Huawei Nexus 6P
Baterija drži 2 dana 😀
Ma sve isto. Mislim sve je extra kao i prethodnih meseci.
Announcing the rollout of Android 7.1.2
Hey Everyone,
Today, and over the next few weeks, we will begin the rollout of Android 7.1.2 to Nexus 5X, Nexus 6P, Nexus Player, and Pixel C. This update contains a number of bug fixes, added features, and general performance/stability improvements.
A few changes and updates that we want to highlight are listed below:
Enhanced notification stability
Fingerprint swipe on 5X/6P
General connectivity improvements
Battery usage alerts
If you have any specific questions, feel free to post here in the community, and we’d be happy to help out!
Sve je po propisu, radi kao sat + aprilski security patch [emoji106]
Već izašao i FULL PIXEL MOD:
N2G47H 7.1.2
Download:
https://www.androidfilehost.com/?fid=673368273298944744
- No tinted navbar add-on: https://www.androidfilehost.com/?fid=457095661767151246
Pretpostavljam da niko ko je na beti nije dobio?
Послато са Nexus 6P уз помоћ Тапатока
Vrlo verovatno ...
Mislim da će te prebaciti na 7.1.1 mart i onda ponuditi OTA za 7.1.2 april, tako da ti je bolja opcija odmah image 7.1.2 stable.
Vrlo verovatno ...
Samo ga fleshnem preko adb-a, bez factory reseta?
Ne moraš adb, možeš preko flashfire.
Ne mora fr.
Nije obavezan factory reset, ali je vrlo vrlo poželjan ...
Kompletno uputstvo za povratak na 7.1.2 (N2G47H, Apr 2017) fabrički softver:
Prerequisites: unlocked bootloader
This section will explain how to return the phone to be like it was when it came out of the box. This will wipe everything from the phone. If you wish to flash the factory images without wiping your personal data from the internal storage please move on to the next section.
Go to Settings/Backup & Reset and perform a factory data reset. This will remove all of your user data from the device (apps, settings, photos, music, etc).
Download the appropriate factory NEXUS 6P image - https://dl.google.com/dl/android/aosp/angler-n2g47h-factory-f1111327.zip
Unzip the angler-n2g47h-factory-f1111327.zip into a directory on your PC (for this guide we'll use C:\angler\).
Once unzipped you should have a folder named angler-n2g47h. Open it and move the following files to a new directory named C:\angler\images\:
bootloader-angler-angler-03.67.img
radio-angler-angler-03.81.img
Within C:\angler\angler-n2g47h\ you'll see another zip archive named image-angler-n2g47h.zip, unzip the contents of that zip into the C:\angler\images\ folder we created before. Now within C:\angler\images\ you should have the following files:
android-info.txt
boot.img
recovery.img
system.img
userdata.img
vendor.img
Boot into the bootloader and connect your phone to your PC via usb cable.
Skinuti i raspakovati na računar najnoviji SDK - https://dl.google.com/android/repository/platform-tools-latest-windows.zip
Otvoriti command prompt iz tog raspakovanog foldera (shift + right click anywhere within that folder, select open command prompt here), enter these commands to flash:
Kod:
fastboot flash bootloader C:\angler\images\bootloader-angler-angler-03.67.img
fastboot reboot-bootloader
fastboot flash radio C:\angler\images\radio-angler-angler-03.81.img
fastboot flash boot C:\angler\images\boot.img
fastboot erase cache
fastboot flash recovery C:\angler\images\recovery.img
fastboot flash system C:\angler\images\system.img
fastboot flash vendor C:\angler\images\vendor.img
fastboot format userdata
Once all commands/flashes are complete you can reboot the device:
Kod:
fastboot reboot
TWRP Rikaveri - https://dl.twrp.me/angler/twrp-3.1.0-0-angler.img
SuperSU (RUT) - https://download.chainfire.eu/1021/SuperSU/SR3-SuperSU-v2.79-SR3-20170114223742.zip?retrieve_file=1
Ko hoće može:
[APK]AdAway (protiv reklama) - https://va1.androidfilehost.com/dl/...34744719/AdAway-release_Build-Feb.08.2017.apk
[ZIP][N2G47H] Full Pixel Mod - https://qc3.androidfilehost.com/dl/.../673368273298944744/full-pixel-mod-n2g47h.zip
Full Pixel Mod donosi:
Animated pixel navbar
Night mode
Blue color accent
Round icons
Tinted navbar
Google assistant
Navbar tuner
Pixel live wallpapers, launcher, sounds, bootanimation (black)
Hvala, uradim cim stignem 🙂
Šta ste kontali kad je najbolji trenutak za prodaju telefona i nadogradnje na neki koji neće biti skuplji od 450-500 evra? I koji bi mogao da bude dobar naslednik?
Cim ga nema god i po dana,nece ga ni biti,al je nejasno kako ni za nokat ne pada cena
Послато са SM-G935F уз помоћ Тапатока
Lg v20, ako ne upadne u bootloop. Ne znam da li i on ima problema... [emoji4]
Najbolji trenutak, kad skupis pare za sledeci telefon. Dobar naslednik? Svaka sledeca generacija pixela.[emoji106]
Sent from my G
Kakav crni Pixel za 650e bez garancije. Bolje onda iPhone da kupi...
Neku od novih Nokia, pošto voze klot Android?
Možda misli na ovaj novi koji trebaju da predstave sa s821/s835. Mada on će biti preskup
Pa i ova šestica tek treba da bude u prodaji ...
Sve u svemu te "nokije" tek treba da se dokažu, jedan htc je obećavao update za nedelju dana pa nije ispunio, a ne ovi koji su u kanalu.
Ја сам прешао на хтц 10 и поприлично сам задовољан 🙂
А следећи фон или пиксел или хтц 11
Sent from my HTC 10 using Tapatalk
Ima neko predlog kako da skroz sklonim navbar bez da editujem build.prop? Immersive mod na PN mi ne vrši posao jer mi se navbar pojavljuje kad swipe-ujem odozdo, a onda mi to smeta jer sam dole podesio hotspotove za swipe gestures.
Sent from my Sexus 6P using Fapatalk
E to, super, hvala. Zaboravio sam da tu ima opcija, ja probao sa Expanded desktop iz quick toggles, ali nije to to.
DU vec digao nex6 na 7.1.2 i sve OK. Manje im treba nego Googleu.[emoji23]
Sent from my G
Ljudi, zar nije bilo price da ce google pistiti assistant uz 7.1.2? Ja ga ne vidim na mom 5x?
Asistent ti je stigao na sve telefone koji imaju 6.0+ android ...
