goran.a
Ja skinuo sa ovog linka i javlja da sound neće dobro da raspakuje pa ne mogu ni da instaliram. Jel neko skinuo odavde?
Ma jok, izaso je SP demo, full igra treba da izadje u drugoj polovini novembra.
A ti gorane, zbog tebe umalo nisam odustao od kupovine novog racunara... ajde postuj rezultate sto pre. Nemoj kaciti screenove nego baci rezultate ko u postu #2083.
Inace probao sam demo na mojoj sklopociji, ide OK u 800x600 sve na LOW. Iz prve sam mislio da necu moci ni da pokrenem igru. :d
Nije mi jasno kao prodaju pricu su optimizovali za quad procesore, a ovde nisu mogli ni za najjacu graficku da optimizuju, koji lazovi.
Onda se zapitam stvarno koliko i u tome ima istine.
Da li si probao da "kosis" drvece.
Izaci ce neki tweak da ukljicimo "DX10" efekte u DX9 modu...,)
Just finished the installation via EA's little download program as I pre-ordered the game some time ago and am currently adjusting a few CFG files to see what can be adjusted as the files are pretty similar to the beta.
(If things work like the did in the beta I should be able to enable quite a few options including the "Very High" setting albeit that would most likely kill off this 7800GTX - Wish the computer in my signature was ready. )
There's also two batch files in the /Bin folder named "Benchmark_CPU" and "Benchmark_GPU", should help benchmarking.
EDIT: The multiplayer map "Shore" is included for some reason.
EDIT: All those annoying logo videos are located in the "InstallFolder\Game\Localized\Video\" - Bye.
EDIT: The .Pak files can be opened with Winrar, already mentioned this in the beta discussion though.
EDIT: EA made a mistake.
(Z_UI_SPDEMO.pak - The Z_ kinda stood out and after renaming the file the whole main menu was accessible, quite interesting but not really intended.)
EDIT: Fileshack has some download mirrors up of the demo, unsure if it's a accident or such.
EDIT: The "Very High" CFG hack works fine in DX9 albeit it would ofcourse look better in DX10.
(Basically you open the InstallFolder\Game\Config\CVarGroups\ folder and copy the [4] values over the [3] values - then select high quality in the options menu.)
(Had to lower resolution a bit but it still look good in 1280x1024)
EDIT: The -Devmode launch parameter can be used to gain full access to the console and other debug commands
Jel jos nekome trazi serijski prilikom instalacije?! Skinuo sam ovaj torrent. Jedino ako je fake :S:
Isto čoveče i baš sam se iznenadio, posle sam je bacio na 1024/768 sa malo povećanim shaderima i malo povećanim kvalitetom vode i dobro ide na mojoj staroj makini. Igra je veoma dobro urađena bar iz ovih pola sata igranja, poz odo malo da šibam ove Korejance.
Shader Quality izgleda najvise ima impakta na performanse ....
A zvuk je velicanstven ...
Procitao sam isto to negde oko shader-a na nekom stranom sajtu... Lik je isto imao GTX.
Sve na high je igrao i smanjio je shader-e na medium i dobio je osetan boost performansi...
Ako bas neces na medium, onda se pozabavi overclockom shadera pomocu nove Riva-e...
Na kojoj su ti rezoluciji bile one slike u DX9 i DX10... ?
Otvoris sliku, desni klik, pa properties
1680x1050, sa napomenom da su dx10 shotke uhvacene sa forsiranjem 16Q AA i 16xAF
