OnePlus 13
Ja sam zadovoljan baterijom, od 80% do 20% izdrži sigurno jedan ceo dan bar ali me nervira što potroši 8% preko noći. Je l' to standardno?
Jesu i vama system launcher i system UI uvek tu negde u top 5 - 10 po potrosnji baterije kad gledate aplikacije dole ispod sot-a ?
Mislio sam da uprostim ovo i prevedem na srpski ali dovoljno razumljivo je i ovako.
🔥 How to Improve the Audio Quality of OnePlus 13 Using Wavelet (No Root Required)
♨️ As you may know, the OnePlus 13 comes equipped with advanced internal speakers like 1115E + 1012H.
♨️However, the manufacturer's software optimization for the speakers might not match your personal preferences. Follow the guide below to optimize the speaker sound quality to your liking.
1️⃣ Download Wavelet
• First, download the Wavelet app from here
2️⃣ Modify App Settings
• Open Settings (gear icon at the bottom-right corner).
• Enable Legacy Mode.
• Set Buffer Size to a sample rate of 1024 (refer to Image 1).
3️⃣ Configure the Graphic Equalizer
• Navigate to the Graphic Equalizer section.
• Set the Preset to Personal, then tap on the screen.
• Enter the recommended settings (refer to Image 2). You can make minor adjustments if the sound doesn't meet your preferences.
4️⃣ Enable Limiter
• Go to the Limiter section and apply the recommended settings (refer to Image 3).
• Disable Auto Post Gain, as it may cause issues.
• If the speaker volume is too high or low, manually adjust the Post Gain setting.
5️⃣ Adjust Channel Balance
• The Channel Balance can be adjusted based on your preferences.
• Since the top and bottom speakers of the OnePlus 13 have different volume levels, you can fine-tune the balance (refer to Image 4). If you prefer not to change it, leave this option off.
6️⃣ System Audio Settings
• In your phone's audio settings, select the Music mode.
• Toggle Holographic Audio on or off depending on your preference.
7️⃣ Manage Wavelet in the Background
• Ensure Auto Start is enabled in the app's settings.
• In the power management section, allow Wavelet to run in the background. The app has minimal power consumption.
💢 With these settings, the optimization process is complete. These adjustments are applied system-wide. If you connect to Bluetooth or external devices, the settings will automatically adapt and can be configured separately without affecting headphones.
    38.4 KB · Pregleda: 35
    48.6 KB · Pregleda: 25
    20.9 KB · Pregleda: 22
    37.5 KB · Pregleda: 20
    48.3 KB · Pregleda: 19
    82.9 KB · Pregleda: 21
    58.3 KB · Pregleda: 31
Za sve koje imaju kineske (color os) verzije...
Da li ostati na coloru ili menjati za oxygen?
Ako je preporuka menjati koji je najjednostavniji nacin prelaska na Oxygen
Hvala unapred
Ako nemas smartwatch ColorOs je bolji od oxygena.
Huawei i Samsung satovi jedino rade na ColorOs tako da imas srece 😃
Videcu tj probacu prvo color pa ako nije ok menjacu za oxtgen... :)
Dobar je, sva kineština moze da se obrise ili disabluje. Da nemam Oneplus Watch 2, verovatno bih se vratio na COS.
Šta je problem sa satom na COS? I kako se očisti sve što je na kineskom?
Problem je što nema podršku za WearOs. Rade Huawejci i Samsung (uz malo gimnastike).
Briše se prostim deinstaliranjem i breeno asistent se isključi da se ne aktivira na Power dugme.
Takođe. Moj izgubi između 5 i 10% u toku noći što mi deluje kao da je previše.
Malo manje. Šaljem skrinšot ispod.
System launcher - 4,5 %
System UI - 1,5%
Evo kakva je situacija kod mene. Skrinšot je od sinoć. Ovo je čak dobar rezultat. Do pre par dana, prosek mi je bio 4-5h SOT. Sad se navodno popravlja...
4️⃣ Enable Limiter
Malo pre ga aktivirao i podesio. Primećuje se malo poboljšanje zvuka, nije loše. Ali pretpostavljam da je Atmos mod bolje rešenje, jel da? Osim toga ima li nekih trikova za produženje baterije?
Dok je OxygenOs bio na inicijalnoj verziji, zvuk je bio baš los. Tu je Dolby pravio ogromnu razliku. Svaka naredna iteracija OOS-a kao da su optimizovali zvuk sve više. Sa ovom poslednjom .821 sam isključio Dolby modul i iskreno ne primećujem baš neku razliku sa ili bez više.
Dobre vesti. Eto, makar zvučnike su rešili sa poprave. Kakva je baterija na .821 verziji? Primetio sam da se mnogo ljudi žali na skraćeni SOT pogotovo od .821 verz. Ja sam još uvek na .703 čekam release za EU model
Izašao ti je stable EU još prošle nedelje.
Baterija je odlična. Neko je na telegramu spomenuo kad se isključi Smart charging da dosta duže drži baterija i tako ga punim odnedavno i stvarno je solidna.
Izašao prošle nedelje? Malo pre sam proverio ali i dalje ništa. Proverio sam i "beta program" za svaki slučaj, ali ni tamo nema ni jednog dostupnog apdejta.
Probaj preko Oxygen Updatera :) ja po defaultu računam da ste svi rootovani i da ručno ažurirate 😁
Izašl je nova verzija: CPH2653_15.0.0.822(EX01).
Ne znam šta su unaprijedili. Ja sam još na 703 verziji, možda ću ovaj novi flešovati.
Mislim da je to za EU, global je još na .821
India dobija prva .831
Bateriju (barem u mom slucaju) najvise unistava non stop teren, voznja, putovanje, promena baznih stanica, handover, mobilni net i dve sim kartice. Razlika je nebo i zemlja u poredjenju sa gradskim "kuca poso, poso kuca" danima.
Sa .831, super je. AI recompose pravi magiju
Imate li preporuku za maskicu, odakle ste uzimali? Treba mi samo za neke situacije kad sam po ceo dan napolju, putovanja, svadba itd, a tripujem se ovih jeftinih sa AliExpressa zbog završne obrade, da ne izgrebe telefon.
