NBA 2K11
Sa kim igrate NBA ligu? Ja ne mogu da se odlucim izmedju Bostona, Majamija i Chikaga...
Te ne bih uzeo ni da mi plate. :D
2K Sports Has Already Approached NFL About 2K13 Licensing Deal
It looks like everything we had been hearing over the last year and half has turned out to be true as word is now coming out that Take-Two Interactive, the parent company of 2K Sports, has approached the NFL about a licensing deal for the 2013 NFL season. It was rumored last month that the NFLPA, the official association representing players of the National Football League, were already in preliminary talks.
While nothing solid has been worked out, all the pieces are falling into place. Take-Two has sold of several major assets - including their mega-distributor JOAG in Cincinnati, Ohio in order to raise capital. We'll keep you updated as the details emerge.
Uh kad bi uspeli da obezbede licencu,dosta je bilo onog smeca zvanog Madden.
Odigrao sam par partija, stvarno je dobar basket. Prilicno mi je tesko da se sastavim sa driblinzima i prodorima, jako tesko probijam sa igracima, treba dosta vezbe jer treba kombinovati analog i Clutch dugme. Free trening je jako koristan, ima lepo objasnjeno za sve driblinge, mada kad je utakmica sve zaboravim :D Prilicno sam bio dobar u 2k9, ovo mi je skroz drugacije.
Zato sto u 2K9 odbrana nije postojala,mogao si da se setas po reketu kako si hteo_Ovde malo teze.
Kakvi se ono prdezhi chuju tokom replaya? Znachi ja ne mogu da verujem, da li je to neki easter egg ili sta... koja smejurija. :d
Grafika mi je tesko njesra, uopste mi se ne svidja... Gameplay onako, mada sam odigrao samo 1 utakmicu pa i nisam jos kompetentan da pricam o gameplayu. Idem jos da se igram, pa se javljam sa jos utisaka kasnije.
Ja sam zapanjen da si to rekao i ostao ziv
Mogao si jos malo da povecas slova. :)
Sada sam jos igrao, i poricem sve sto sam rekao, igra razbija. :D
Btw, kako se rade finte?
Igram sa X360 dzoj. i mene zanima kako idu finte, pre dok sam koristio 'trougao' i krug' (PS2 navika:D) je fintirao tu i tamo a sad se ukopa u mesto
Sto ste toliko lenji,igra sadrzi opsiran tutorial.Udjete lepo u practice mode i tu sve pise.
Mali off! Da li je Michael Jordan ikada bio u Beogradu?
Pogledaj zadju zastavu na zidu, skroz desno
Ali kolko znam nije bio u Beogradu
Ne mogu da se odlucim izmedju Chikaga, LALa i Majamija nikako...
Ja volim da igram sa slabijim ekipama, evo sad se uvežbavam sa Washingtonom. :)
Kako dobar meč Barse večeras protiv Lejkersa :)
Nisam gledao utakmicu, ali sam iznenadjen rezultatom :) Nisam mislio da je ovo moguce :)
Odlican utakmica,Spanci su je prilicno ozbiljno shvatili.:d Sad ce da pricaju kako su dobili aktuelne NBA sampione.:d
Au ne verujem !!! :zgran::zgran:
Bravo za Barsu !
Dobro, Lejkersi nisu u takmičarskoj formi, dok Barselona jeste, ali svakako svaka čast. :)
Svaka cast za Barsu , ipak na neki nacin je ovo bila utakmica za naslov nezvanicnog prvaka sveta (nesto poput Toyota Cup-a u Tokiju gde igraju sampion Evrope i sampion Juzne Amerike).
Lejkersima ni ocigledna sudijska pomoc nije bila dovoljna. )ono je stvarno bilo sramta sta su sve tolerisali Lejkersima i kakve su smesne faulove dosudjivali Barsinim igracima)
Inace sano kosarkaske neznalice mogu biti iznenadjene ovim rezultatom.
Mislim realno Lejkersi imaju negde 3,4 odlicna igraca dok je ostatak tima manje vise smesan (tipa : Luk Volton, Braun, Barns, Blejk) dok kad pogledamo Barsin sastav vidimo da tu ima 10-ak zaista odlicnih igraca tipa jedan Navaro, pa jedan univerzalan "all round' igrac Mikel, pa Riki Rubio koji je najveci talenat u evropskoj kosarci u poslednjih 10-15 godina, pa recimo Fran Vaskez jedan eksplozivan centar odlican skakac koji pogadja i za 3 ako treba, pa zatim Lorbek koji je bio i MVP Evrolige , pa jedan odlican plej i suter Jaka Lakovic, pa N'Dong isto jedan odlican igrac u reketu sa izuzetnim odrazom i rasponom ruku.....mislim stvarno cak i malo koja NBA ekipa moze da se pohvali tolikim brojem vrhunskih igraca.
U svakom slucaju velika pobeda za Barsu (pa i za evropsku kosarku) ali ne i neko veliko iznenadjenje.
Uostalom setimo i da su vec jednom igrali Lejkersi i Barsa i to u Staples Centru pre godinu ili 2 dana i da je bilo 104-102.
Pa onda setimo se kad je Barsa pobedila i Filadelfiju predvodjenu Ajversonom i Iguadalom, pa onda kad je CSKA iz Moskve pobedio Kliperse sa 20 razlike, pa kad je Unikaha pobedila Memfis, pa akd je Real pobedio Toronto, pa zatim kad je i Makabi u 2 navrata pobedio NBA ekipe..........itd
Ali svakako da se sastanu Barsa i Lejkersi na vrhuncu forme, Lejkersi bi ih oduvali, nemojte da se zamajavamo, zna se kako se igra odbrana dok ne dođe playoff, a pogotvo sada kada je još predsezona. :)
Pa pazi sumnjam i ja da bi ih Barselona prosla da se sad sastanu u plej ofu ali sam svakako siguran da bi i tad dobro odigrali i uzeli im koju pobedu.
Stvarno Barsa ima odlican tim i tolikim brojem odlicnih igraca cak i malo koja NBA ekipa moze da se pohvali.............
Po meni u Evropi postoji nekih 6-7 zaista jakih timova koji mogu da pariraju NBA timovima ali recimo problem je u tome sto je jedan osrednji NBA tim ( tipa Milvoki, Toronto, Portland) daleko jaci od nekog osrednjeg evropskog tima (tipa ALBA, Ulker il tako neko)
Saglasni smo, mislio sam da imaš drugačije mišljenje, loša pretpostavka. :)
