pilac
Sad ce da dodje Risbo da ti objasni neke stvari..... :d
A vidim da za The Last of Us remastered za preorder daju bonus ajteme, veći klip na pušci, brže kraftovanje i lečenje...e to jedino još više mrzim
jel i za ovaj pre order destiny-a preko psn treba da na mail stigne kod od bungi-a ili digitalni pre order ima automatski pristup? Ja sam napravio nalog na njihovom sajtu pre tri dana i sve povezao ali kod jos ne stize. Jel nekom stigao kod?i da li uopste treba da stigne?
Go to the EU PSN store, search for Destiny, pre-order it (for no immediate charge), and the Beta will begin downloading.
It will say that it has completed after downloading a small portion of it, but will continue to download in the background. To see the actual progress, navigate to the Destiny Beta tile, click the OPTIONS button, and select Information. You'll see a screen similar to the one in this post.
You will be able to play it on your main account in any region, so long as you go to Settings -> PSN -> Activate as Your Primary PS4.
OK. For PS4 clarification:
Pre-order the title. It will start downloading the beta.
Then go into: Settings -> PSN -> Account Information -> Wallet
Select: Transaction History.
Select: Next
You should see a Product Purchase in the amount of UK/Euro 0.00 from the date you preordered. Click on that Purchase entry
Select: Cancel Pre-order
That means you'll be able to download the Beta, and also ensure that the preorder is cancelled.
Da, da, mislim skida.
Prvo je nekih 170 MB, a sad ovih ostalih 15 GB u pozadini skida.
Javicu da li igra radi do uvece, ili ako se nekom pre skine neka javi.
Skinuo si samo client koji ne moze da se igra ako serveri nisu aktivni. Igraces isto kada i svi ostali, krajem nedelje.
Meni je destiny pre order odmah skinuo sa kartice 54funte dok npr prorder last of us mi nije skinuo nista tek ce 30jula
