Neki ljudi su prijacili da taj novi Muse ima tih baja.
Da li na gree klimi moze da se uradi ofset, aki moze neka neko objasni kako?
Prepisano sa drugog foruma upute iz s manuala. Probaj, mada nez da je nekome nesto rijesilo.
Znaci klimu treba iskljuciti iz napajanja jedno minutu, i sto brze ovo ukucati pri paljenju klime.
To set 3C temp. compensation: in heating mode, set temp at 17℃, then within 5 second ,press button"+,-,+,-,+,-" , there will display 3 on IDU, heating light shining 3 times
To set 2C temp. compensation: in heating mode, set temp at 18℃, then within 5 second ,press button"+,-,+,-,+,-" , there will display 2 on IDU, heating light shining 2 times
To set 1C temp. compensation: in heating mode, set temp at 19℃, then within 5 second ,press button"+,-,+,-,+,-" , there will display 1 on IDU, heating light shining 1 times
To set 0C temp. compensation: in heating mode, set temp at 20℃, then within 5 second ,press button"+,-,+,-,+,-" , there will display 0 on IDU, heating light shining 4 times
