http://forum.benchmark.rs/showthrea...-arhitekturi&p=3268152&viewfull=1#post3268152i kad izlazi zvanicno nova serija procesora? kad je launch date?
Nisam očekivao, dobro su odradili grafiku.
Nista znaci nisam izgubio sto sam uzeo Ga Z77 UD4 i Ivy. Sad mi je lakseNisam mogao da cekam mesecima jer su komponente za hackintosh... Lep pomak sto se tice mobile spravica, ali ne i za desktop... Cak je sve sintetika i nema nigde real life poredjenka Ivy vs Husswell. Ovaj review je pokusaj da se opravda mizeran increase u performansama, vidi se iz aviona.
From the hardware enthusiast perspective it is going to be very interesting to see what retail purchased processors give us clock-wise in the wild. With Sandy Bridge and to a lesser extent Ivy Bridge, you could pretty much go buy that 2600K or 3770K processor and know you are going to bang out a solid 4.6 or 4.7GHz without a terribly expensive cooling solution on a decently priced motherboard. With everything I am hearing now about Haswell, 4.6GHz is sounding kind of dicey without less than $100 invested in a cooling system. If you purchase a Haswell and overclock it and find out 4.4GHz is pushing it for your particular processor, well then your gains from Haswell's superior IPC will be lessening quickly.
From gaming enthusiast perspective quite simply your hard earned hardware dollar is better spent on a new video card or display. (Or SSD for that matter.) While certainly CPU clock speed comes into play in the gaming arena, the games we play are largely GPU limited and most of you reading this already likely know if you have "enough" CPU for gaming. Or you likely know you are few CPU generations behind and already know you will greatly benefit from a CPU and motherboard upgrade.
Ajde sad ovi hardwer masturbatori koji su ovde govorili na sav glas kako treba da sacekamo rezultate, pa kako eto unapredjenja u arhitekturi su znacajna, te platforma, te energetska efikasnost i slicne marketinski kontaminirane bajezgarije, recite nesto sto ce biti na tragu inteligentnog zivota!
Jedno je jasno, ko ima SB procesore, nema razloga da prelazi na IB, pa sad nema ni na HW. Za mene najbitniji PS i LR, ukupno poboljsanje od SB do HW za ova dva programa je max 10-12%, u proseku 7%.
Ali dok je ovaca, vredne ruke radnika sto ih sisaju bice nezamenjive! :d
Zašto stotine evra? Ako prodaš stare komponente, koje i dalje imaju dobru cenu, i kupiš novu platformu, dobićeš 3-6% poboljšanja za 10% više para. Što je i logično, jer odnos cene i performansi nije linearan, sa razlogom.Neko ko odluci da u ovakva vremena zarad 3-6% poboljsanja baca stotine evra na apgrejd
^ koliko sam ukapirao DDR3 je za Hass... ne jos uvek DDR4
Stvari treba nazivati pravim imenom a ne kao ova poboljsanja ce nekome znaciti.. Kome i za sta?
Svedoci smo da svaka nova arhitektura donosi manje poboljšanje u performansama nego što to većina očekuje. Ali to je u redu, pošto su današnji procesori dosta složeniji i potrebna su unapređenja u mnogim delovima čipa. Tebi je možda za Far Cry 3 svejedno da li imaš SB, IB ili Haswell, ali nekome je mnogo bitnije trajanje baterije na laptop-u, ili da intelova integrisana grafika može da zadovolji sve potrebe.
ne sendi je kevaIvy je ipak keva , sigurno ce biti unapredjenja ali ne vrednih da se menja ceo HW... S tim verovatno cu ostati na ivy ju do neke sledece generacije ... prezadovoljan sam ivicom i za divno cudo meni je hladan kao spricer. :-D
