G210 is GT218/D10M1 based using P690 and P691 PCB designs supporting DDR3 and DDR2 respectively. G210 has 24 shader processors clocked at 600MHz core and 1425MHz shader. G210 runs on 64-bit memory interface with 512MB DDR2/3 memories clocked at 800MHz. These cards will be priced very cheaply between US$30-35 replacing the current GeForce 9400 series.
GT 220 is GT215-300/D10M2 based and there will be 3 variants; P681 (DDR3), P682 (DDR2) and P680 (GDDR3). GT 220 has 48 shader processors clocked at 625MHz core and 1375MHz shader. It has 1GB memories onboard on 128-bit memory interface clocked at 800MHz. These cards are going to cost somewhere between US$55-60 and is going to outperform GeForce 9500 GT by much.
Yesterday, the Taiwanese rumor mill suggested that two desktop GeForce graphics cards with 40nm GPUs would launch in September. That was incorrect, apparently: information pages that correspond exactly to the rumored GPUs have already appeared on Nvidia's website.
To je samo za mobilni segment, ili će biti i za desktop??
I koliko to ima smisla za desktop?
To da, ali ubaciti ovakvu kartu u novu masinu je cisto bacanje para.
Pa integrusa ne mora da bude nvidia, znaci moze to jeftinije.Tako da po ceni ova karta za prosecnog korisnika (kome ne treba cuda dekodiranje ) je krajnje neisplativo resenje, ova karta ce kostati oko 30 eura, a za 60-70 eura moze da se uzme deset puta brza.
Ako hoces iole da se igras pa ti trebaju deset puta bolje performanse, to vec (po meni) ne spada u klasicni HTPC - lepo kupis konzolu i ne razmisljas
Ne bih se slozio 🙂, ne u smislu nekupovanja konzole, vec da je izvodljivo kao i bilo koji drugi "klasicni" gaming PC.
http://www.avforums.com/forums/home-cinema-pcs/989505-gaming-htpc-thread.html
Npr. E5200/X2550 i HD4770 bi bili idealni kanditati za relativno jeftin gaming HTPC. Naravno, moze i daleko vise od toga, sve zavisi od finansija.
Mislim da je to malo preskupo zadovoljstvo samo da bi imao PhysX u par igrica.Kako li rade fiziku ? Nema dodatnog napajanja, samo bocnes.
