spaxon
Masik[emoji769] U 1.1 Beta Test (MIUI 10)
To je koliko sam skontao novi custom Miui rom (aroma installer) koji obuhvata skoro sve opcije sa Multirom, MiuiPro, MIUI Global, MIUI SU i ostalih...
Vidim u anketi na 4pda da ga rusi vec aktivno koriste i ima ~20% glasova...
https://drive.google.com/file/d/1T0_O-KKDZIDD0LA8GVOHekED71AjSNQE/view
Koristio sam google translate:
Описание Masik[emoji769] Premium
https://4pda.ru/forum/index.php?showtopic=892339&view=findpost&p=74462877
Android 8.1, MIUI 10 Beta
Built-in global Hi-Fi audio engine from Beats Electronics (to the global audio drive) and from Harman Technology (for processing sound MI-amplifier)
System optimization was performed, system parameters were adjusted for better system performance and responsiveness of the interface, the scenarios were modified and cleared of intermediate values
The application interface has been modified: Settings, Security, Themes, Browser, Phone, Contacts, Messages, Downloads, Desktop, Music, Themes, Explorer
Ads sources and recommended pages for applications have been removed: Security, Themes, Browser, Messages, Downloads, Desktop, Videos, Music, MI account, Mi Cloud
The functionality of the MIUI drain camera has been expanded (JPEG compression is disabled, new shooting modes are added, shooting with the screen off, noise reduction option, object tracking mode)
Removed Chinese applications, anonymous statistics collection and sending services, analytics and logging services, system update agents, Analitics Core and their dependencies
Added the ability to install firmware with Root access, integration of Magisk 16.0 + BusyBox (optional option in Aroma Installer during firmware installation)
Built-in minimal set of Google services with the ability to completely remove from the system (optional option in Aroma Installer during the installation of the firmware)
Added the ability to set the ad blocking file (optional option in Aroma Installer during firmware installation)
Extended or standard reboot menu (optional option in the parameters for the developer)
Original media content is replaced by author's (sounds of notifications, ringtones, wallpaper, butanimation, bootlovo)
Updated APN, SPN and operator settings to the latest versions at the time of firmware release
Built-in background blur (blur) in the panel of running tasks
Added the ability to enable / disable alerts on connecting / disconnecting the charger
Preinstalled regional applications, components and regional system add-ins were removed
Built-in 3 styles of desktop design in the "Themes" application (the preview of the styles is present)
Embedded in 3 styles of icon mask design in the "Themes" application (the preview of the styles is present)
Increased the maximum threshold of the volume of the speaker and the volume of audio in the headphones
Embedded 6 styles of system font in the "Themes" application (the preview of the styles is present)
Added the ability to activate the maximum screen backlight in a phone call
Added the ability to enable / disable the "Smart Assistant" on the desktop
Added the ability to enable game mode (performance mode)
Design of the system with the adjustment of graphic layers in the style of Super AMOLED
Added the ability to select one of the 3 animation styles of the system
Added the ability to disable notifications from running applications
Rounded corners in preview of running applications in Task Manager
Added the ability to disable (freeze) system applications
Built-in extended geolocation of phone numbers
A pop-up message is disabled when selecting the "3G only"
Improved quality of telephone conversations from the line
Built-in patch for Google Photos unlimited storage
Added ability to use all Wi-Fi channels
Signature and application integrity checking disabled
Added advanced settings for network type selection
Rounded corners of buttons and pop-up menus
Changed the style of pop-up and menu animation
Added option to configure A-GPS in the settings menu
Setting up a grid of desktop icons has been added
Added icons to the advanced settings menu
Reduced the threshold for issuing a message about the battery discharge
Enhanced Ipack (support for 5500+ applications)
Automatic closing of desktop folders
Reduced the minimum screen brightness threshold
Patched the theme manager
