Windows 8
Sa twittera: "you will not need a LiveID to download the Windows developer preview.", ako ce samo trebati live id onda bolje to nego cekati torrent 🙂
pa da, public release je 😛 kao sto sam i govorio ovih dana -.-
nego...u ovom developer preview buildu nece raditi app store(naravno) ali ni mestro style apps....
The preview build does not include every feature shown this morning. Shown but not in the Developer Preview release include the Windows Store, Windows Live Metro style apps, and some of the user interface features. The focus of the preview is the API and development tools for building Metro style apps.
LINK
edit: a evo i linka gde moze da se skine, novi dev centar: http://msdn.microsoft.com/en-us/windows/home/
Znaci oko 5h ujutru ce biti dostupno, potvrdjeno da je free za sve i bez aktivacije 😉
Win7 je prodat u 450mil komada, a win8 izlgeda ce biti jos prodavaniji jer ce doci na vise platformi. Valve'u se sigurno nije svidela vest da Win8 App Store nece uzimati proviziju na prodate programe [za razliku od Steam-ovih 30%].
Da li to eventualno znaci i portovanje xbla igara da mogu da se igraju na pc-u? To bi takodje bilo odlicno posto vec pucaju na xbox live...
Pocev od App Market-a pa preko bling bling kampanje za user-dumb korisnike... Vrlo vesto iskopirana filozofija koja daje rezultate ($$$).
Hmm mozda si u pravu, ja sve te stvari uopste ne gledam, pa nisam ni primetio 😀
Ne slazem se sa logikom da daje (ili da im trebaju) rezultate/i ali ajde, nije to tema 😉
Ocekujem da ce MS-ov server ponovo iskusiti krah slican kada su pustili Office 97 update pack 😀
http://www.winrumors.com/windows-8-xbox-live-ui-is-identical-to-the-new-xbox-dashboard-pic/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+WinRumors+%28WinRumors%29
Larry Hryb (Major Nelson) revealed the interface in a blog post on Tuesday. Microsoft’s Xbox LIVE support in Windows 8 includes features like Achievements, Multiplayer, Avatars and Community and brand new ones like roaming storage and profiles. Microsoft revealed in June that the company plans to integrate Xbox LIVE support in Windows 8 but it’s not present in the developer preview build handed out to attendees on Tuesday.
u oktobru izlazi public beta
informativno stivo: http://www.istartedsomething.com/
edit:
streamovanje - audio i video http://www.microsoft.com/download/en/details.aspx?id=27412 - ima .doc fajl u kom je sve objasnjeno
The Windows Developer Preview introduces a number of new APIs to enable Play To and home media sharing experiences in Metro style apps. This white paper provides an overview of these new APIs along with some examples and guidance on how to enable Play To and media sharing in Metro style apps.”
http://www.istartedsomething.com/20110914/short-some-of-what-microsoft-didnt-show-of-windows-8/
Here are some of the most interesting ones I could read legibly from the text.
Integrated load balancing – if you have multiple active network connections, Windows 8 will intelligently balance the network traffic between them for performance
Stereo 3D video and gaming – would suggest native support for stereoscopic display output too
Easy discover apps that support a language – would suggest Windows Store will allow browsing by language
Filter apps that are accessible – similar to above, for applications that are accessible
Start background – there will be the ability to change the Start background (not possible in developer preview)
Create Live ID in Windows OOBE – users without Live IDs will be able to create one at the Windows setup
Phone as Smartcard – the ability to use Windows Phone as an authenticator for login?
Communication over SMS on my PC – the ability to send and receive SMSes?
Native support for WIMAX and LTE
Isprobao i deluje zanimljivo, videcemo kako ce to sve da izgleda u finalnoj verziji.
Kako se instalira , jel kao i win 7 ili ?
Još nisam isprobao win 8, ali da li mi neko može reći koji je fajl sistem u upotrebi? Da li je protogon ili NTFS?
Smrc 🙁 DP ne radi na VMWare-u 🙁
Da, to su već rekli.Ali zato na VirtualBox-u radi bez problema.
Izasao je VM 8 pa probaj..
instlirao sam developer preview, i wow ! :O
kad se bootuje pc, nema desktop u app switcheru, tako da se bas ne loaduje klasicni desktop 😀 sve dok se ne pokrene neka klasicna aplikacija, text i slika izgledaju malo cudno...
mislio sam da mi se ne svidja ovaj novi Start, ali prelaz ismedju starta i klasicnog desktop je tak dobro uradjen !! i vidi se da ce jos dosta da menjaju desktop UI, procitao sam na nekom blogu da ce taskbar ceo biti crn....
zar nisu rekli da ce onaj docking aplikacije sa na levu ili desnu stranu biti iskljucivo za 16:9 displaye, ja imam 16:10, i radi....
ali ovo je tek alpha verzija !! O_O finalni prozivod ce biti pravi pogodak, ne znam kako mogu da omanu sa ovim.
Jos 50 minuta do zavrsetka download-a 🙂 Steta sto ne moze VMWare nije kompaktibilan....
Meni jos 2,5 sata. Nisam uspeo na faxu da skinem, pa se sad patim.
I ja se patim sa brzinom od 250KB/s... Izgleda da je poveci udar na servere s obzirom da je se nocas vuklo oko 30KB/s (procitao na jednom forumu ) 😀
Na fakultetu je skidao sa brzinom od 7-8 MB/s. Probao sam tri puta, ali svaki put mi je pri kraju javljao da nemam vise mesta, iako imam vise nego dovoljno. Skidao sam direktno na externi, sad da li se problem javio zbog toga, nisam ispitivao.
Sad, kod kuce, i meni skida sa oko 480KB/s. Cesto nesto manje, jer usput slusam neki online radio.
