Amazon Fire TV
  • Začetnik teme Začetnik teme McDuck
Pored Netfly i CinemaHQ, još jedna preporuka za Stremflix. Ovog puta bez live programa 🤣
Od provajdera izabrati TMDB (english).
Što se prevoda tiče, tokom emitovanja, ući na captions i izabrati srpski. Ako ga ne ponudi automatski, spustiti "kursor" do opensubtitles i izabrati koji vam je po volji.
Flix Vision
Može se naći na FireStickHacks stranici.
Podržava debrid servise, ne i torbox 😃
Proverio par novijih naslova, dostupni naši prevodi.
Live tv u rangu sa CinemaHQ, ako ne i bolji, šljaka pink sve u šesnaest 🤣
To je to ljudi, kad krenu da gase postojeće -idemo u lov na druge 😃
Izdvojio bih SportzX koji je stvarno bez konkurencije. Ovo ostalo, manje više sličnog kvaliteta i sadržaja.
Jel samo meni Defender prijavljuje virus na Flix Fision.apk ?
Obzirom na live TV i adult kategorije nije isključeno 😃 Imaju svoj discord server pa možeš pročešljati pre eventualne instalacije..
Evo šta kažu:
#FAQS REGARDING PLAY PROTECT
Is FlixVision Safe?
FlixVision is 100% safe with no viruses or malware.
Why am I seeing a notification when downloading the file that it has viruses?
This is because the signing certificate of the App has been flagged by big companies like Google. When we let our unsigned APK run through VirusTotal for instance, it detects no viruses because our code doesn't contain any malware. But as soon as we sign the APK, it detects a virus.
Do you have an explanation for the above?
```Yes. The first thing you as a user need to know is that there are so many pirated copies of our App out there. People reverse engineer our App, add their code, and publish them. Now, if one of them has a virus, then all Apps that are 90% identical (like the original) becomes also suspicious as the algorithm thinks they are all copies. This is why you should never use a pirated/modded version or use it at your own risk. We checked a few mod versions of our App in VirusTotal and more viruses popped out while only one virus was "detected" for the original APK.
Da rezimiramo, virus total kaže 29 detekcija što je poprilično visoka cifra. Neću se oslanjati na "garanciju" developera, već ide na deinstalaciju.
@Sone1983 hvala na "signalu" 😃
Netfly, skyshowtime i CinemaHQ pokazuju ispod 5 detekcija i ne bi trebalo da predstavljaju opasnost. Sportsfire, Streamfire i SportzX čiste u potpunosti.
Ima li ko narodnu verziju AtvTools da posalje na PP a da mu radi, najbolja verzija, 1.3. Sve koje skinem i instaliram imaju neku gresku gde se odmah po pokretanju zatvore
Da li si pre instalacije odradio USB debugging u Developer Options inače neće da radi. Tako je na box i TV uređaju valjda je tako i ovde
Nije to, sad sam cackao.
Sad sam opet nesto cackao, pojma nemam sta, i proradilo, svasta. Dao si mi ideju da procackam po developer opcijama samo sto ja nemam pojma sad sta sam radio 😀
Ljudi dajte downloader kod za eon smart tv aplikaciju?
Imam Amazon Fire TV Stick 4K Max. Kupljen još prošle godine, još ne raspakovan. Šta sve trebam da odradim da napakujem Projectivy Launcher?
Napravis nalog na Amazon.de .com .. nebitno. To pre svega uradis.
Prvi korak ti je da uklucis Fire u struju, i da budes spreman da iskjucis internet kada uredjaj krene da trazi azuriranje. Znaci, kad stigne na Checking For Updates da iskljucis ruter na koji si prethodno nakacio Firestick. Onda stisnes Back i Menu taster na daljincu i ulazis u VoiceView rezim, to ti je slicno Safe Modu, tu mozes da se vec spojis na internet (Ukljucis ruter), prijavis na ACC i odradis ostalo. Ako imas extremno brz net najbolje u ruteru podesi brzinu WIfI ako mozes jer je tu bitna brzina koliko brzo mozes da iskljucis ruter pre nego sto krene preuzimanje azuriranja.
A pod ostalom mislim na svasta jos, medjutim, JAKO BITNO je da ne resetujes Stick dok ne blokiras update. Znaci svo vreme u pozadini Firestick ce preuzimati azuriranje ali ga nece instalirati dok ne pokrenes ponovo uredjaj. Znaci, Fire mora da bude ukljucen, bez resetovanja. CIm resetujes krenuce da instalira azuriranje i tu si gotov. Znaci, NO REBOT.
E onda odes na XDA forum, procitas prvi post odavde, naucis kao OCE NAS.
Moras da instaliras Launcher Manager i da mu das dozvole, a zatim u Launcher Manageru da blokiras azuriranje.
Ako nisi baratao sa ADB onda ce ti malo biti prpa ali ne radi nista dok ne iscitas sve sto treba iz prvog posta na XDA a ovo sto sam ti napisao u prvom delu poruke da naucis kao Simvol Vere. Tek onda krenes u tu avanturu. Deluje komplikovano ali ako se spremis lapo, sve se resi
Napakovao sve... Radi bez Greške.
Hvala puno na pomoći.
Inače verzija Softvera je OS 8.1.1.6 (RS8116)
Наместио си лаунчер да притиском на тастер HOME добијаш повратак на почетни екран тог лаунчера, а не на амазонов почетни екран?
Da, Pritiskom na Home se vraća na Projectivy Launcher, a u Launcher Manager-u isključio Update, Blacklist i još jednu Stavku, nesećam se tačno šta je bilo...
Da li neko zna gde mogu da nadjem 32 bitni apk za yettel tv? Imaju neke starije verzije ali login ne sljaka kad instaliram. Trenutno poslednja je samo 64 bitna. Uzeo sam Firestick 4K druga generacija u UKu ali je 32 bitni, dodje mi da ga bacim haha
Mislim da je bio nešto manje od 50e, možda 46.
ne radi lose, brzo se instalira. Jedino kad stisnes home dobijem ovu ikonicu i treba mu vremena da ucita, ne ide instant.
Та анимација је на FireOS 7, на FOS 8 је нема.
Meni ne izbacuje update na 8. Imam Max 1st gen jedan kupljen u Americi drugi u Nemackoj, azurniji je ovaj US ali su oba i dalje na 7ici.
