Imam ja taj jedan dac, stigao mi, ali posto sam uzeo X6, ocaj je viska, pa moze neko da proba kako mu radi i da li odgovara.@lepi kokan
Naručio sam onaj BT. Od toga kako radi videću da li će zvučnici biti BT ili ne. Isto jedna informacija. Jedan moj drug mi je rekao da onaj mali
https://www.aliexpress.com/item/32932392383.html?spm=a2g0o.productlist.0.0.2d164872ikXAYN&algo_pvid=a24f2591-ca45-479a-b97f-663ad198461d&algo_expid=a24f2591-ca45-479a-b97f-663ad198461d-15&btsid=0bb0623c16006745773493500e13a7&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
DAC Lusya SA9023A + ES9018K2M radi bolje od Asusa DG. On je svoj prodao. Na par mesta sam pročitao da je kopija (klon) Dragonflaja red.
https://nobsaudiophile.wordpress.com/2019/09/24/ultra-cheap-chinese-dac-amp-mini-reviews-absurdly-inexpensive-audio-solution/
Sent from my SM-N950F using Tapatalk
pre ~15 godina iole solidni 2.1 zvučnici su koštali oko €50, sada takvi koštaju €75+. inače, tada je Microlab imao super cene a onda se promenio dobavljač i osetno je poskupeo.a i mislio sam da za 30-ak e mogu dobiti neke pristojne zvucnike, ... To se izgleda promenilo, pa sada treba izdvojiti vise novca, citao sam da je i FC330 vremenom imao sve vecu cenu.
vlado, hvala za dojavu za dragonfly red klon, deluje kao apsolutni best baj ever i potencijalno obesmišljava sve ostale audio dac investicije.
-DAC AUDIO SA9023A + ES9018K2M USB portable DAC (22$)-
SOUND: 9/10
CONSTRUCTION: 8.5/10
VALUE: 9.5/10
This one is something else, and unlike other DIY products, its a finished mini USB DAC-AMP with proper metal casing. What push me to buy it is the fact it use a Sabre ES9018K2M dac in the smallest portable way possible. Sure, its not a super powerfull dac-amp but with its 1.5vrm its more powerfull than the Audirect BEAM that sell for 100$. Some think the DAC AUDIO is a copy cat of DRAGONFLY RED that use similar ES9016 dac and sell for 200$ (!), but specs say it deliver 2.1V rms output power so I guess its quite different (wich do not mean it sound better, perhaps the opposite due to lower dac model used). Again, this device is plug and play, with my different laptop or tablet I have no issue about recognization of the DAC, BUT with my LG G6 it do not work, still it work with all Samsung phone I try. So, if you plan using it only with your phone, its perhaps a risky buy!
What about the SOUND? Well, as say it use the superb ES9018 dac, wich have been well implemented even if the signal to noise ratio isn’t the best at 93db and make it less clean sounding at high volume than well…400$ IBASSO DX90 or 250$ Xduoo X20 DAP for example. Anyway, you got a very accurated, detailed, delicate and revealing sound as expected with this excellent sabre dac. It sound way better than stock phone or laptop sound card because of its vivid dynamic range and great imaging capabilities. As a fan of ES9018 dac, I confirm this is the cheapest way you can taste its flavor, but I suggest using it with low impendance earphones to benifit its great clarity and dynamic. Reference sound at peanuts price IMO.
NO BS SUPER RECOMMENDED!!
Imao sam onu eksternu asus karticu, zaboravih oznaku, mislim da je bila x7 ona druga verzija i tim uopste nisam bio zadovoljan. X6 bas lepo radi i bolji je od ovog usb dac-a, ali opet i skuplji. Meni ovaj usb dac stoji, skuplja prasinu, ako ti treba javi se.Napiši nešto o njemu, kakav je u odnosu na x6? Da li si ga poredio sa Asus DG ? Ja bih ga rado kupio![]()
Shiping za Vikefon je skoro 40 dolara.
da li je neko probao ovako neki chromecast audio klon?
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
jeste skuplje od bt varijanti, ali ima više mogućnosti, daleko manje troši bateriju za strimovanje i svakako je bolji zvuk...
Ja uzeo pre desetak dana, sa inteza popustom izašli oko 180€.
Imaju kontrole sa strane, svi ulazi rade pu,pu, daljinski kriminalan valja snajper kada nišaniš...
Lepo sviraju, vrlo zadovoljan. Nema tu neke preterane snage, slični su po snazi nekoj matoroj filipsovoj liniji koja je 2x50w ali meni to i ne treba, naprotiv.
Povezao u setap sa tv-om (sat risiver) i ceo dan svira swiss pop baš prija. Nikad ne slušam muziku za računarom je me ovi altec zvučnici baš umaraju, dok je sa ovima baš obratno...
Odlični su za filmove, grme kad treba a za muziku je meni basa i previše pa ga držim na -4 a treble +2...
Sve u svemu, nisam hteo saundbar a i oni su preterano skupi pa mi se ovo učinilo kao kompromisno rešenje za muziku i filmove i rade posao. Cena jeste malo naduvana, ali kad nema nekog velikog izbora to je to...
