CSC version: I8750OXAALL3
Current CSC: ATO
E bas to.. Evo i ja sam sad prebacio na ATO i upravo mi skida GDR3.. Ko hoce da proba..
Change directly on Samsung Ativ S method
The all members of xda-developers, and the author can not be held responsible for any damage to any of your devices after applying the following. Make sure to save all your data!
This method works for the Samsung Ativ S, (except the Custom CSC of @-W_O_L_F-).
And I think also that this method only works if the ATO region settings are integrated into the CSC. If this is not the case, please flash the ROM and the appropriate CSC using the Samsung ATIV S I8750 Rom flashing guide.
This method will require at least two reset, necessary for change the CSC. Then again remember, save all your data!
If between each reboot, you are prompted to reconfigure your Samsung Ativ S, it is not worth it until all the resets are completed.
Of course, will remove the μSD card if it is built into the phone.
In phone hub, dial, the ##634# code. So, the menu of Diagnosis app appear.
In the menu Diagnosis app, enter the *#321647335 code, to view/change the region code of CSC. Select the ATO code.
If you want to know more about region codes, then you can visit the blog ykkfive.blogspot.be.
The Samsung Ativ S, will reset.
Once, the change ATO made, search the updates.
Download and install all updates GDR3 proposed.
Once GDR3 installed, you can, if you wish, return to your old CSC, simply performing the inverse method.
In the Diagnosis menu choice CSC, choose your old CSC.
The Samsung Ativ S, will again reset.
You can now reconfigure all your content on the Samsung Ativ S with updates official GDR3 and your original CSC integrated.
