Exe Net - iskustva
  • Začetnik teme Začetnik teme pivce
Bilo bi dobro da dignu upload, bar 1-2 Mbps, mada je za danasnje standarde i to slabo.
Ako mene licno pitas, stvarno ne znam. Tebi je dovoljno i 32kbps uploada da ides okolo i davis teme/forume sa svojim 140/14 paketom koji si dobio po ceni nizeg paketa. Mislim, nemoj pogresno da me razumes, davio si i dok si imao 80/8 🙂
Ali pokusaj da zakacis fajl od nekoliko GB na server koji ima dovoljno kapaciteta da iskoristi maksimalno tih tvojih 14Mbps koje smatras super-magicnom brzinom. Dok se slanje obavlja pokusaj da surfujes, skajp/viber call, pokusaj video call, pokusaj da odigras nesto online itd. Javi nam kako ide 🙂
Sad ne znam da li znas, ali jedna obicna, mozda malo modernija porodica ovo opisano iznad radi vrlo cesto. Sa povecanjem x2 upload brzina taj mucni period bi se skratio tacno za duplo 🙂
ping 92.60.224.14 -t
Pinging 92.60.224.14 with 32 bytes of data:
Reply from 92.60.224.14: bytes=32 time=1ms TTL=63
Reply from 92.60.224.14: bytes=32 time=32ms TTL=63
Reply from 92.60.224.14: bytes=32 time=84ms TTL=63
Reply from 92.60.224.14: bytes=32 time=159ms TTL=63
Reply from 92.60.224.14: bytes=32 time=107ms TTL=63
Reply from 92.60.224.14: bytes=32 time=138ms TTL=63
Reply from 92.60.224.14: bytes=32 time=187ms TTL=63
Reply from 92.60.224.14: bytes=32 time=200ms TTL=63
Reply from 92.60.224.14: bytes=32 time=199ms TTL=63
Reply from 92.60.224.14: bytes=32 time=198ms TTL=63
Reply from 92.60.224.14: bytes=32 time=194ms TTL=63
Reply from 92.60.224.14: bytes=32 time=205ms TTL=63
Reply from 92.60.224.14: bytes=32 time=2ms TTL=63
Reply from 92.60.224.14: bytes=32 time=51ms TTL=63
Reply from 92.60.224.14: bytes=32 time=380ms TTL=63
Reply from 92.60.224.14: bytes=32 time=296ms TTL=63
Reply from 92.60.224.14: bytes=32 time=502ms TTL=63
Reply from 92.60.224.14: bytes=32 time=503ms TTL=63
Reply from 92.60.224.14: bytes=32 time=514ms TTL=63
Reply from 92.60.224.14: bytes=32 time=533ms TTL=63
Reply from 92.60.224.14: bytes=32 time=553ms TTL=63
Reply from 92.60.224.14: bytes=32 time=319ms TTL=63
Reply from 92.60.224.14: bytes=32 time=331ms TTL=63
Reply from 92.60.224.14: bytes=32 time=347ms TTL=63
Reply from 92.60.224.14: bytes=32 time=367ms TTL=63
Reply from 92.60.224.14: bytes=32 time=389ms TTL=63
Reply from 92.60.224.14: bytes=32 time=669ms TTL=63
Reply from 92.60.224.14: bytes=32 time=690ms TTL=63
Reply from 92.60.224.14: bytes=32 time=204ms TTL=63
Evo kako izgleda ping kod mene do exe-net gatewaya prilikom speedtesta. Zakljucak izvedi sam.
Za takve stvari postoji QoS. Ja za torrente obavezno limitiran upload da ne moze da smeta da se uospte koristi net (sto na DSLu stvarno ume da bude totalno nemoguce inace, a i kablovski nije imun nimalo).
Za upload ka serverima se slicno podesi, ali posto moderna porodica ne radi nikakav upload sem na InstaCrap, FakeBook, Twatter i slicnim "time wasverima" (time wasting serverima), ionako ne moze da iskoristi toliko uploada.
A pitatje malo IT kolege u Skandinaviji, Japanu, Koreji kako je tamo - hoces upload na server van zemlje? Pa mooooze, ali... nece to moci pravom brzinom. Skandinavske zemlje su jos OK, ako je ka serverima u Evropi.
Evo ja imam 30Mbps upload trenutno na LTE - jbm li ga sem za Speedtest da li je ista uspelo >10Mbps da iskoristi 🙁 FIrmin server je u USA, kod Pair Networks. Nikada nismo uspeli ni DSL brzine da iskoristimo za upload, i to nije nista cudno. Iz Koreje kada uploadujem jos je sporije, 100-200KBps 😀
Ja zelim isto brzi upload, nemam nista protiv toga, "jel'te" 🙂 Ali mislim da ljudi imaju prevelika ocekivanja. Izmedju ostalog da ce ostati pun kapacitet za koriscenje kao sada. Sada jos uvek vrlo malo korisnika koristi net, nemaju jake pakete itd.
Cim se to malo vise modernizuje, imacemo Gbit/Gbit link, ali u praksi nece ici preko 20/20. To je situacija recimo u Koreji, jos je gore u UK trenutno.
BTW, ima li ExeNet neke popuste za OSI, 2 ugovora i sl.? Koliko sam razumeo 35/5 net je 1500 na UO od 2 godine, i moze samo net?
Sa svime se slazem alfaunits 🙂 QoS furamo jos od 256/64Kbps WiFi paketa back to 2006 🙂 - I sve to stoji. Ja licno nemam tih problema uopste, ali znam kako je drugima i to vazi i za ostale ISPove.. E, sad tu se javlja i drugi problem, indijanaca sa jbnim seedboxovima i slicno tome, koji ce to da zloupotrebe. Iskreno licno sam veci trafik na mesecnom nivou pravio na nizim paketima, nego dok sam koristio trocifreni dl/ul. 🙂
Sto se tice agregacije kod ExeNet-a, sta mislis zasto 11+ godina koristim iskljucivo njihov internet? 🙂 Jednostavno su izmislili internet u odnosu na ostale u Srbiji 😛
Nego ne zelim da izgledam kao calexx... Izgleda da strahuje da ce mu vratiti paket koji placa ukoliko na svakih 3, maksimalno 4 dana ne pomene 140/14 paket 😀
Za OSI i 2 ugovora stvarno nemam ideju, uz malo pregovora verovatno nesto moze da se izboksuje.
50/5 je 1490 - 2g UO odnosno 1590 - 1g UO.
Haha, da, caleta svi znamo, on je tata bwe 🙂
Polako za agregaciju, pitanje je vremena.
Znam neke ranije informacije, da su uvek cekali da im Telekom poveca link pre nego sto su povecavali WiFi pakete da bi odgovorili na povecanja na ADSLu i SBBu. Nadam se da se tu nista nije promenilo. 🙂
Promenu paketa ocekujem kada SBB/Lelekom krene masovno sa optikom, pod uslovom da ponuda bude nesto drugacija od ovoga sto trenutno nudi ExeNet. Mislim i na odnos dl:ul brzina kao i na cene paketa.
Ja sam izuzetno zadovoljan WiFijem za sad, imao sam neke probleme u pocetku ali to je do podesavanja u ruteru bilo jer sam kupio svoj zbog izmenjive antene. 7/1 stalno bez prekida, lagano igram WoT bez ikakvih problema a bio sam izuzetno skeptican kada sam uzimao WiFi. Jos ako bi uletelo neko povecanje to bi bilo full, npr 10/2 bi bilo idealno, ne treba mi vise.
QoS je resenje za vase probleme. Evo kako kod mene izgleda ping kad radim speedtest (exenet optika).
Ja uploadujem prilično podataka, nije da branim exe za odnos brzina 10/1. Oni imaju upload boostere pa ko hoce neka plati. Sta radi njihova konkurencija? Mozda ce mts optika malo da ih natera da povecaju upload, SBB, Kopernikus, pa i netnet ne vidim da imaju nesto brze upload brzine. Generalno nemaju potrebu da daju vece brzine uploada (opet kazem bar ima uz doplatu).
Sta da rade ljudi na mts vdsl-u koji u vecini slucajeva moze da gura i 20Mbps upload, pa ne daju vise od 2Mbps ni pod kojim uslovima. Da li u SBB-u imate brzi upload, da li kod mts-a (osim na skupljim optickim paketima) imate veci upload? To je problem, tehnicki kroz optiku (gPON) kroz jedno vlakno - koje se deli na 16 korisnika maksimalno moze da prodje 2.5/1.25Gbps - sto ne znaci da korisnici uz agregaciju ne bi mogli da dobiju 500/250Mbps i da u danasnje vreme niko ni ne primeti da je to deljen saobracaj. Jer kroz gPON svaki korisnik - ako bi se podelila brzina podjednako i svi na jednom vlaknu u istom trenutku prenosili nesto, svako bi imao oko 160/80Mbps.
# ping 92.60.224.1
PING 92.60.224.1 (92.60.224.1) 56(84) bytes of data.
64 bytes from 92.60.224.1: icmp_seq=1 ttl=63 time=1.24 ms
64 bytes from 92.60.224.1: icmp_seq=2 ttl=63 time=1.20 ms
64 bytes from 92.60.224.1: icmp_seq=3 ttl=63 time=1.17 ms
64 bytes from 92.60.224.1: icmp_seq=4 ttl=63 time=1.22 ms
64 bytes from 92.60.224.1: icmp_seq=5 ttl=63 time=1.18 ms
64 bytes from 92.60.224.1: icmp_seq=6 ttl=63 time=1.20 ms
64 bytes from 92.60.224.1: icmp_seq=7 ttl=63 time=1.23 ms
64 bytes from 92.60.224.1: icmp_seq=8 ttl=63 time=1.05 ms
64 bytes from 92.60.224.1: icmp_seq=9 ttl=63 time=1.20 ms
64 bytes from 92.60.224.1: icmp_seq=10 ttl=63 time=1.18 ms
64 bytes from 92.60.224.1: icmp_seq=11 ttl=63 time=0.407 ms
64 bytes from 92.60.224.1: icmp_seq=12 ttl=63 time=1.28 ms
64 bytes from 92.60.224.1: icmp_seq=13 ttl=63 time=1.17 ms
64 bytes from 92.60.224.1: icmp_seq=14 ttl=63 time=1.18 ms
64 bytes from 92.60.224.1: icmp_seq=15 ttl=63 time=1.35 ms
64 bytes from 92.60.224.1: icmp_seq=16 ttl=63 time=1.11 ms
64 bytes from 92.60.224.1: icmp_seq=17 ttl=63 time=0.333 ms
64 bytes from 92.60.224.1: icmp_seq=18 ttl=63 time=0.843 ms
64 bytes from 92.60.224.1: icmp_seq=19 ttl=63 time=0.347 ms
64 bytes from 92.60.224.1: icmp_seq=20 ttl=63 time=1.10 ms
64 bytes from 92.60.224.1: icmp_seq=21 ttl=63 time=1.19 ms
64 bytes from 92.60.224.1: icmp_seq=22 ttl=63 time=0.297 ms
64 bytes from 92.60.224.1: icmp_seq=23 ttl=63 time=1.18 ms
64 bytes from 92.60.224.1: icmp_seq=24 ttl=63 time=1.25 ms
64 bytes from 92.60.224.1: icmp_seq=25 ttl=63 time=1.27 ms
64 bytes from 92.60.224.1: icmp_seq=26 ttl=63 time=1.54 ms
64 bytes from 92.60.224.1: icmp_seq=27 ttl=63 time=0.853 ms
64 bytes from 92.60.224.1: icmp_seq=28 ttl=63 time=1.15 ms
64 bytes from 92.60.224.1: icmp_seq=29 ttl=63 time=0.325 ms
64 bytes from 92.60.224.1: icmp_seq=30 ttl=63 time=0.202 ms
64 bytes from 92.60.224.1: icmp_seq=31 ttl=63 time=1.17 ms
64 bytes from 92.60.224.1: icmp_seq=32 ttl=63 time=1.08 ms
64 bytes from 92.60.224.1: icmp_seq=33 ttl=63 time=1.24 ms
64 bytes from 92.60.224.1: icmp_seq=34 ttl=63 time=1.17 ms
64 bytes from 92.60.224.1: icmp_seq=35 ttl=63 time=1.15 ms
64 bytes from 92.60.224.1: icmp_seq=36 ttl=63 time=1.17 ms
64 bytes from 92.60.224.1: icmp_seq=37 ttl=63 time=1.19 ms
64 bytes from 92.60.224.1: icmp_seq=38 ttl=63 time=1.11 ms
64 bytes from 92.60.224.1: icmp_seq=39 ttl=63 time=1.21 ms
64 bytes from 92.60.224.1: icmp_seq=40 ttl=63 time=0.561 ms
64 bytes from 92.60.224.1: icmp_seq=41 ttl=63 time=0.318 ms
64 bytes from 92.60.224.1: icmp_seq=42 ttl=63 time=1.04 ms
64 bytes from 92.60.224.1: icmp_seq=43 ttl=63 time=0.918 ms
64 bytes from 92.60.224.1: icmp_seq=44 ttl=63 time=1.20 ms
64 bytes from 92.60.224.1: icmp_seq=45 ttl=63 time=0.565 ms
64 bytes from 92.60.224.1: icmp_seq=46 ttl=63 time=1.14 ms
64 bytes from 92.60.224.1: icmp_seq=47 ttl=63 time=1.14 ms
64 bytes from 92.60.224.1: icmp_seq=48 ttl=63 time=0.278 ms
64 bytes from 92.60.224.1: icmp_seq=49 ttl=63 time=0.572 ms
64 bytes from 92.60.224.1: icmp_seq=50 ttl=63 time=0.782 ms
64 bytes from 92.60.224.1: icmp_seq=51 ttl=63 time=0.500 ms
64 bytes from 92.60.224.1: icmp_seq=52 ttl=63 time=0.286 ms
64 bytes from 92.60.224.1: icmp_seq=53 ttl=63 time=0.979 ms
64 bytes from 92.60.224.1: icmp_seq=54 ttl=63 time=1.16 ms
64 bytes from 92.60.224.1: icmp_seq=55 ttl=63 time=1.17 ms
^C
--- 92.60.224.1 ping statistics ---
55 packets transmitted, 55 received, 0% packet loss, time 54278ms
rtt min/avg/max/mdev = 0.202/0.973/1.541/0.352 ms
Čak dolazim do toga da je ping manji kad je protok zauzet. Ni jedan ping nije kasnio vise od 1.5ms iako opteretim link sa 200Mbps protoka na optici.
Ono što koristim je htb+fq_codel (pročitajte više koga zanima na bufferbloat.net), ono što je dobro je što je taj traffic shaper standardan u OpenWRT i LEDE custom firmware-ima za rutere. Doduše na ovim naj jeftinijim sa 4MB Flash memorije nema baš mesta da se instalira traffic shaper. Mora neki malo napredniji sa bar 8MB Flash memorije.
Ja ovo guram na prilično jeftinoj itx mašini (Celeron 847 sa dual gigabit lan-om na ploči) sa custom linux distribucijom, koju smo pravili ja i brat isključivo za ovu namenu. Inače fq_codel mi se odlično ponaša i na sledećim linkovima (VDSL 50/2, ExeNet wifi 18/4 i za divno čudo Vip vikend netu (4G LTE na fiksnoj lokaciji)).
Generalno je odlično što i OpenWRT odnosno LEDE koriste ovaj algoritam za traffic shaping.
Ето, ја напишем кратак коментар а ово је опширније објашњење шта сам мислио.
Практично, лепо је да се тражи више и више али је нереално да се то ради код некога ко нуди више од огромне већине осталих. Реално, ко нуди за 3.490 месечно 140/14 (ово није са попустом него пуна цена) чисте оптике, отворену дигиталну телевизију уз опцију да дају и 3 СТБ гратис ако неко нема одговарајући телевизор и 120 сати уназад? СББ за 3.899 нуди 100/6 а оних неколико корисника оптике може да добије и више. МТС је јефтинији али је тамо плафон 100/2. Само да поновим да ехе нуди додатне upload брзине уз доплату, не знам ко још то нуди.
Са њима може да се преговара и нуде разне повољности па није лоше да се распиташ. Иначе може само интернет али није 35/5 него 50/5 по тој цени. Наравно, FTTH варијанта.
Не страхује, на почетку сам мислио да сам добио једнократан попуст али ми све продуже кад год продужим или променим па сад имам поверења у њих. 😉
А иначе у првом пасусу баш делујеш као ја. 😛
Kako misliš 120 sati unazad!? Kod Exe neta? Na kom paketu, jel sam ja to nešto propustio??
Ниси пропустио него им је маркетинг успорен, као и телевизија. То је у понуди, како су ми малопре рекли, месецак дана, нема ни слова на сајту али има на флајеру. Сви дуо2, трио2 и већи пакети имају право на 120 сати уназад. Плус су се отворили и за СТБ па дају 2 за пакет 2 и 3 за пакет 3. Не знам да ли постоји варијанта да мањи пакети добију уз доплату.
Е да, ово је решено тако што дају андроид бокс на коме постоји и апликација за њихову телевизију па се практично своди на исто што користе у IPTV варијанти. Повежеш га на рутер (везом са или без жице) и онда се играш. Малопре пробао, у кутији није било упутство а ни батерије за даљинац и AV каблић (не знам да ли су грешком или намерно то избацили) па сам проваљивао. Пошто још немам ни телевизор, све је ишло на монитор, без звука ... али ипак ради.
OTT TV Box MXQ R9
OTT TV Box MXQ R9
Lepe vesti ako ovo ide u masu. Daj sličicu flajera ako imaš. Da li to znači da oni koji već imaju uslugu/ugovor mogu samo da im se jave i zatraže STBove i uspostavljanje usluge?
Ne razumeh ovo za Android box. Jel STB zapravo android box?
Posto sam pre par strana citao nesto oko promene tekuceg racuna za uplatu, ovaj tekuci koji pise na racunu je aktuelan za uplate?
Pa NetNet nudi, sve to osim mozda 120h (ali ni exe to ne nudi jos uvek, budimo realni). I to bas u Nisu, verovatno i u tvojoj zgradi 🙂 xD
Da nije zalosno bilo bi smesno. Ali ako gledamo malo sire od Nisa, onda ih ima dosta koji nude slicna pakovanja, samo 2:1 ili 1:1 cak...
Stvar je u tome sto Exe od 2006 igra na tu kartu malo vise od konkurencije po njihovim odnosno nesto nizim cenama. Ili nesto manje od konkurencije po nesto nizim cenama. Pakete formiraju u odnosu na SBB - Telekom/ADSL/VDSL.
Kao sto sam i rekao, ne ocekujem da exe promeni pakete sve dok ne dodje do toga da SBB/Telekom krenu sa optikom i to pod uslovom da Tel/Sbb unesu neku promenu u "cenjenju" paketa kao i dl:ul ratio.
Ja bih voleo da Exe uvodi inovacije, a ne konkurencija, a da ih Exe onda samo copy/paste, tako da mi je po malo i drago sto ih je NetNet 101% kopirao 😀
Иде, не знам зашто касне са објавом на сајту када су флајери готови. Сасвим случајно сам, по ко зна који пут, питао када ће да уведу додатне услуге типа 72ч уназад и у ТП су ми рекли да то постоји и да неки пакети имају то у опису. Мој пакет то подразумева, само сам им дао ЛК да провере јесам ли то ја, потписао и добио бокс.
Дају додатни андроид бокс који закачиш каблом или бежично на своју мрежу и онда на телевизор. Значи обичан СТБ на један, овај андроид на други HDMI и бираш шта гледаш. У принципу може само овај андроид али ми делује да то још не ради најбоље. У неком тренутку не иду програми или иде понеки, могуће да је до мрежних подешавања, мало сам разгледао и бокс је добио адресу 192.168.0.161 док у неким подешавањима стоји 192.168.0.10 па још без gateway и DNS адресе. Свратићу опет кад стигнем да их питам, можда није до тога али је њихов посао да нађу где брља.
Сликао сам на брзину, може да се прочита.
НетНет је до скоро имао слабу понуду па су укапирали да морају да буду конкурентни. Зато су и изједначили понуду са ехе-нетом али нису понудили ништа више.
Ти би могао да будеш мало више реалан а не да пишеш само да буде контра ономе што ја напишем. Види слике у претходној поруци.
Има их доста али се своде на један блок зграда или на неки кварт. Ехе покрива такорећи цео Ниш а иду и на север, североисток. По БГ или НС има пар њих са бољом понудом али нити се шире нити мени много значе. 😉
Да не знам шта пишеш о ехе-нету, помислио бих да си из конкуренције а и волиш да ми контрираш. 😉
Дај неку паралелу са поменутим двојцем. Нити имају оптику (само се наслућује) нити имају боље од 10:1 у интернету нити им је дигитална отворена и не тражи доплату за други телевизор ... мада личи, сви нуде интернет, телевизију и телефонију.
Наравно, зашто би неко себи правио трошкове без потребе? Иако мислим да битно повећање брзине не значи аутоматски и да ће корисници да праве толико већи промет, ипак то мора да буде покривено.
СББ има у ценовнику оптичке пакете, да не помињем да је 10:1 али ми делује да је за нијансу повољније па ће ехе да испрати новим брзинама. МТС крије ценовнике а они који се повремено појаве су ужас, надам се да нису коначни.
Ехе би без проблема са овом инфраструктуром могао да пусти много веће брзине и то ће да ураде као што се свуда по свету ради, када конкуренција пристигне. Имао сам прилику да код себе пробам 500/500 и ради без проблема па је само питање времена када ће и колико да убрзају.
Ма да, свуда около само зуји оптика а ехе то копира. Јесте да и НетНет и Поглед а мислим да их има још стално плету оптичке мреже по Нишу и то је добро, још да мтс крене а СББ реши да пусти FTTB и ето прилике да их ехе копира и опет оде испред.
Иде, не знам зашто касне са објавом на сајту када су флајери готови. Сасвим случајно сам, по ко зна који пут, питао када ће да уведу додатне услуге типа 72ч уназад и у ТП су ми рекли да то постоји и да неки пакети имају то у опису. Мој пакет то подразумева, само сам им дао ЛК да провере јесам ли то ја, потписао и добио бокс. Дају додатни андроид бокс који закачиш каблом или бежично на своју мрежу и онда на телевизор. Значи обичан СТБ на један, овај андроид на други HDMI и бираш шта гледаш. У принципу може само овај андроид али ми делује да то још не ради најбоље. У неком тренутку не иду програми или иде понеки, могуће да је до мрежних подешавања, мало сам разгледао и бокс је добио адресу 192.168.0.161 док у неким подешавањима стоји 192.168.0.10 па још без gateway и DNS адресе. Свратићу опет кад стигнем да их питам, можда није до тога али је њихов посао да нађу где брља.
Pogledajte prilog 240228
Pogledajte prilog 240229
Hvala ti za ovu informaciju. Možeš li možda da okačiš koju fotku STBa i/ili android boxa? Koji je model Android boxa? Ako sam te razumeo taj android box dodje sa aplikacijom za gledanje 120h unazad? A mogu da se instaliraju i koriste i druge aplikacije za android boxeve?
Hehe, ja ih samo kritikujem da bi bili jos bolji. 🙂 Nista vise 😛
Ok, NetNet nema telefoniju, ali ni Exe je nije imao do pre ~1god. Ubacice je i oni verovatno i onda cemo dobiti 2x~Isto. 🙁 Za sada ne bih preporucio DUO kod NetNeta jer sam imao prilike da vidim izbor kanala i Exe ipak ima nesto (blago) bolju ponudu. Realno, 80% kanala da izbace ne bih ni primetio i onako ih samo preskacem kada i taj jedan dan nedeljno (i redje) sednem ispred TVa.
Upravo se o tome i radi, sto imaju GPON, a "pilicare" (bas kao i NetNet) sa odnosom DL:UL brzina. A to sve, zato sto im se moze jer ostali cable ISPovi ne mogu da ponude vise od toga. I sto u Telekomu ocigledno vole da maltretiraju svoje korisnike pa im 2Mbps uploada nude kao max i ako imaju uslova da profuraju i mnogo vise. Da nema ovih mucenika sa koaksijalnim kablovima, Exe bi nudio nesto tipa 110/2.5Mbps 😉 - To je ono sto meni licno smeta.
Mah, za ovo poslednje, samo si stekao pogresan utisak 🙂
STB је онај стари а за андроид бокс сам написао, у питању је OTT TV Box MXQ R9 па лако нађеш све о њему.
Апликација је ExeTV а могу да се инсталирају и остале али је проблем у недостатку меморије. Долази са 1/8 плус може да се дода SD картица али нисам сигуран да ли она може да помогне. Мислим и да је препуњен па не може да се дода много тога мада ... нешто може да се деинсталира (ФБ рецимо а и још неки повећи) али не знам шта бих да убацим.
Могли су да изаберу и неки бољи али ајде кад је фрај.
Mislio sam na ono kontriranje. Inace ne sumnjam da ce Exe opet da ih ostavi za sobom za nekim manje/vise minimalnim raskorakom. 😉 Ali nase je da se nadamo da ce konkurencija malo "grublje" reagovati, kako bi i Exe bio primoran da napravi veci raskorak, inace odosmo mi i na 20:1 😀
Jos jedno pitanje vezano za racun i necu vise 😛 Koliko okvirno treba da prodje vremena da se proknjizi uplata?
Upload uglavnom svuda mora da se doplati. Prosečnim korisnicima to ne treba. Recimo meni treba pa sam uzeo. Šta je problem da doplatiš za upload booster ako ti je bitan upload?
Oko tv mi nije jasno, nigde nema linkova na sajtu kojih kanala ima gde u ponudi. Koji su to premium kanali doplacuju uz nize pakete i sta sadrze ti prepiumu paketi?
