Windows 11 - dev build / preview / testiranje
  • Začetnik teme Deleted member 46590
  • Datum pokretanja
Dev Channel​
The Dev Channel will be for long lead work from Microsoft engineers with features and experiences that may never get released as Microsoft tries out different concepts and get feedback. It is important to remember that the builds Microsoft releases to the Dev Channel should not be seen as matched to any specific release of Windows and the features included may change over time, be removed, or replaced in Insider builds or may never be released beyond Windows Insiders to general customers.
The Dev Channel is for highly technical users who love to be the first to see the latest features and updates for all things Windows. It will get builds that are earliest in a development cycle with the latest work-in-progress code from our engineers. These aren't always stable builds, and sometimes you will see issues that block key activities or require workarounds while flighting in this channel.
These builds aren't matched to a specific release, which means these may simply be the latest work-in-progress code from our engineers. New features and OS improvements in this channel will show up in future Windows releases when they're ready, and Microsoft may deliver them as full OS build updates or servicing releases. Your feedback here will help Microsoft engineers with major fixes and changes to the latest code.
Beta Channel​
The Beta Channel is for early adopters and IT professionals who want to see what's next or validate the latest Windows updates and features, but still need reliable updates that are validated by Microsoft.
As a part of the Beta Channel, you'll be seeing builds tied to a specific upcoming release, like Windows 11. Your feedback will be especially important here, since it will help Microsoft engineers make sure that key issues are fixed before major releases.
The Beta Channel will be previewing experiences that are closer to what Microsoft will ship to general customers. Because the Dev and Beta Channels represent parallel development paths from Microsoft engineers, there may be cases where features and experiences show up in the Beta Channel first.
Release Preview Channel​
The Release Preview Channel remains the best spot for previewing what’s coming to general customers soon.
In the Release Preview Channel, Insiders and IT professionals get the upcoming version of Windows before it's released to the world, with advanced quality updates and certain key features. These builds are also supported by Microsoft if you're in the Windows Insider Program for Business.
A posle i ovo
Nekako mi se "ušunjao" ;) apdejt na 11-u.
Da li ostaviti desetku ili ipak instalirati jedanaesticu?
To moti znaš ali ako ti je ponuđeno znači da je sve kompatibilno.
Nisam mislio na hardwersku kompatibilnist, to je sigurno kompatibilno(i7 8700, 16gb ddr4, itd...). Nego da li 11 kao OS radi bez problema? Čuo sam od lokalnog servisera da mu se dosta njih žali na jedanaesticu.
Ja sam još zimus/proletos(ne sećam se tačno), napravio butabilni Win 11 na flash disku i instalirao na jedan nov laptop, vlasnik laptopa ne javlja da ima problem sa sistemom, znači da mu dobro radi...
Ma nema problema. Ja sam od prve insider opcije. Bilo je problem sa drag and drop davno u taskbaru, ali je i to ispravljeno.
Pa naravno da serviseri znaju puno ljudi sa problemima, niko ne ide kod njih kada sve radi kako treba.
PS. Imaš 10 dana (ako ne uradiš disk cleanup) da se predomisliš i vratš nazad.
Imam problem sa instalacijom Windows 11 na novoj masini. Pokusao sam sve i uvek isti problem. Pokrenem instalaciju, zavrsi najnormalnije prvi deo prebacivanja fajlova na ssd, krene drugi deo gde windows odradjuje instalaciju, kod dela gde pise da startuje servise iskoci blue screen i to je to. Menjao vise usb-a, ponovo skidao instalaciju sa ms sajta, poslednji bios sam instalirao na ploci, ukljucen tpm, cupao hardove da ostane samo ssd. Windows 10 prodje bez problema. Ne znam sta vise da probam. Ima li neko ideju?
Ako ne prolazi cista instalacija Win 11 ti odradi Win 10 pa kroz update skini Win 11.
A "nova mašina" je ???
Resio sam problem. Ladno je druga pci mrezna karta pravila problem. Kad sam nju izvukao prosla je instalacija.
Konfiguracija vise nije bitna ali kad si pitao red je da odgovorim:
AMD Ryzen 7 5700x
Gigabyte B550 Aorus Elite v2
MSI Ventus GTX 1660 6gb Super
2x16GB HyperX Beast 3600 mhz
Samsung Evo 980 Pro 512gb
Ja ostajem na "novom" Dev pošto mi je to ujedno i "rezervni" OS a izbacio sam Linux Mint pre nekolkiko meseci. Ako je suditi po Edge-u Canary je previše nestabilan.
Announcing Windows 11 Insider Preview Build 25314​
Zdravo svima! nikada nisam koristio Windows 11 i želeo bih da sastavim dva računara prijateljima i da na njih stavim Windows 11. Da li je to zaokružen proizvod bez problema?
Lično još uvek koristim Windows 10 LTSC (LTSB) iz 2016. i radi kao švajcarski sat. Ali možda je vreme za promenu i kod mene!
Usput, ima li Windows 10 nešto poput, LTSC/LTSB kanala? Hvala! 😉
Ako želiš stabilnost, 10-ka definitivno.
U redu je 11, ali nije kompletan proizvod još uvek sa aspekta sazrevanja i šansi za što manje problema.
Što se tebe tiče, ako ti odgovara LTSC, guraj i dalje isto, samo novije (21H2 LTSC).
sto se tice stabilnosti mozes i 11, nemam nikakvih problema sa stabilnosti racunara koji je 24/7 on
ali nemoj ovaj dev build vec live production verziju
ali posto svi imamo svoje varijante OS-a, ono sto meni i dzoniju radi ne mora da znaci da je i tebi ok. to moras sam da odlucis
@illidan
Hvala na odgovoru. Na šta si mislio kad si napisao da vas dvojica imate "svoje varijante OS"-a?
Svakako ne bih developer build. 😁
Da li Windows 11 ima nešto slično kao Windows 10 LTSC/LTSB (only security updates)?
u smislu svako sebi podesi OS po nekim njegovim zahtevima, svako radi drugacije stvari na OS, sve to treba uzeti u obzir
Kod mene win 11 radi neuporedivo bolje i stabilnije u odnosu na win 10 kada je izašao sa kojim sam imao poprilično problema. Mada je ovo win 10 sa manjim izmenama i novim skinom.
Koristim ga na glavnoj mašini za posao od kada se zvanično pojavio i ni jedan problem nisam imao.
Sve u svemu prija mnogo više oku jer je macOS-oliki :)
Ovo bi bilo osnovno korišćenje računara, gde bi se 99,99 posto vremena koristio samo browser. Samo ne želim da neki forsirani update blokira računar.
