Poolmaker
Nenadmašan
Odmah ispod izbora boja imaš da uključiš opciju da prikaže izabranu boju u start meniju taskbaru i notification centru. Znači odmah ispod onih ponuđenih boja. Staviš na ON i to je to.Ljudi,namestih u Colors_u da mi sve bude zeleno,ali zasto nije i taskbar ?
Kako to da namestim ?
Sad ce da kazu kada je free...kao da ostali nisu isto "free".Neće ljudi da pređu na 10ku pa to ti je, samo ovih nekoliko :
http://www.b92.net/tehnopolis/softver.php?yyyy=2015&mm=07&nav_id=1021987
Pun forum Tarabića, šta bi smo bez njih.I još brže će nazad, kad im "univerzalni kvadratići" dosade. 😉
Get colorized title bars without renaming/changing the Aero.msstyles
First of all, this is not a tweak for beginners. It includes modification of a system file, so please use it at your own risk!
Now, you might ask: Why don't you do it the way like it is described on WinAero? Answer: Because simply copying and renaming the Aero style/theme to circumvent the name checking in uDWM.dll prevents WPF applications from rendering buttons, text boxes, progress bars, etc. correctly in the Aero style. They fall back to the classic theme rendering because they don't recognize the renamed theme as being Aero anymore.
Prerequisites:
Download a hex editor (I use HxD in this tutorial).
Take ownership of the uDWM.dll file (in System32).
Copy the uDWM.dll file to a temporary location for editing
Tweaking:
Run HxD and open the uDWM.dll file from the temporary location.
On the menu bar, click Search and select Search...
Search for "aero.msstyles", but make sure the data type is text-string and the Unicode characters option is checked.
Now, overwrite "a e r o" with, for example, "o r e a" (you can use any four characters you want) - see image below.
Save the file and close HxD.
In the System32 directory, rename the uDWM.dll file to uDWM.dll.bak.
Copy the tweaked uDWM.dll file from the temporary location to System32.
Restart Windows.
Now you should get colorized title bars even when the normal Aero theme/style is active, and with it the Aero style in WPF applications. If you want to rollback this tweak, simply go to the System32 directory, rename the tweaked uDWM.dll to uDWM.dll.tweaked and the uDWM.dll.bak back to uDWM.dll (you cannot delete the tweaked uDWM.dll file right away because it is in use and therefore locked by the system). The uDWMl.dll.tweaked file can be deleted after the next reboot.
I na drugom računaru završena instalacija Windows 10 PRO x64 sa DreamSpark-a...
Isti serijski ključ - isti rezultat 🙂
Rehoh li ti ja. Možeš i na još da ih staviš. Ja sam to provalio još na 7-ici. Ne znam koji je maximum, ali mislim da je neograničeno. Nisam siguran pa zato ne dajem nikom .I na drugom računaru završena instalacija Windows 10 PRO x64 sa DreamSpark-a...
Ma znam ja sve to - godinama koristim legalan windows (od windows XP, preko 7 ...) sa dreamspark programa...
Nego na forumu je bilo par "stručnjaka slučajeva" koji su tvrdili da je sve to prevara 😀
Meni nije hteo da prodje DreamSpark kljuc iz Win 8.1. Prvo sam odradio upgrade i bio je aktiviran i cim sam odradio clean izbacio je gresku da je kljuc disableovan pa sam morao da uzmem novi sa DreamSparka. Verovatno je ovo zato sto je proslo dve godine pa nemam vise pravo na aktivaciju.
To jeste tako. Zato ga i ne dajem nikomeMSDN kljucevi kad procure budu black listovani...
