Izasao update HTC 10 porta. Popravljena frekvencija i mnogo toga.
Download: https://www.androidfilehost.com/?fid=24499762636007238
@pera987 je verovatno probao rom 🙂
Sent from my HTC One_M8 using Tapatalk
Misliš bootloader da otključam?
Ako ga vratis na stock 4.4.2 otkljucas sa ovim programom.
Ja sam ga rootovao i ostalo uradio preko:
WinDroid Toolkit v3.1
Ma ispravno je bre 🙂
Ne kucas fastboot getvar all dok je upaljen telefon, vec kucas u bootloader-u(onaj beli meni sa RECOVERY, FACTORY RESET itd.)
I da li ti pise UNLOCKED,LOCKED,RELOCKED u bootloader-u?
Mozes da se prijavis na Google acc, pri onim pocetnim podesavanjima. Cim podesis jezik i wifi, onda ti ponudi da uneses google mail i password.
Moze da se flesuje MM pomocu RUU-a. Posto ti je 6.12.401 verzija, skines 401 RUU, tj. za evropu, onda pratis uputstvo sa xda. Moras da imas zakljucan bootloader (LOCKED ili RELOCKED). U bootloader ulazis tako sto drzis power+vol down. I ne mozes sevratiti na KK, a ako imas S-OFF onda mozes. Brise sve sa telefona, ukljucujuci i internu.
Nisam flesovao RUU na 708 verziji jer i nema RUU fajla, a inace bih flesovao da ima i objasnio detaljno.
U sustini nista nije komplikovano, samo prati svaki korak:
Ovde imas RUU.zip Skini ga i prati uputstvo. Izaberi metodu koja ti je laksa.
Flashing the RUU.zip
Method 1
*ADB / Fastboot*
First, make sure you have the path to adb and fastboot setup in your system environment variables
When you open a command prompt, open it in the folder the zip is in. Hold shift, Left Mouse click, open command prompt here.
1. Rename the RUU.zip to something short and easy like RUU.zip
2. adb reboot bootloader "press enter" Wait till phone reboots into fastboot
3. fastboot oem rebootRUU "press enter" Wait till the phone is in RUU mode (black screen with HTC logo)
4. fastboot flash zip RUU.zip "press enter"
*You will get the following message: FAILED (remote: 90 hboot pre-update! please flush image again immediately)
*RUU mode will reboot,
*Now run the same command again,
5. fastboot flash zip RUU.zip "press enter"
6. fastboot reboot-bootloader "press enter"
7. Select hboot, Do a factory reset in recovery. To enter the recovery menu when greeted by a "red triangle with an exclamation", Hold Volume UP and click Power.
8. Done, reboot system
Method 2
*External / mircoSD card*
1. Rename the RUU.zip to "0p6bimg" or "0p6bdiag" Note: the name is not case sensitive
2. Place the zip in the root of your external SD card
3. Power off the phone
4. Boot into Hboot (hold volume down as you power on the device)
5. The zip will automatically load and ask you if you would like to proceed
6. Select "Yes"
7. Wait, the zip will load the hboot first, it will then reboot and continue
8. Reboot then remove your sdcard. Hold Power and Volume UP until it reboots then Hold Power and Volume down until you get back to hboot.
9. Do a factory reset in recovery. To enter the recovery menu when greeted by a "red triangle with an exclamation", Hold Volume UP and click Power.
10. Done, reboot system
OK, sada imam i ja problem 😀 . Flesovao SuperSU i ElementalX na cist stock. Nece da mi se upali telefon. Nemam nikakav backup, a hocu da izvucem poruke, bekapujem app itd. Stoji na onom belom HTC logo, sa crvenim tekstom i ne mrda. Radio sam wipe cache i dalvik nista ne pomaze. @imotep995 @pera987 ?
