ivanojle
Poštovan
Nasao neki post od Hiseance:
We are announcing a new product for 2023 – a heat pump with an operating temperature of up to -30C – premium Energy Nordic series from the original manufacturer Hisense. Available from July 2023.
It has the highest energy efficiency among competitors in a similar price range. It has the maximum energy efficiency class A +++, working for heating in the second climatic zone. The high SCOP of the 5.1 model will ensure seasonal electricity consumption 5.1 times less than the kilowatt of thermal energy allocated for heating. The heat pump is represented by a model with a nominal power of 4.2 kilowatts. For heating area up to 45m2.
It has a strict neoclassical design that sets it apart from other Hisense air conditioner models. The air conditioner has a built-in Wi-Fi output unit (standard), which allows remote control and monitoring of the heat pump via the Internet using a smartphone. Energy Nordic is equipped with an electronic refrigerant supply system that allows it to be used as a heat pump, with the highest efficiency at critical outdoor temperatures. The heat pump is equipped with Toshiba DC-inverter compressors with triple sound insulation.
