jaffar
Kod:
<?xml version="1.0"?>
<settings>
<!-- for detailed info about the settings see http://webgrabplus.com/documentation/configuration/webgrabconfigxml
and http://webgrabplus.com/sites/default/files/downloads/Misc/Documented_Configuration_Files.zip -->
<filename>epg.xml</filename>
<mode>n</mode>
<postprocess grab="y" run="n">rex</postprocess>
<user-agent>Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.130 Safari/537.36 Edg/79.0.309.71</user-agent>
<decryptkey site="site-name">xxx</decryptkey>
<license wg-username="xxx" registered-email="xxx" password=xxx" />
<logging>on</logging>
<retry time-out="5">4</retry>
<timespan>0</timespan>
<update>f</update>
Replace the next dummy channel entry with the channels you want.
You can look into the installed siteini.pack folder on your computer
For the latest version,
see http://webgrabplus.com/epg-channels for the available sites/channels
<channel update=xxx</channel>
