Kritika, sta si na kraju uradio sa tim problemom? Jel koristis LAV filtere? Meni ovo ipak ne resava problem kada sam sve proverio i podesio... Mnogo je tise, bar 50%, a filtere i sve ostalo sam podesio kao ranije, samo sto su nove verzije filtera i pot-a.
Valjda bolja komunikacija graficke i player-a.
http://forum.doom9.org/showthread.php?p=1426681#post1426681In exclusive mode madVR has full control over the GPU and does not need to share control with the OS or other applications. The main benefit is that frames are switched by a GPU hardware interrupt exactly during VSync hardware events. That guarantees that there's no tearing. In windowed mode, madVR has to share control with the OS and other applications. Frame switching is done by actually copying the the new frame over the old one pixel by pixel. That is still done by the GPU hardware, but it's more time consuming and there's no guarantee that there's no tearing.
Ja u principu vise volim 64-bit programe da drzim. I sve sto ima u toj varijanti radije koristim.
U profilu mi pise X2=4GB.
Problem imam samo sa madVR, koji ocigledno nema 64-bit varijantu i s toga ne moze da radi u 64-bit Pot. Kao sto uostalom ne rade ni 32-bit kodeci.
Mene je samo interesovalo da li moze da radi madVR na 64-bit Pot. Kodeke imam instalirane, i sve mi i radi. Doduse, mozda ima i neki bug u Pot 32-bit, pa da madVR nece kod mene.![]()
