Evo lik iz thread-a mi je poslao PM... šta reći, čovek je car.
Hi omnik,
In fact, to do the modifications of the bios image is not that complicated, but to get the idea you have to read the thread from the beginning ;) (also the link to the russian guide).
Anyway, I'm not using hexedit anymore, instead of hexedit I did a simple linux script (oneliner) to do the modifications. When the voltage values are replaced by linux sed I'm doing a quick open/save in VBE7. To run these cards at 1060MHz, the 1050mV core voltage should be enough, but it depends on the GPU ASIC quality. If You have some cards below 70-75% ASIC You have to go with the 1075mV version.
So, I did this two version for You.
https://www.dropbox.com/s/ziijau8mdxz7syz/gig1050.rom
https://www.dropbox.com/s/ya0nesjt069y8ma/gig1075.rom
Linux oneliner for the BIOS image modification:
1050mV
hexdump -ve '1/1 "%.2X"' 0.rom | \
sed "s/008010008B04/008010001404/g" | \
sed "s/00000000B604/000000001A04/g" | \
sed "s/0000B6040000/00001A040000/g" | \
sed "s/B60437001E03/1A0450001E03/g" | \
sed "s/B00438004203/1A0450004203/g" | \
sed "s/97043C005F03/1A0450005F03/g" | \
sed "s/7E0440007703/1A0450007703/g" | \
sed "s/78044100FF03/1A045000FF03/g" | \
sed "s/00008B040000/000014040000/g" | \
sed "s/8B043E001E03/140451001E03/g" | \
sed "s/84043F004203/140451004203/g" | \
sed "s/6B0443005F03/140451005F03/g" | \
sed "s/520447007703/140451007703/g" | \
sed "s/4C044800FF03/14045100FF03/g" | \
xxd -r -p > 0mod.rom
1075mV
sed "s/008010008B04/008010002D04/g" | \
sed "s/00000000B604/000000003304/g" | \
sed "s/0000B6040000/000033040000/g" | \
sed "s/B60437001E03/33044C001E03/g" | \
sed "s/B00438004203/33044C004203/g" | \
sed "s/97043C005F03/33044C005F03/g" | \
sed "s/7E0440007703/33044C007703/g" | \
sed "s/78044100FF03/33044C00FF03/g" | \
sed "s/00008B040000/00002D040000/g" | \
sed "s/8B043E001E03/2D044D001E03/g" | \
sed "s/84043F004203/2D044D004203/g" | \
sed "s/6B0443005F03/2D044D005F03/g" | \
sed "s/520447007703/2D044D007703/g" | \
sed "s/4C044800FF03/2D044D00FF03/g" | \
Sutra probam pa javim... mašina sa GBT 270kama je udaljena 5km od mene a vreme je polako za spavanje :)
Kakva je situacija sa naponom za Giga 270x (GV-R927XOC-2GD-GA)? Pretpostavljam da je isto kao sa 270. Meni stigla pre par dana, ali nikako da spustim napon. Pokusao preko trixa, ab, oc guru, ali nece. Inace asic 85,7%. :)
Probaj VBE7... ukoliko ne radi onda jedini način je ovo iznad napisano.
To mi je desktop,može ona bolje sigurno ali nisam experimentisao mnogo,gpu 950 memorija 1250
stigle meni danas 4 te "nesrece", nisam stigao da ih probam ali evo omnik nam je pomogao pa se nadam da cu sutra sve srediti
"Stigla" ... Mozda na njihovom sajtu.. Ista fora kao prosle godine sa BTC Asic-ima. Ko uhvati prvi order uz malo srece moze da prodje ok, tj. ko moze da pljune kes u startu za nesto jako...a posle... kud koji mili moji... Cim ova isplativost opada sve vise i vise zna se sta se dogadja...
Lepo ovo ali nigde nije navedeno da ovaj "privezak" treba da radi po trenutnom odnosu diff/LTC celih 200 dana samo da bi se otplatio.. ):
Rok otplate ne mozes da znas jer placas u dolarima a cena moze preko noci da se promeni, ja se nadam na bolje ali moze da bude i mnoooogo gore. Sve u svemu to je samo "privezak", cekajte da stignu ozbiljni uredjaji sa gomilom takvih cipova. Ovi prdavcu su po pravilu preskupi. Secam se onih eruptera koji u trenutku prodaje nisu mogli da otplate 50% para.
Hijao, hardvera za mining po oglasima ima ko salate i to po odlicnim cenama. Samo kesh fali :D.
mozes pogledati i ostale uredjaje na tom istom sajtu imaju do 160MH/s -> taj im je najjaci ... http://zeusminer.com/product/zeus-s-flex-ultra-professional-package-160mhs-scrypt-asic-miner-set/
Tako da mislim da mozemo pricati o tome da ozbiljni ASIC uredjaji uskoro ulaze u pricu LTC-a ... E sada jedino je pitanje kako ce ici prodaja sobzirom na trenutnu cenu (mada iskreno mislim da ce ljudi kupovati ..)
Zeus je azdaja. Nece oni moci da naprave dovoljno, veruj mi. Ljudi su spremni da uloze u ovo samo da dobiju pre i naprave sto veci stek pre nego sto skoci cena. Nisi svestan kako bi mi jedan takav zeus legao na gajbi ali je cifra prevelika za mene.
Kako je krenulo otici ce diff u nebesa jako brzo ako ovakvi uredjaji izadju na vreme. Verujem da ce i pre isporuke polovina kopati za prodavce.
U Q2, naspram ovih Q2/Q3 verovatno. KNC je ozbiljna firma ali nisam siguran koliko daleko su odmakli s konstruisanjem svoje sprave. Za to sto oni hoce da prave trebace im ozbiljni cipovi.
U Novembru bice u Decembru... :)
Dok ne dodje taj Q3, veruvatno ce ga najaviti za Q4. A onda ce ta cena biti prevelika kad diff ode u nebo.
Jedino mi nije jasno zasto knc radi preorder. Imaju sigurno dovoljno para za proizvodnju jer odavno stancuju asic za btc. Bas mi je cudno.
Zdravo drugari.
Obećao sam da ću da napišem kako sam rešio problem sa napajanjima i pločama, ali sam bio u gužvi pa nisam stigao, kasnije sam se smorio od silnih muka sa kopanjem, tako da nisam ni otvarao ovaj podforum(sad me čaka čitanje bar 50 strana, da pohvatam šta sam propustio)
Prvo
Imao sam muke sa tim što nisu grafike htele da rade na dodatnom napajanju, to sam rešio kao što ste me savetovali, napravio sam kratku vezu iz matične u drugo napajanje, ploča pali oba napajanja. sve radi.
Pogledajte prilog 139109
Drugo
Imao sam muke sa pločama GA-H61M-DS2H , tako da je jedna crkla posle 24h, a druga par dana kasnije, obe su izgorele na istom mestu, nažalost nisam slikao da vam pokažem.
Zamenio sam ih sa ASROCK PRO BTC( nisam ni znao da su to uvezli, ne bi se ni zezao sa ostalom buranijom)
Ploče su fenomenlane, sve radi ko podmazano
Treće
Napajanja GPS-700A8, zaobići, ima samo jedan kabl za vga i jedan sa 2x molex(stim što su žice mnogo tanke), jednostavno je loš za rudarenje
Četvrto
Ko ima Asus 270X DC2T obavezno da stavi novi bios, dobija 50Kh sa istim configom
Peto
Taj problem sam rešio tako što sam postavio novo napajanje GPS-700A8 da ide na ploču , umesto LC Power 6650 ( izgleda da je oslabilo napajanje), tj zamenio sam im mesta
Šes'
Nemojte se plašiti da promenite napone na grafikama, skinuti bios sa grafike, promeniti ga i vratiti nazad je posao pd par minuta.
Ako nemate vremena/strpljenja da tražite zlatnu sredinu, oborite na malo veće vrednosti.
Kod mene sam stavio 1050mv za Asus 270X,1080mv Asus 280x i 1088mv za Sapphire 280X DualX
sigurno može još dole, ali za sve ostalo treba vremena, bolje da bude ovako, nego da radi na defu.
Kad budete imali volje, krenite sa traženjem zlatne sredine
@smith_bre 992-1250-1068 na tim podesavaljnima ti radi moja dualka 280x ( i to mi je savetovao neko sa foruma )
To jest radila je dok nisam presao sa LTC-a na dark coin :D Sad nemam pojma koja su podesavanja , znam da se ne moze ugrejatia ventilatori se ne mogu cuti tako da me ni ne zanima :p
Ima li mozda neko ideju gde mogu da nabavim 2 x kbli na slici ispod, ili neki slican koji moze da sluzi istom, inace kabli je od napajanja Raidmax 835 W. Napajanje je bilo preoptereceno pa su nagoreli kablovi, sada se greju non stop.
Pozz
Pogledajte prilog 139131
ljudi jedno semi-noob pitanje
ako pretp da si spustio vddc na neki idealni nivo za odredjeni br core i mem clock-a, koja je opasnost (ne bukvalna opasnost vec vise tipa pucanje drivera posle sat dva rada) ako se poveca intenzity npr sa 18-19 (pricam o 7850 i 6950 karticama ako je to bitno) dal to dugorocno na neki nacin steti karticama? (posto se dobija nesto malo vise khs-a)
