Google Pixel(i) 2016 - off tema
DxO Piksele vec postavio na vrh :) https://www.dxomark.com/Mobiles/Pixel-smartphone-camera-review-At-the-top
Ajd' sad da cujem DxO hejtere koji su negodovali u poslednje vreme zbog ip7 testa :)
The Google Pixel takes some of the very best images we have seen from any smartphone we have ever tested
Unapredili su i stabilizaciju kamkordera!
Ocene za stab. su skoro kao sony.
Video
The Pixel produced overall excellent video results, with one of the best stabilization systems we’ve tested. Motion artifacts are visible only in low light, due to the longer shutter speeds needed
Pa se vi posle pitajte zasto su skupi ;)
Tu su i foto cropovi vs android flagship ekipa.
Sent from my D6503
Hahahhahhahahahahahahahahahhahahahshshshshshshahhahahhahahahahahhahahahhahhahahahhahhahaahahahahhahahahahahahahahahah
@G@W
Ajde razmisli o napustanju teme, pocinjes da smaras.
Ovde mi se za sad pored cene jedino ne svidja Gorila staklo 4(koji je pretpostavljam i na ovom zadnjem delu) videli smo na Note 7 kako se lako grebe.
Note koristi GG 5, tako da je bolje što su ostali na 4
Sent from my LG-D838 using Tapatalk
Sent from my D6503
Hmmm.. ovde ne piše ois.
Video
The Pixel produced overall excellent video results, with one of the best stabilization systems we’ve tested. Motion artifacts are visible only in low light, due to the longer shutter speeds needed.
The Pixel’s 12.3MP main camera is paired with a fast f/2.0 lens. Autofocus is provided by a combination of laser detection (LDAF) and phase detection (PDAF). The Pixel can also record 4K video at 30fps, and 1080p video at up to 120fps.
Jel ovo sve sto se tice Pixel telefona?
Kako je sve odjednom manje cool kad se ponudi na ovaj način, a objektivno je sve odlično osim cene i dizajna (subjektivno).
Video
Koliko sam ja skapirao socivo kamere nema ugradjen OIS nego nesto pomocu ziroskopa softverski stabilizuju sliku.
Šteta onda iako na ap piše ois.
Meanwhile, the refined HDR+ algorithms capture a series of images at multiple short exposures, fusing them into a single, enhanced image. As HDR+ produces no shutter lag, it is on by default.
Mala je baterija. SoC je nista specijalno. Softver valja ocistiti od Google spy apps. Mozda bude problema sa root-om u buducnosti. Jedino ce po svemu sudeci kamera biti zver. Pitanje je kakav je storage. Obzirom da sve bacaju na upload, mozda nije sjajan.
Ne znam, meni bas i nije vrh.
Elektronska stabilizacija nazalost, nista od opticke! Cekam rezultate izdrzljivosti baterije, ali vec unapred naslucujem da ce da bude prosek nazalost.
Ali 650dolara za manji model!!!! Koliko je xl? Izvinite na pitanjima ne pratim prezentaciju
Sony je primer da elektronska stabilizacija ne mora da bude loša uopšte, samo da ne bude kao na 6p/5x
Nisam video na prezentaciji ali mislim da je u leakovima (koji su se za sada ispostavili 100% tacni) pisalo 749$ za veci model.
malo o hdr+
Pixel’s biggest innovation is an enhanced version of Google’s HDR+ multi-image capability. First introduced in some of its Nexus phones (see our Nexus 6P review), the upgraded version in the Pixel combines several RAW images in near-real time to create one enhanced JPEG image with lower noise and extended dynamic range as the final result.
The Pixel activates the Google Camera app’s Auto HDR+ feature as its default camera mode. The Pixel determines whether it needs to use multiple images to get lower noise and better dynamic range, then switches HDR+ on as needed. It also does a good job of detecting rapid motion in the scene, avoiding the ugly artifacts often found in images from other HDR systems.
Google certainly isn’t unique in providing clever software for assembling multiple images, as Apple, Motorola, and Sony have all done something similar – but the Pixel pushes the capability further than we’ve seen before.
HDR+ was introduced with the Nexus 6P last year, and has been included in Nexus models since then, but the Pixel’s increased computing power extends the feature’s functionality and performance.
To assess the Pixel’s HDR+ capabilities, we did a comparison of the Pixel and the Nexus 6P using a very simple test:
We took a shot every second for more than 10 seconds and compared the level of image quality provided for each shot. If image quality went down significantly, it meant that the smartphone didn’t have enough processing power to provide an HDR+ picture and instead provided a traditional single-frame image. The Nexus 6P was unable to keep up, but the Pixel could capture as many as 9 HDR+ frames before falling back to a single-frame image.
If we slowed down to one image every 3 seconds, the Pixel was able to provide HDR+ pictures indefinitely, while the Nexus 6P failed to use HDR+ after 4 images, meaning that the Pixel has more consistent image quality when shooting multiple images.
video stabilizacije je po njima najbolja do sada..
With very impressive stabilization, accurate autofocus, and generally good quality, the Pixel produces excellent video under most conditions. Its Video score of 88 is tied with the Samsung Galaxy S7 and the Sony Xperia X for the highest ever achieved.
Za mainstream mora ovaj "friendly" izgled, ne može da prođe nešto kao raniji nexusi.
Mora nežno, zaobljeno, kao iPhone.
Ovo treba i žene da požele verovatno, mada to neće ići :D
Ubili su u mozak sa ovim ok Google, ogadiće i onima koji će da koriste Google home.
@ G@W
Nisu to male baterije za 5" i 5.5" ekrane, bice to Nexusi tj Pikseli sa najboljom autonomijom ikada od svih Gugl telefona.
Kamera kida, LDAF i PDAF + krstena stabilizacija videa, sve ono sto im je falilo u odnosu na S7/N7.
Dakle to su najbolje smartfon kamere na trzistu, ne ubedljivo ali najbolje. Dodajte na to najbolji softver-podrsku, high-end hardver, kvalitetne ekrane i dobre baterije i jasno je da su Pikseli najbolji androidi na trzistu a rekao bih i naj smartfoni uopste uz IP7+ ;)
Ako su godinama plasticne Samsung Galaxy nakaze sa ocajnim TW mogle da kostaju ovoliko na startu onda mogu i Gugl Pikseli.
Jedina mana ostaje Goophone-olikost..
@ fkl
To za kamkorder skor ce im trajaji kratko tj sve dok ne budu testirali XZ :-D
Sent from my D6503
Koliko ce ovaj asistent da bude duboko usadjen u sistem? Google Now mi nije smetao jer je bio samo jos jedan app ali deluje kao da su ovaj novi Android izgradili oko asistenta.
A ono sto me zanima najvise.. bootloader status i source, ni reci... *** ih ovaj skynet koji ovde ima koristi kao apple store [emoji23]
Sent from my m8 using Tapatalk
Pa ocekuj da google naredi da svi budući telefoni moraju da imaju tog špijuna u sebi.. takva vremena dolaze ***. Nadam se da će sa rootom moći da se obriše ,mada..
Andromeda MIA :D
Kakav kraj...
