Eno na dbrand-u 30% OFF EVERYTHING FOR 48H.
Opasno se razmisljam![]()
Jao bre @Proday pisano 20 puta. Možeš sa njihovog sajta preko PayPal-a ali na tu cenu dodaj i poštarinu od skoro 9$...![]()
Izvol(i)te
@vojkan - Review
http://forum.benchmark.rs/showthread.php?p=4554938
@vojkan - Baterija
http://forum.benchmark.rs/showthread.php?p=4554602
@vojkan - Kesiranje
http://forum.benchmark.rs/showthread.php?p=4554604
Kesiranje 2
http://forum.benchmark.rs/showthread.php?p=4595778
Kesiranje 3
http://forum.benchmark.rs/showthread.php?p=4596432
Kesiranje 4(Vojkane, koji si ti manijak...)
http://forum.benchmark.rs/showthread.php?p=4596607
@vojkan - ZRAM
http://forum.benchmark.rs/showthread.php?p=4592847
@Nikola1994 - Review
http://forum.benchmark.rs/showthread.php?p=4589910
@Nikola1994 - Baterija
http://forum.benchmark.rs/showthread.php?p=4594170
@Nikola1994 - Kesiranje
http://forum.benchmark.rs/showthread.php?p=4593138
@ChobbyNS - Baterija
http://forum.benchmark.rs/showthread.php?p=4598505
@ChobbyNS - Kesiranje
http://forum.benchmark.rs/showthread.php?p=4596640
@dovedan - Baterija
http://forum.benchmark.rs/showthread.php?p=4594519
Nije bitno Vojkane stavio sam ovako, lako ce ljudi preci tj bice nas opet i tamo i ovamo ali bar da se u ovoj temi pise samo o 5x a tamo o 6pI vas trojica sa 6p izbaci nas 20 sa 5x, gde je tu pravda eee
Ne stvarno, bolje ova tema da bude za 6p jer tamo ima mnogo više postova o 5x nego o 6p
Q : Why is a bad 3A resistor a problem?
A: 3A is bad because all of these cables and adapters are legacy host port adapter cable, meaning the other end of the cable is Type-A plug. The Type-A port and the vast majority of the devices that have Type-A ports were never designed to support 3A charging.
The cable lies to the phone by telling the phone it's attached to a pure 3A charging path, like the C-to-C cable to the OEM 3A charger that ships with the Nexus 6P/5X. The phone will attempt to draw 3A, but that may damage the weaker device you have the Type-A end of the cable plugged into.
Q: If I have a 1A or 2A charger, am I safe?
No, if you have a weaker charger, you are actually at MORE risk because your phone/tablet/laptop may not know to stop at the 1A or 2A limit the charger advertises because of the improper identifier in the cable.
Q: Do C to C cables have the same problem?
No. C to C cables do not have the same problem because they are required to be straight pass through and do not have a pullup built into the cable. If the other end of the cable is Type-C, then as long as you plug into a 3A charger (like the one you get with Nexus phones), you will get fast charging in a safe way.
Q: Can you recommend a Type-A charger? Is <insert some random Type-A charger from Amazon> safe? Is it fast?
I cannot review every charger, but as long as you have a safe compliant cable with a 56kΩ resistor, the phone will limit itself to safe levels of charging for Type-A chargers and hubs.
Whether or not a particular charger works best for your phone in terms of charge speed I cannot say definitively. It really depends on a ton of factors, including the protocols your phone and the charger supports. Phones and charger may be able to support up to 2.4A using various proprietary protocols with a safe cable.
Q: Can you recommend a Type-C fast charger?
I like the Google one. 2 Type-C ports, 22.5W total power.
https://store.google.com/product/usb_c_dual_port_charger
If you want a SUPER deluxe one, get the Pixel 2's charger. It will support up to 60W charging using USB PD. Fast charge your laptop.
https://store.google.com/product/universal_type_c_60w_charger
Q: How can I test the cable myself?
If you have a Chromebook Pixel :
https://plus.google.com/+BensonLeung/posts/jGP5249NppF
If you have a Nexus 6P/5X phone :
https://plus.google.com/+GeoffHoff/posts/eMsr1cyw75s
Or use CheckR:
https://play.google.com/store/apps/details?id=net.mderezynski.checkr
http://www.apkmirror.com/apk/in-sight-labs/checkr/
Q: I want to keep my bad cable. Is that OK?
Be very careful what you plug it into. If you must keep it, tag the cable with a label that says "3A bad cable" or something so that in a few years when you forget about this controversy, you don't grab that cable and damage a charger accidentally.
Q: Where can I find the USB spec to read up on this more?
http://www.usb.org/developers/usbtypec
Uzimaj i to 2 komada da se ne razgrabe , ozbiljan sam.
