Litecoin [LTC] (scrypt)
Ma bezi bre na coinotronu mi je stale 2.5% a na litepool je 0.025 % stale .
Jos jedna preporuka za litepool, na coinotronu sam imao negde oko 4-5% stale, a na litepool-u na oko 900 shareova imam 1 stale, sto je 0.0011% :) i jos je 2% fee, a na coinotronu 5%.
upregao sam i haswell-a da malo radi, upravo mi stigla verzija sa avx2 optimizacijom koja donosi 100% ubrzanja tako da jednicak i5 na stock-u daje 80Khs
original minerd 2.3.1
2013-07-05 00:16:55] thread 0: 178092 hashes, 11.12 khash/s
2013-07-05 00:16:55] accepted: 13/15 (86.67%), 43.71 khash/s (yay!!!)
2013-07-05 00:17:00] thread 3: 646380 hashes, 10.78 khash/s
2013-07-05 00:17:18] thread 2: 650544 hashes, 11.00 khash/s
2013-07-05 00:17:23] thread 1: 658044 hashes, 10.90 khash/s
2013-07-05 00:17:26] thread 2: 86124 hashes, 10.76 khash/s
2013-07-05 00:17:26] accepted: 14/16 (87.50%), 43.56 khash/s (yay!!!)
2013-07-05 00:17:45] thread 1: 242184 hashes, 10.73 khash/s
2013-07-05 00:17:45] accepted: 15/17 (88.24%), 43.39 khash/s (yay!!!)
haswell 2.3.2 alpha1
[2013-07-05 00:19:29] thread 2: 1000176 hashes, 19.57 khash/s
[2013-07-05 00:19:29] thread 1: 1000176 hashes, 19.55 khash/s
[2013-07-05 00:20:28] thread 1: 1173264 hashes, 19.86 khash/s
[2013-07-05 00:20:28] thread 2: 1174104 hashes, 19.66 khash/s
[2013-07-05 00:20:28] thread 0: 1212264 hashes, 19.84 khash/s
[2013-07-05 00:20:28] thread 3: 1188888 hashes, 19.70 khash/s
[2013-07-05 00:21:00] thread 2: 626952 hashes, 19.87 khash/s
[2013-07-05 00:21:00] accepted: 1/1 (100.00%), 79.27 khash/s (yay!!!)
Hej ovo uopste nije lose. Ima li neke optimizacije za Ivy? Ivy i7 trenutno pljucka 56 khasha sa 6 aktivnih threadova...
To je veravatno to, ovaj je bez AVX2 bacao ~40 sa AVX, znaci i7 haswell bi verovatno bacio ~110kh/s
AVX2 je dosta unapredjenja doneo, takodje moze da gura u jednom ciklusu sto je ivy gurao u dva i vise
poslao mi autor, za sada je u fazi testiranja bice javna na forumu za koji dan, ali radi samo na haswell-u
E to mi se vec dopada. Sad imam zvanicno opravdanje da se ratosiljam ovog djubreta od ploce - uzimam 4770k i Z87 ^_^
Za sve one koji imaju problema sa pokretanjem ltc minera (u ovom slucaju reapera, mada vjerujem da vazi za sve) koristite atiman uninstaller 7.0.2 za brisanje svih drievra iz kompa, driver sweeper i amd cleanup until ne izbrisu sve kako treba i uvijek ostane ponesto sto blokira rudarenje (kao u mom slucaju).
Znaci izgubio sam 3 dana pokusavajuci da podesim reaper, cgminer i ostale minere kako bih poceo da rudarim na nekom ltc poolu ali uzalud.
Atiman uninstaller je lak za upotrebu, sve sto trebate je da ga pokrenete i pustite da sve sam odradi.
Kada sve zavrsi, nemojte restartovati pc jer vam onda ne gine reinstalacija istog, nego poslije zavrsetka atiman uninstallera instalirajte driver koji zelite i srecno rudarenje. ;)
Pokušao i ja (eksperiment) sa mojom konfom da kopam :d al sam stalno imao crash cgminera. Želim da se zahvalim :Klanjanje:Klanjanje:Klanjanje jer sam već skoro digao ruke. Nakon ovoga sve radi kao podmazano. :eyebrows:
Kako da povučem LTC sa cointorona? Stavio sam auto na 15ltc ali danas se nakupilo skoro 16, a ništa nije otišlo na adresu pored, odnosno na btc-e
isplacuju na svakih pola sata mislim, ako nece da prebaci pisi suportu
Do sada su radile isplate. Danas coinotron zeza opasno, ceo dan bukvalno.
Edit: Ne znam za vas ali upravo sam povukao 56 LTC-a sa coinotrona, sljaka sve normalno. Probajte opet to.
To i mene muci kako je najbolje poslati LTC i gde na koju menjacnicu sa coinotrona
Rade isplate na coinotronu ali dansa nesto usporeno, treba im 2-3-4 sata da isplate. Samo strpljivo ljudi.
ne znam u cemu je problem ljudi , jer ja kako sam procitao ovde da nesto zeza na cointronu probao da posaljem neku kolicinu i ono mi je stiglo za 10 min, sve radi najnormalnije, bar kod mene
Ovo jos nisam video, 4 dana a jos uvek nema bloka sa 50Mh na litepool.in . Vlasnik pool-a je ponudio 10ltc-a za nadjen blok.
Current Round Shares
Pool Valid: 8214541
to ti je isto ko neka krava ko daje 12 litara mleka ali ponekad zna da isturi lonac i sve da ide u nepovrat :D
ljudi dajte podesavanja za coinotron, nesto nece da radi nikako.
kopam preko reapera i stalno mi izbacuje error with server: stratum..
Reaper ne radi na stratum-u. Koristi mining_proxy (za reaper) ili cgminer.
Taj litepool vise ne radi nego sto radi!! Par puta sam mu davao sansu, ali definitivno sam digao ruke od njega pa neka darko i ostali koji se kunu u njega pricaju sta hoce!!
Ni kod mene ne radi dobro danas, tj ne radi lepo od onog kratkog prekida...kartice mu umesto 370 i 490 khash koliko imam na coinotronu, na litepool-u ne prelaze 310 i 440 khash, pritom uz konstantne prekide na svakih minut dva...odustao i vratio se na coinotron...
Mislim da nije fake.
