So now we stumble upon the difference. The big change here is that the V35 ThinQ has been updated internally for 2018, getting a Qualcomm boost and moving onto the Snapdragon 845 platform. It also gets 6GB RAM as standard.
Those who know their LG V30 models will know that the V30 launched with 4GB RAM and then updated to the V30S with 6GB RAM in February, but the jump to SD845 is going to be the big differentiator here - it brings more power to handle your mobile demands even better.
There are two version of the V35, one with 64GB storage and a + model with 128GB - but both also support microSD.
There's another difference in the audio offering: both have a quad DAC to support your headphones, but the LG V35 also offers DTS:X 3D surround sound, for more immersive mobile audio through the speakers. This appeared on the LG G7 and is a useful audio boost on the V35.
On paper the cameras might look similar. The rear camera is a dual system that offers a wide-angle camera paired with the main. The difference here is that the wide-angle camera on the V35 has been moved to 16-megapixels, but at the same time, its field of view narrows, to 107 degrees, compared to 120 degrees on the V30 - so the new model is less wide than the old.
LG says this is to give wide angle photos with less distortion and increased sharpness. If the quality goes up, then who can complain?
The front camera also gets a bump to 8-megapixels (from 5-megapixels on the V30), to give you more detail.
The LG V35 ThinQ has the AI camera - although this update should have landed on most LG V30 models by now. LG also says this is the "Super Bright Camera" featured on the LG G7, which leans on AI (and processing from that more powerful hardware) to boost the low light performance.
So the LG V35 ThinQ should be a better camera all round.
Ja bih postavila isto pitanje? sada 2019, avgust. Čula sam od benč kolege da ima problem sa ekranom i bojama. Ako može neko da mi objasni šta je u pitanju, thx...Gledam da kupim ovaj telefon,jel bi hteo neko od korisnika ovog telefona da napise utiske o njemu.
ok... thx... ali... što to znači konkretno na praktičnom primeru objašnjeno? burn-in, mrtvi pikseli ili oni duhovi koje nikad videla nisam 🙂 Šta ekranu može da se desi (opisano konkretno: to i to...) i kako se to vidi i da li se to dešava često, retko... i kako to proveriti na polovnom? Jel mu je to jedina mana? Pa on je super ako je to jedina mana? samo ako to ne znači da ću da ostanem bez ekrana... Za zvuk ne treba da pitam, sigurna sam zar ne?Lošiji oled , to jest lg oled.
Pa ne zvuči baš OK. Kažeš "delimičan je rizik uzeti ga", pa šta je veći rizik V20 ili V30, prema tvom mišljenju?Npr brzi burn in , plavetnilo ako se malo pomeri osa gledanja ekrana , ili ono najgore bela nije ravnomerno bela preko cele površine ekrana, neki čak pričaju i da se vidi kao neka prljavština na belom iako je 2k ekran.
Sve u svemu delimičan je rizik uzeti ga.
OnePlus su nabavljali android geek-ovi (plus i nije bilo preveliko cimanje doci do OP telefona) a najveci (jedini) adut V30 je QuadDAC/audio kvalitet preko slusalica a prosecan bench clan u najboljem slucaju ima 5+ godina star PC sa ALC892 integrusom odnosno neki $250-$300 android telefon sa viper/power amp-om i kineskim slusalicama od 15-20$ tako da nije bas za poredjenje.
Ali se slazem da je V30 rizicna kupovina sto u sustini vazi za svaki LG bez validne garancije. G7 se bolje pokazao ali mu je primarna kamera ispod svih ocekivanja pa na tom polju zaostaje za ostalim uredjajima (KP, 350-400e).
Taj oled nije na nivou konkurencije i ima neke svoje mane ali sličan je kao u pixelu 2 xl kojeg i pravi lg, pa se koristi u daleko većem broju sa manje fame. (...) ali rekao bih da v30 opravdava cenu polovnog uređaja naročito što pruža vrhunsko audio iskustvo što ti je prioritet u kupovini.
Ja imam V30+, kupio sam ga u decembru. Za sada bez bilo kakvih problema, bez mrlja, burn ina i slično. (...)
Pa super... sto ljudi, sto mišljenja... 🙂 Ok, dobro je dok ih ima 😉 i treba tako... al' ste me svakako bacili u neodlučnost... i stopirali moje aktivnosti na planu potencijalnih gledanja pojedinih...Ja uzeo G7 na Kp (znaci u praksi bez garancije), ali ovaj put sebi za dusu..(...) Inace, dobar telefon (za mene).
mozda je tu najbolji kandidat G7 zbog IPS lcd-a, V20 bih zaobišao u širokom luku..... from komsa's XZ1
