan za uplate?
Реално, ко нуди за 3.490 месечно 140/14 (ово није са попустом него пуна цена) чисте оптике, отворену дигиталну телевизију уз опцију да дају и 3 СТБ гратис ако неко нема одговарајући телевизор и 120 сати уназад? СББ за 3.899 нуди 100/6 а оних неколико корисника оптике може да добије и више. МТС је јефтинији али је тамо плафон 100/2. Само да поновим да ехе нуди додатне upload брзине уз доплату, не знам ко још то нуди.
Иде, не знам зашто касне са објавом на сајту када су флајери готови. Сасвим случајно сам, по ко зна који пут, питао када ће да уведу додатне услуге типа 72ч уназад и у ТП су ми рекли да то постоји и да неки пакети имају то у опису. Мој пакет то подразумева, само сам им дао ЛК да провере јесам ли то ја, потписао и добио бокс.Lepe vesti ako ovo ide u masu. Daj sličicu flajera ako imaš. Da li to znači da oni koji već imaju uslugu/ugovor mogu samo da im se jave i zatraže STBove i uspostavljanje usluge?
Дају додатни андроид бокс који закачиш каблом или бежично на своју мрежу и онда на телевизор. Значи обичан СТБ на један, овај андроид на други HDMI и бираш шта гледаш. У принципу може само овај андроид али ми делује да то још не ради најбоље. У неком тренутку не иду програми или иде понеки, могуће да је до мрежних подешавања, мало сам разгледао и бокс је добио адресу 192.168.0.161 док у неким подешавањима стоји 192.168.0.10 па још без gateway и DNS адресе. Свратићу опет кад стигнем да их питам, можда није до тога али је њихов посао да нађу где брља.Ne razumeh ovo za Android box. Jel STB zapravo android box?
НетНет је до скоро имао слабу понуду па су укапирали да морају да буду конкурентни. Зато су и изједначили понуду са ехе-нетом али нису понудили ништа више.Pa NetNet nudi, sve to osim mozda 120h (ali ni exe to ne nudi jos uvek, budimo realni). I to bas u Nisu, verovatno i u tvojoj zgradixD
Има их доста али се своде на један блок зграда или на неки кварт. Ехе покрива такорећи цео Ниш а иду и на север, североисток. По БГ или НС има пар њих са бољом понудом али нити се шире нити мени много значе.Da nije zalosno bilo bi smesno. Ali ako gledamo malo sire od Nisa, onda ih ima dosta koji nude slicna pakovanja, samo 2:1 ili 1:1 cak...
Дај неку паралелу са поменутим двојцем. Нити имају оптику (само се наслућује) нити имају боље од 10:1 у интернету нити им је дигитална отворена и не тражи доплату за други телевизор ... мада личи, сви нуде интернет, телевизију и телефонију.Stvar je u tome sto Exe od 2006 igra na tu kartu malo vise od konkurencije po njihovim odnosno nesto nizim cenama. Ili nesto manje od konkurencije po nesto nizim cenama. Pakete formiraju u odnosu na SBB - Telekom/ADSL/VDSL.
Наравно, зашто би неко себи правио трошкове без потребе? Иако мислим да битно повећање брзине не значи аутоматски и да ће корисници да праве толико већи промет, ипак то мора да буде покривено.Kao sto sam i rekao, ne ocekujem da exe promeni pakete sve dok ne dodje do toga da SBB/Telekom krenu sa optikom i to pod uslovom da Tel/Sbb unesu neku promenu u "cenjenju" paketa kao i dl:ul ratio.
Ма да, свуда около само зуји оптика а ехе то копира. Јесте да и НетНет и Поглед а мислим да их има још стално плету оптичке мреже по Нишу и то је добро, још да мтс крене а СББ реши да пусти FTTB и ето прилике да их ехе копира и опет оде испред.Ja bih voleo da Exe uvodi inovacije, a ne konkurencija, a da ih Exe onda samo copy/paste, tako da mi je po malo i drago sto ih je NetNet 101% kopirao![]()
Иде, не знам зашто касне са објавом на сајту када су флајери готови. Сасвим случајно сам, по ко зна који пут, питао када ће да уведу додатне услуге типа 72ч уназад и у ТП су ми рекли да то постоји и да неки пакети имају то у опису. Мој пакет то подразумева, само сам им дао ЛК да провере јесам ли то ја, потписао и добио бокс. Дају додатни андроид бокс који закачиш каблом или бежично на своју мрежу и онда на телевизор. Значи обичан СТБ на један, овај андроид на други HDMI и бираш шта гледаш. У принципу може само овај андроид али ми делује да то још не ради најбоље. У неком тренутку не иду програми или иде понеки, могуће да је до мрежних подешавања, мало сам разгледао и бокс је добио адресу 192.168.0.161 док у неким подешавањима стоји 192.168.0.10 па још без gateway и DNS адресе. Свратићу опет кад стигнем да их питам, можда није до тога али је њихов посао да нађу где брља.
Сликао сам на брзину, може да се прочита.
Pogledajte prilog 240228
Pogledajte prilog 240229
STB је онај стари а за андроид бокс сам написао, у питању је OTT TV Box MXQ R9 па лако нађеш све о њему.Hvala ti za ovu informaciju. Možeš li možda da okačiš koju fotku STBa i/ili android boxa? Koji je model Android boxa? Ako sam te razumeo taj android box dodje sa aplikacijom za gledanje 120h unazad? A mogu da se instaliraju i koriste i druge aplikacije za android boxeve?
Што, мислиш да мтс и сбб неће да крену а да их ехе опет остави за собом?Mah, za ovo poslednje, samo si stekao pogresan utisak![]()
Iz nekog mog iskustva obično proknjiže narednog radnog dana od uplate. A ako ti je iz nekog razloga bitno da to bude istog dana onda slikaj/skeniraj uplatnicu i pošalji na [email protected].Jos jedno pitanje vezano za racun i necu vise [emoji14] Koliko okvirno treba da prodje vremena da se proknjizi uplata?
