Kurttrasel
Cenjen
Dust 2 napravljen u Portalu
Tačno sam znao, closed weapons bukvalno su sakrili u BETI, čak je matchmaking pravio greške i ubacivao igrače u druge modove...There were no differences of note for time players spent in combat between Open and Closed Weapon playlist types. The actual differences were only fractions of a percentage where, rounded up, the results were identical.
Lastly, another key insight from the Open Beta was that the vast majority of players, after trying both playlist types, chose to stick with Open Weapons. This reinforces our belief that Open Weapons is the right path forward for Battlefield 6. At the same time, we recognize that some players prefer the Closed Weapons experience. To support them, official Closed Weapons playlists will be available at launch.
Neće biti server browsera u main menu, Portal su preimenovali u Community, tu će biti custom serveri i server browser.Alongside these, you will see combined playlists such as Conquest & Escalation and Breakthrough & Rush so you do not have to stop matchmaking when switching between those experiences. If you want to focus on a specific mode outside of playlists, you can always find it through Custom Search and the Server Browser.
Portal remains the tool for creating and customizing experiences, while the section in the main menu previously called “Portal” is now called “Community”.
This is where you will find the Server Browser,
Da si pratio YT-ere koji kače redovno materijal dok igraju Closed Beta, uhvatio bi da je došlo do izmena upravo u tačkama koje si nabrojao AKA oružja kao laseri (više ne pucaju tako kao u Open Beta, recoil je veći), automatsko tagovanje itd. Broj neprijatelja na zastavi je prisutan i u 2042, ništa novo a korisno je. Test range za vozila su u 2042 bili solo/coop serveri sa AI igračima, ne znam kakav range treba da izmišljaju.Isteklo vreme za edit...
Iskreno, voleo bih da se varam ali bas ne mogu da se otmem utisku da je ovo imitacija budjavog 2042 jer mi UI i gunplay na to lici. Nema pravi server browser sa filterima vec mazu oci sa "community" glupostima na kome ce 99,99% mapa biti krndelj neopevani, bullet drop skoro nepostojeci oruzja ko laseri > learning curve=0, he8es klase otkljucano sve sem gedzeta, helikopteri upravljanje ko igrackice, ozivljavaju vojnike iz eksplodiranog tenka ili apc-ja, nema vise zastava vec je capture point oivicen linijama. Ako zauzimas tacku, dobijas info koliko neprijateljskih vojnika imas na istoj. Zasto? Nisan pretrpan nepotrebnim informacijama i ikonicama. Nema krsten test range za vozila i letelice, vec samo streljana. Padobran ko Fortnajt, AA deluje sakato. Ne bi me uopste iznenadilo da se kroz mesec - dva pojavi puska sa cirkonima.
Eto, izjadah se u nadi da cu biti u krivu.
nazalost, kao nekom ko ima vise hiljada sati u BF4 i BF1, ne da mi se nije ovo dopalo ovo sto sam do sada video i probao, nego me je totalno odbilo od kupovine iste..... 🙁Da si pratio YT-ere koji kače redovno materijal dok igraju Closed Beta, uhvatio bi da je došlo do izmena upravo u tačkama koje si nabrojao AKA oružja kao laseri (više ne pucaju tako kao u Open Beta, recoil je veći), automatsko tagovanje itd. Broj neprijatelja na zastavi je prisutan i u 2042, ništa novo a korisno je. Test range za vozila su u 2042 bili solo/coop serveri sa AI igračima, ne znam kakav range treba da izmišljaju.
Mislim da je Open Beta bila super zaslađeni tester kako bi se dopao najširem broju igrača i u tom smislu je apsolutni pogodak da se ne zavaravamo. Sa druge strane, na osnovu iskustava YT-era, mislim da će igra na launchu biti malo teža i drugačija od onoga što smo dobili u Open Beta (najprostije rečeno - manje lasera, više recoila) i da će biti potreban određeni learning curve, pogotovo za one koji dolaze sa COD ili uopšte prvi put kreću u BF vode. Git gud što bi rekli mi veterani.
Bio sam protiv preordera, iako sam vrlo brzo tokom Open Beta prelomio da ću je igrati i plan je bio da je kupim u 17:01 na launch day (neki inat EA-u), ali sam dobio igru za rođendan, uradio preload i jedva čekam da počne prašenje.
Takođe imam hiljade sati u BF franšizi, počev od BF1942 u igraonicama, preko BF2 pa na ovamo bez preskakanja, uz neke naslove koje sam slabije igrao pa nisam prebacio hiljadarku (BF4, BFV, BF2042).nazalost, kao nekom ko ima vise hiljada sati u BF4 i BF1, ne da mi se nije ovo dopalo ovo sto sam do sada video i probao, nego me je totalno odbilo od kupovine iste..... 🙁
Ispraticu svakako, ali mislim da je to za mene ipak gotovo.... a imam i drugog favorita kojeg vec 5 godina cepam po 5-6 sati dnevno, igru sa definitivno najuvrnutijom idejom i izvedbom - Hunt: Showdown, ima nas 15-20 stalnih domacih, plus gomile stranaca sa kojima sam se sprijateljio, znaci bukvalno, pod morati je da se kvota sati igranja na dnevnom nivou ispuni hahahaha, pa prosto ne vidim gde bih ovaj novi BF uspeo da uglavim u satnicu 🙂Takođe imam hiljade sati u BF franšizi, počev od BF1942 u igraonicama, preko BF2 pa na ovamo bez preskakanja, uz neke naslove koje sam slabije igrao pa nisam prebacio hiljadarku (BF4, BFV, BF2042).
Tretiraj viđeno do sada kao trejler, pažljivo spakovan tako da se svima dopadne i zagolica ih dovoljno da ulete u igru ali je normalno i da se neće svakome dopasti. Isprati nakon launch utiske i review-ove sa osvrtom na Open Beta, po čemu se razlikuju i kakav će zaista biti gejmplej pa tek onda donesi zaključak. Idealno ako budeš u prilici da zaigraš kod nekoga ili da ti neko pozajmi svoj nalog da izvrtiš par sati. Posle par hiljada sati siguran sam da imaš takve saborce 🙂
Pa ja sam recimo do sada igrao samo kampanje, ne zanima me mp. Ima nasBukvy, ko zbog kampanje uzima bf…
