kondenzator
Misli na PunkBuster, ali kako se updatuje manuelno?
http://www.evenbalance.com/index.php?page=pbsetup.php
more ovako
Imao i crash to desktop
Meni se tu desilo da su me ostavili i otisli dalje...
Ja pucao na te na mostu i kad sam skontao da ovih nema nisam mogao da ih nadjem nego sam uspeo da napustim boljno polej
Nisam skontao putic kroz most koji vodi da ovih.
TL;DR: Ne.
Koliko imas fps-a u mp ?radi odlicno na high...Samo danas me nesto zeza,opada frame...
Ostala grafika na ultra,pa zato...Probao sinoc na ultra bez AA i onih djavola...Izgleda da sinoc nije ni promenilo podesavanja,mozda sam zaboravio da restartujem igru... :wall:
Yesterday AMD sent us a benchmarking guide for Battlefield 3 written by Antal Tungler, AMD's PR Manager. In the guide, Antal recommends using Nvidia's FXAA instead of MSAA.
"You'll notice that we recommend the 'Ultra' preset in lot of our scenarios, without the use of MSAA (Multi-Sample Anti-Aliasing). This is a traditional technique to remove aliasing from objects in the visible scene. It provides significant image quality improvements, at least in most cases. But because of its nature, working only on actual geometry, some objects will not benefit at all from this process, like foliage or fences, that are just textures, sprites etc. Luckily DICE implemented a new technique as well called FXAA (Fast Approximate Anti-Aliasing), which is a process that works pretty much on all objects. Another significant difference between the two is that while FXAA has a very small impact on performance, however using MSAA can essentially cut your framerate in half.
Ljudi instalirao sam manuelno PB i odradio update sad cim udjem u igru izbace me sa servera,jel ima neko taj problem?
Ja sam imao,i onda mi padne na pamet da iskljucim PB u igri i od onda nema problema!
Kakvo zlo su oni montirani AA topovi na aerodromima.
Vehicle disabled ribboni se ređaju kao na traci
Nisam nešto oduševljen mapama.
Mislis oni u samoj bazi koji su nepokretni?Ili oni kao tenkici koje vozas i rokas?
Kad nisi lepo uzeo nVidia zver iz NS-a![]()
