Moze neko da me podseti, koji je zadnji AC za PS2?
steta sto nece izaci za pc
Da budemo pošteni, kenjuckaš po malo.
U MS FSu može skoro svako ko odvoji par popodneva da poleti, leti unaokolo i sleti. 90% pakla u modernim simulacijama je upotreba elektronike (radar, podešavanje oružja... bla bla...), zato je i IL2 bio tako popularan.
Par poslepodneva je jako puno, hocu da zavrsim igru za to vreme i da je izbrisem sa hard diska. Simulacija imate koklo hocete. Ovakvih igri arkadnih ima 4 od koje 2 valjaju. + Sto je neko rekao, zaista nemam nameru, afinitete, fetishe i sve ostalo da naucim kako se upravlja avionom i zatim pola sata ganjam jedan avion i sat vremena letim nazad u bazu. to mi je svo slobodno vreme koje imam
Hvala na razumevanju
kome je freespace simulacija? :d
doduse ima svakakvih, neki su za AC6 rekli da je realan i vise od arkade
Ubisoft has just confirmed that a playable demo of HAWX will be released for PC on March 2, with the game's official website hosting the file from 5pm GMT.
The demo arrived on PS3 yesterday and has already been a huge success on Xbox 360, notching up over a million downloads on Xbox LIVE Marketplace.
HAWX is scheduled for release on Xbox 360 and PS3 on March 6, with the PC version scheduled to hit stores the following week.
The 1.3GB Tom Clancy's H.A.W.X. PC demo is finally available for download. Featuring two single-player levels, and no co-op multiplayer (as was in the Xbox 360 release), the demo will entertain you for at least twenty minutes.
Minimum System Configuration:
CPU: Intel Pentium 4 2.0 GHz/ AMD Athlon XP 2000+ or higher
Operating System: Windows XP (with Service Pack 3) or Windows Vista (with Service Pack 1)
RAM: 1 GB Windows XP / 2 GB Windows Vista
DVD-ROM: DVD-ROM speed 4x, dual-layer drive
Drive Space: 1.5 GB
Graphics Card: 128 MB DirectX –compliant, Shader 2.0– enabled video card
Sound Card: DirectX 9.0 – compliant sound card
DirectX Version: DirectX 9.0 or 10.0 libraries (included on disc)
Recommended & Preferred System Configuration:
CPU: Intel Core 2 Duo 6320 / AMD Athlon X2 4000+ or higher
RAM: 2 GB
Drive Space: 1.5 GB
Graphics Card: 256 MB DirectX 10.0– compliant video card or DirectX 9.0 – compliant card with Shader Model 3.0 or higher (see supported list)
Peripherals: Xbox 360 Controller for Windows
Ja skino probo grafika je ok radi perfektno igra i dobro je sto ovo moze da voza i pocetnik...
a oce moci da se igra na mojoj masini?
:d First!
