Sony Playstation 3 hack tema
  • Začetnik teme Začetnik teme xWoLf
Ma ima tu negde znam da je on orginal :d
Instalirao sam wutangrza CFW i geohot i gaia manager na Fat 40 gb. Na internet nisam isao i necu nekako mi je krivo sada da furam pirate i jos igram im na netu.
Samo eto filmovi ne mogu da se vrte(orginal i pirati) i ne znam da li mogu PS1 igre da se vrte .
ima na TL celo uputstvo kako da se stavi CFW 3.55 - i ne zahteva nikakav USB, djuntu i sl.
pazite sa tim custom/modified firmware-
zeznete li ps3, mocicete da se slikate s' njim
u srbiji tesko da cete naci nekog sa potrebnom opremom za ozivljavanje brikovanih ps3
samo da se zna, nisam odgovoran:
Kod:
Step 1:
Make sure you're on the official 3.55 Firmware, you can check this by going to your console, under the settings part of the XMB > System Settings > System Information and making sure it says 3.55, if it infact does state you're on the latest firmware, you may proceed to step 2, otherwise read below.
If you're on an earlier firmware, you will need to either upgrade to 3.55 via Internet or from your external USB drive, to do this you will need to do the following:
- Take your external USB device, create a folder "PS3".
- In the folder "PS3" Create a folder "UPDATE".
- Then paste in this folder "UPDATE" the downloaded file "PS3UPDAT.PUP".
- Connect your external USB device to the PS3 (The ps3 must be not jailbroken at this point).
- Select (Settings)> (System Update).
- Update.
Step 2:
Now, you're on 3.55, we will be wanting you to install a Custom Firmware to allow the running of all the games via the TorrentLeech PlayStation 3 section. First of all you will need to download the "Kmeaw 3.55 Firmware" which is a 100% safe update file and the current best custom firmware that allows you to install unsigned homebrew and use backup managers to load the actual games up.
To install this on your official 3.55 console you will need to do the following:
- Take your external USB device, open up "PS3".
- In the folder "PS3" Open up "UPDATE".
- Then delete the old PS3UPDAT.PUP and paste in this folder the downloaded Kmeaw custom firmware PS3UPDAT.PUP from above.
- Connect your external USB device to the PS3.
- Turn off your PS3 from the back or plug.
- Hold down the PS3 button, it will light up green and make a few beeps, this is safe, it will take about 15 seconds to power the machine back off again.
- Hold down the PS3 button after the console light is red, it will beep once and then it will beep two times, it is now safe to release the button.
- You will now be in recovery mode, plug in your controller with the USB cable and press the PS button (Check THIS picture to make sure you're in recovery mode).
Kod:
- Click on the "SYSTEM UPDATE" and press Start + Select at the same time, it will automatically install the custom firmware you placed on the USB stick.
Step 3:
Your console should have restarted after the update and you'll notice under "Game" section that you have two new options, "* /app_home/PS3_GAME/" and "*Install Package Files" let me briefly explain what these options do. The * /app_home/PS3_GAME/ is a redirection of a bluray disc, so when you load up a game via the Backup Manager without a disc inside the console and hover over the * /app_home/PS3_GAME/ you will see the game and be able to load it (Not every game supports disc-less booting) and the * Install Package Files will install those unsigned or signed .pkg files e.g. Backup Manager, lv2 patch, Emulators, etc.
We will now install a FTP server which will be the application you use to transfer games over from your PC to your PS3's hard drive, first download THIS application which is Blackbox FTP Server 1.2, you will need to do the following:
- Take your external USB device, unzip the rar on the ROOT of the drive so that blackbox.pkg is on it.
- Plug your external USB device into your PS3, go to "Game > * Install Package Files" and clicking on it should bring up the pkg you put on your USB drive.
- Click X on the PKG and install, it should now appear on your XMB under "Game" ready for you to launch.
We now want to take the same steps above but this time, installing your Backup Manager instead, which is the program that loads ALL the games that are downloaded from TorrentLeech.org and other websites, download the Backup manager from HERE and take the steps installing it as you did with your FTP server, this backup manager includes lv2 syscalls, no more need for the lv2.pkg.
Step 4:
So you now have all the tools, patches, firmware ready to start running your backups / downloads, you will firstly need to start up your FTP server on your PS3, it is a good time to connect your console through wired (don't need to have the internet running, just PS3 > PC) and to upload your games you will need to do the following:
- Open up FlashFXP or any other FTP client you have on your PC.
- Connect to the IP address that the PS3 is connected too (Upon opening Blackbox FTP server, it will say your Ip address in the middle).
- Navigate through the PS3's hard drive to "dev_hdd0/GAMEZ/" this is where you will place your backups, you may have to create this folder if it's your first time.
- You will be uploading the TITLEID folder to dev_hdd0/GAMEZ/ so e.g. dev_hdd0/GAMEZ/BCES00569 which would be Gran Turismo 5.
- Congrats! You have now backed up your first game.
Step 5:
So you now have a game uploaded which your Backup Manager will automatically detect, you firstly want to run the LV2.pkg which you installed, which on your XMB will say "lv2 patcher" and have a image of omg omg omg lv patcher, this will launch and direct you to a white screen telling you "Success" and pressing X to exit, do this.
You have now patched your console with the syscalls necessary to run the backup you uploaded. Now load up your Backup Manager, you might have to agree to a few notices but that is all good. You will now see your game listed in the Backup Manager, just hover over it and press X to launch it. You will be thrown back to the XMB and notice that if you HAVE a blu-ray game in, it will be replaced with the game you launched from Backup Manager, if you DONT have a blu-ray game in the console, you will have to scroll over "* /app_home/PS3_GAME/" which if you press X on, will load your game (Note that disc-less mode supports less games than having a disc in the console.)
Congratulations you are now jailbroken, have peek/poke and lv2 patched, backup manager running and game backups working, enjoy!
NOTE:
If your games are blackscreening, use THIS pkg to fix permissions everytime you upload a new game.
- Upload 3 games
- Run fix permissions
- Upload 1 more game
- Upload 24 games
You only need to use the fix permissions everytime you upload a game or several, it doesn't need to be ran everytime you boot your console.
linkove namerno nisam ostavio, ipak necu da forum ima problema, a ni ja 🙂
Resio sam problem sa Blu-ray i dvd filmovima. Kada upalite konzolu ne pokrenete LV2 patcher i to je to
Samo da javim da je sve proslo kako treba i da ne treba da brinete oko instaliranja custom firmware-a jer je apsolutno bezopasno ako pratite instrukcije koje je Iznogood dao, ili druge instrukcije koje nadjete. Imao sam vec 5,6 igara na hardu a trenutno sam prekopirao Mafiu 2 na sonijev hard, posto sam poceo nju poceo da igram kad sam bio u Nemackoj, red je da je zavrsim. Uncharted 2 obrisah greskom kada sam danas uninstalirao backup manager, zaboravio sam da brise i folder GAMEZ gde su bile igre na hardu... tako da to moram opet nocas da skinem.
Ja sam bio strpljiv i ustedeo pare koje bi dao na jailbreak, jer je ovo kad tad moralo da izadje. Online jos nisam probao ali verovatno radi. Sto se tice banovanja sa PSN-a, vreme ce pokazati da li ce Sony preduzeti nesto povodom toga. Sve u svemu, ja srecan.
drago mi je da sam pomogao. meni nije zao za djuntu, jer sa njom mogu da odradim i FW downgrade, ako negde nesto zapne 🙂
dobra ti usteda,u pola godine nekih 13e si ustedio 🙂, instalirah na jos 6-7 ps3,radi ekstra, ponekad kad izadjem iz igre ili ovako random blokira al nije cesto
jel ti se pojavi crn ekran? posto bi trebalo da se sa nekom pkg aplikacijom odradi fix permissions everytime you upload a new game
i to svaki put kada se uploaduju nove igre (ne mora za svaku pojedinacno).
znam za to,radio sam,al svakako su mi igre na externi pa nema veze.Nego jednostavno zablokira sve,npr jednom kad sam krenuo da se logujem na psn i par puta dok sam setao kroz xmb. Do payloada je to, al mi ne smeta mogu da zivim sa tim 🙂
Da li to znaci da sa ovim kmeaw CFW mogu da se igraju sve igre? I one koje jos uvek ne rade na Hermes v4b + 3.55 spoof?
pa rade i sve igre koje valjda traze 3.5+ FW... bez nekog zezanja
Ja imam problem da mi nishta zivo ne radi 🙂 Update je proshao normalno i mogu da instaliram razne managere, ali jedini od njih koji radi ja Gaia. Multiman startuje, vidi igre, ali kada neku od njih odaberem, u XMBu nemam gde da je startujem, ubaceni disk se zove onako kako se stvarno i zove 🙂 Drugo, sa externog harda od 10ak igara ako radi jedna, a sve su radile ranije sa Open Managerom i JB stickom. Takodje, prebacio sam Uncharted 2 na interni, startovao ga, uradio je update, i evo 5x zaredom mi je blokirao u toku uchitavanja ili na samom meniju, igru nisam uspeo da vidim.
odradio si ono fix premission?
ne znam koje su sve mane. koliko vidim, ljudi su uglavnom zadovoljni.
mozda je ovde problem sa igrama:
the games that i get the black screen on, are the ones with the modified eboot.
gt5, nfs etc.......
If you get black screens, or random crashes when using the backup managers and you were previously jailbroken on 3.41, try deleting your backup manager and reinstalling fresh
If you get black screens or lock ups when running older games and you patched the eboot or param.sfo, restore those to the original unpatched versions
Delete any 'game data' for games which were played with older jailbreaks - this data may not be compatible with the new CFW
Samo da pitam nesto, mi koji imamo ps3 sa 3.41 jel da ga updejtujemo na 3.55 ili ne? da ostanemo gde jesmo ili je ovo nesto bolje na 3.55?
dokle god ti sve radi na 3.41 sa djuntom, ne diraj nista...
"Mujo, narani svinje i ne pipaj ništa!" 🙂 🙂 🙂 Baš tako, sve dok se ne stabilizuje situacija sa homebrew FW .....
Jedina prednost na 3.55 je to sto ti radi PSN opet i mozes online da ides, i to sto ne moras da plugujes djuntu jer ti je sve "na tacni". Ako budu krenuli da banuju, morace da banuju milione ljudi. U najgorem slucaju ce banovati PSN, a uvek mozes da napravis novi.. Ne bi se usudili da banuju konzolu jer nemaju koristi od toga. Time bi izgubili pola korisnika, i obeshrabrili bi ljude koji planiraju da kupe ps3 koji nameravaju da hackuju= gube $$$. Te pare koje su "izgubili" na tome sto ljudi vise ne kupuju originale ( a mnogi jos kupuju ) su nadoknadili time sto im je povecana prodaja konzola. Sony srecan, mi srecni.
Imaju tri opcije, prva je banovanje, druga je besomučna trka fw-ovima sa piratima i treća uvođenje serijskih brojeva na originalima koji bi se vezivali za PSN, time ne bi sprečili pirateriju (eventualno online igranje), ali bi te pare izgubljene kroz pirateriju vratili srpečavanjem prodaje polovnih igara.
Znaci docekasmo cheatere i aim botove i na PS3 🙂 A jadni geohot i ekipa su samo hteli da pokrenu Winamp na Sondzi 🙂
