fenomenalno!!!
daj malo informacija o monitor setupu! Koristis neke adaptere?
Sada uz novije ati grafike sve je mnogo lakse
Izvrti bench svih igrica sto imas, ako moze 1/3 monitora da vidimo koiko se gubi
Evo ti jedan jako dobar forum za samo to, mozes svasta da saznashttp://www.widescreengamingforum.com/forum/
uzivaj![]()
I ja planiram slican setup sa 1xAsus MW221 + 2xLenovo L2251p (ili x) samo da ispregovaram sa zenom gde da ga smestim![]()
I have three monitors, all the same but for some reason Bezel Compensation was not an option.
Not wanting to mess with flashing my monitors...
I did a quick search in my registry and found this gem of a key:
Code:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ATI\ACE\Settings\Graphics\BezelSupported
"Accessible"="Nobody"
Now I know what youre thinking...it CANT be that easy...
But, IT WAS...
I changed the Nobody value to Everybody...and I now have the option to Add Bezel Compensation on my display group.
For those of you less computer/registry savvy, here's the quickest way to make the change:
copy the contents of the following code into a new notepad file:
Code:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ATI\ACE\Settings\Graphics\BezelSupported]
"Accessible"="Everybody"
Save the file as BezelSupportForce.reg(or anything as long as it has .reg, be sure it's not .reg.txt)
Then double click the new file and hit Yes when asked if you want to continue.
I hope this helps...Really curious to know if it works across the board or just on x64 systems.
Cekaj Prijatelju,sve ovo radi jedan Radeon 5850?
Ekstra izgleda, perforamnse su ok s obzirom koaj je rezolucija aj probaj Crysis![]()
Da samo jedan 5850.
Naravno i crysis, nego sam zeznuo diskove :S:, ali trebalo bi da na high bude average oko 30fps.Za njega bi bas legao onaj 6870cf.
Ja kapiram da je mnogo dobar osecaj stvarno igrati na 3 monitora ali je 3 puta bolje za relly voznje i simulacije letenja nego na drugim igricama, tek na tim igricama vidis koliko je dobar trip Eyefinity.
Jer to Samsung P2450 u sredini, kakav je???????
