Razmena pozivnica za torrent trackere (pravila su u prvoj poruci)
Ima li engleski prevod 😁
Vidim na login strani da može da se bira engleski.
vratimo se na temu. hvala na razumevanju
Niko ne spominje UHDBits,dobar tracker,lagan za održavanje.Ima dosta internala sa HDBitsa.Koristio sam ga ranije za cross seed na HDB.
Eto sa tobom sam usao u svet trackera i pozivnicom za FL ( sad proverih tacno 2god.) i doguro do VIP 😁😉 sto zahvaljujem i ovim putem 😁😉👍, pa ako ( mozda ) ima pozivnica za UHDBits ( i samo ako sljaka u Elementumu kao i FL a nije slucaj kao sa IPT da ne moze ) bio bih zahvalan za pozivnicu
I obecavam ovog puta necu gusiti sa podpitanjima u p.m. ( tada sam ipak bio mlad i zelen guster 🤣😂🤣😂 )
Vidim Torrentleech ima bonus poene, nisam dugo koristio. Onda je lakša priča nego ranije. Nekada je samo suvi upload mogao da nabije ratio, pakao bio.
Torrentleech je otvorio registraciju:
Use the Invitation Code: FLREFUGEE
Takodje info sa TL-a:
We are all sad to see FileList close its doors after all those years.
If you were/had an uploading group there, and you wish to continue posting your releases on TL for everyone to enjoy, please do DM zdeev with subject "FileList uploader" along with a screenshot proof of your account on FL, so we can promote you directly as an uploader on TL. This way you can continue sharing your releases to the community!
We hope you will feel like home here.
See you online!
<3
Sto se tice FL-a uzas... Taman sam ga dobio, odlican 0-day traker i sad se gasi :( Znaci iznervirah se, prvo Rar.bg sad ovi, uzas
Ipak ne zatvaraju vrata 🥳
We were overwhelmed by your wishes and messages!
You know that over the years, I've always said that the community has a significant voice. Your words have always mattered, and we've never been indifferent to them. Your voice has been heard, even now.
I am delighted to announce that the website will not be shutting down!
Donations are now reactivated, so everything is returning back to normal.
One of the founders of the website, God, is back and will take over the technical aspect to ensure the site continues to thrive. He is trustworthy, loyal, and things will certainly go well from this point of view.
However, we also needed someone to take care of the other aspects of the work. From now on, Oana will handle everything related to the staff, server payments, and all the internal matters that a SysOp does. She will get promoted to the SysOp class. She is more than capable and competent to maintain control and ensure that everything runs smooth internally. Congratulations!
Together, they will continue the necessary work to keep this website alive.
That being said, this announcement will be my last. I, EboLLa, am permanently retiring from the community.
I want to personally thank you all for all the private messages and wishes you've sent me. There have been so many, and I genuinely appreciate them from the bottom of my heart. You are all wonderful, and I appreciate each and every one of you!
I am and have been honored that I could contribute to your well-being! To all of you. Farewell and take care!
:love:
So let's wish Oana and God best of luck!
With love and appreciation,
EboLLa
Reko Ebola sa FileList
Tako da radujte se narode :) Ako treba nekom pozivnica nek se javi u PP.
Isto, imam pozivnica za FL, ali uz uslovw iz prvog posta. IPT moze i pocetnicima.
nCore nema engleski na sajtu, mora translate da se koristi.
Ima li neko pozivnicu za neki od audio trackera? Zanimaju me flac ripovi są ploca. Jako davno sam bio aktivan na what.cd I naravno spreman da aktivno seedujem. Takodje izuzetno mator clan kao sto se moze videti :) Hvala!
Ako te interesuje Redacted, a verujem da te baš taj tracker interesuje, pusti PM.
Ima li neko da preporuci pozivnicu za neki dobar traker. Fer sam korisnik, ponekad downloadujem, ponekad ne. I ako je neko zaintersovan da mi pojasni seedbox kako ide, mogu i da uplatim nesto na torrent da se ima kad zatreba. Traker za filmove najviše tražim, pošto za sve ostalo koristim rutraker, a mnogo mi je žao što je Partis otišao u večna lovišta.
Zahvaljujem članovima na pozivnicima.
Da li ima neko pozivnicu za https://exyusubs.com/ ? Zapravo, pre pozivnice, ako neko može da napiše da li je dobar i da li je teško da se održava. Ja sam do sada na crnoj berzi i uglavnom sedujem do 1001 i nazad :D
Ako neko ima pozivnicu za neki UHD torrent site, bio bih zahvalan, UHDBits ili HDbits. Hvala
Moze i meni za UHDBits. :D
Stvarno moras da budes ****** da trazis pozivnicu i da se neodgovorno ponasas tamo, pogotovu na ovim elitnim trackerima. Ja bih takve banovao i sa foruma , jankada sam dobijao pozivnice po sat vremena sam iscitavao pravila da nesto ne zajebem, ali nismo svi isti...
Nema više takvih članova. Ja sam umalo s CB banovan zbog nekog gospodina odavde. Od kada sam se opekao mislim da sam možda par puta ponudio nešto ovde.
Imenujte takve da se i drugi ne zeznu.
Jesam tada, ne sećam se sada kako ide.
