- Core i9 14900KF*Noctua NH-D15
- MSI MAG Z790 Tomahawk WiFi
- Corsair Vengeance DDR5 64GB 6400MHz
- Asus TUF RTX4090
- 2x 2TB Samsung 990 PRO NVMe M.2
- Corsair HX1500i
- NZXT H7 Flow
- Monitor
- LG Ultragear 27GS95QE-B, LG CX
Da, ta igra ima problem sa widescreenom.Ovdi je resenje 🙂
A na tweakguidesu, covek kaze:
As of the 1.1 Patch, there is now a 'Horizontal FOV Lock' option under Graphics Options which you can switch On or Off to control the Horizontal Field of View. If using a widescreen resolution, try changing this option to Off first to see if it resolve any FOV issues.
