Visa vrši konverziju a banka možda uzima neku proviziju.Jedno pitanje vezano za povlacenje. Dodao sam VISA Electron karticu koja je vezana za dinarski racun? Da li pri povlacenju dolara na nju banka izvrsi automatsku konveziju u dinare?
Dodatno objanjenje je je da je to nekakav Matrix (taj njihov sistem) na koji oni nikako ne mogu da utiču, ni ručno da uključe. Da li je neko imao slično iskustvo, dodavanje tuđe kartice u svoj nalog, verifikacija kartice je uspešno prošla?I have reviewed your PayPal account and can see that your payment attempts have been stopped by our internal security system.
You will be able to add it straight away after the card is removed from the other PayPal account.
To provide one of the safest online payment methods PayPal reviews every payment before it's approved. Occasionally, we may block the use of a particular card or your balance if there may be a higher-than-normal level of risk associated with the transaction.
When a payment is blocked, this is not a reflection of you or your account activities. Our internal security system is an automated system which reviews all of the details of every payment that is made through PayPal. It has been designed to recognise patterns that could result in buyer complaints, unauthorised claims or chargebacks. This is similar to the way your bank or credit card issuer approves transactions.
For fraud prevention reasons, I cannot see what aspect of this payment has caused our internal security system to intervene. Neither can I override or manually change the security settings to allow your payment to go through.
I can, however, give you advice on the steps you can take to reduce the chances that our internal security system will block any future payments.
Here are some things that you can do that may help:
Clear your cache and cookies or try a different web browser
Attempt to make the payment from a different card
Attempt to make the payment at a different time
Ensure that you are making your payment from your country of residence. If possible attempt to complete the payment from your home computer or the computer you most frequently use to access your PayPal account.
In order to complete the withdrawals I would like to give you some advices:
Wait 24 hours before attempting another withdrawal
Try the operation using different web browsers (Explorer and Firefox for example) and to clear the cache and cookies on your device as well
Try the withdrawal from an home computer and from a consistent IP address
VPN and Proxy are not to be used with PayPal
If you connect from outside your country our security system might stop this operation for your own security
Check if the data on the card linked to your PayPal match with the ones in your PayPal account
Take in consideration that the limit per transactions for withdrawals on your account is $2,500.00 USD
Drugim rečima, još uvek nismo ni stigli do kartice, nisam ni kliknuo na Send, a ni prešao na sledeću stranu gde potvrđujem plaćanje. Šta bi to moglo da bude? Da li je problem što sam sa iste IP adrese sam otvarao i svoj PP nalog? To je juče svežeotvoren prvi nalog nekome ko zaista nikada nije imao PP. Jesam dodao svoju karticu juče. A onda i primetio da je ista kartica i dalje u mom nalogu, samo kao istekla (expired 2015). Izbacio sam je iz svog naloga, izbacio novu iz drugarovog naloga i onda opet dodao istu karticu u drugarov nalog i -- ne radi, ista greška i dalje. :wall:There's a problem
We can't send your payments right now. If the problem continues please contact Customer Support.
If you continue to encounter problems, please contact customer service.
I reviewed your account and it shows that the withdrawals are declined by our security system. To provide the safest online payment method in the world, PayPal reviews every transaction before it's approved.
To ti kažem. Generalno, sad skoro svi imaju vizu i onda možeš da napraviš nalog i na majčino ili očevo ime, vežeš karticu i nek stoji. I posle kad treba da primiš neke pare možeš da koristiš više naloga. To je posebno dobro ako primaš mesečno više od onog njihovog limita.Ja sam primio vecu sumu odmah, ali ne mogu da je povucem.
Sent from my LG-D855 using Tapatalk
Ne znam koji su to "sigurnosni razlozi" zašto ne mogu da komuniciraju putem poruka (za koje je potrebno biti ulogovan nalogom), nego mora glasom? I pitam kranje opšte stvari. Sad kad ovo izgleda radi (nisam još poslao novac), nemam nameru da ih zovem sa SkypeOut. 🙂I have reviewed your account, in order to help you I would recommend you to call us.
For security reasons, we are unable to answer all enquiries we receive by email. In those circumstances, in order to maintain the integrity of an account, we need to make sure we are speaking directly to the account holder. To assist you with your issue, we recommend contacting us by telephone and we will be more than happy to help you.
Vesti: na (novom) nalogu mog druga delimično nestala poruka o grešci koja se pojavljivala, sada može da izabere iznos i dođe do poslednjeg koraka da pošalje novac, što juče nije mogao, a da ništa nisam radio. Ali, kada se bira shipping adresa, pristaje samo na adresu koja je navedena kao Billing adresa na kartici. Ako izaberem bilo koju drugu adresu ili izaberem "no address necessary" -- opet ista poruka o grešci i ne može dalje. Kod mog PP naloga mogu da izaberem drugu shipping adresu ili da izaberem nijednu shipping adresu, lepo radi, ali kod drugara ne, iako ima pomaka od juče. Da i dalje čekam? :smoke: Da li je ovo normalno ponašanje?
Nisam još probao plaćanje (jer neću na billing adresu), samo hteo da javim da je izgleda trebalo sačekati. Što mi to support lepo nije rekao, već mi davao kriptični odgovor? Vi ste mi ovde lepo savetovali da sačekam i izgleda da je bilo potrebno samo, mada još problem nije rešen. 🙂
Danas su mi odgovorili iz PP za nalog drugara:
Naravno da može. I treba to iskoristiti dok se ne reguliše zakon za to.Jel moze da se salje kod nas, a da ne budemo gonjeni [emoji3]
Kako to mislis gonjeni? Mislis za porez?
Koliko je nalog "star"?Blic pitanjce:
PP iz Nemacke pokusava da posalje novac privatnom licu na PP u BiH,izbacuje gresku sa "Contact support",bez obzira na iznos (posto ima sredstava i na PP nalogu).
Kada pokusam da posaljem nekom u Nemackoj,bez ikakvih problema...
Da li BiH ima neka ogranicenja ili...?
Može biti do toga. Kada sam napravio moj nalog i novac trebao da primim nekoliko puta su mi rekli da nije moguće poslati novac na moj nalog. Posle nekog vremena, kad je nalog zaživeo sve je bilo u redu.Mislim da je nedavno otvoren,treba da proverim,ne znam tacno...
