LG V30
Koja je razlika V30-V35?
Sent from my SM-G950F using Tapatalk
Uz to 6 GB RAM-a umjesto 4 GB, i prednja kamera je 8 MP (f/1.9) umjesto 5 MP (f/2.2) a zadnje kamere su obe po 16 MP a ne 16 MP + 13 MP kao na V30.
Sent from my LG-H815 using Tapatalk
https://www.pocket-lint.com/phones/buyers-guides/lg/144658-lg-v35-thinq-vs-lg-v30
So now we stumble upon the difference. The big change here is that the V35 ThinQ has been updated internally for 2018, getting a Qualcomm boost and moving onto the Snapdragon 845 platform. It also gets 6GB RAM as standard.
Those who know their LG V30 models will know that the V30 launched with 4GB RAM and then updated to the V30S with 6GB RAM in February, but the jump to SD845 is going to be the big differentiator here - it brings more power to handle your mobile demands even better.
There are two version of the V35, one with 64GB storage and a + model with 128GB - but both also support microSD.
There's another difference in the audio offering: both have a quad DAC to support your headphones, but the LG V35 also offers DTS:X 3D surround sound, for more immersive mobile audio through the speakers. This appeared on the LG G7 and is a useful audio boost on the V35.
On paper the cameras might look similar. The rear camera is a dual system that offers a wide-angle camera paired with the main. The difference here is that the wide-angle camera on the V35 has been moved to 16-megapixels, but at the same time, its field of view narrows, to 107 degrees, compared to 120 degrees on the V30 - so the new model is less wide than the old.
LG says this is to give wide angle photos with less distortion and increased sharpness. If the quality goes up, then who can complain?
The front camera also gets a bump to 8-megapixels (from 5-megapixels on the V30), to give you more detail.
The LG V35 ThinQ has the AI camera - although this update should have landed on most LG V30 models by now. LG also says this is the "Super Bright Camera" featured on the LG G7, which leans on AI (and processing from that more powerful hardware) to boost the low light performance.
So the LG V35 ThinQ should be a better camera all round.
Za 600$ V35 je odlicna kupovina, posebno kada se zna da nudi najbolji audio kvalitet preko slusalica, zanimljivu wide kameru (prosecnog kvaliteta ali je bar ima). U odnosu na V30 ima malo bolje kamere, bolji zvucnik, 2Gb rama vise i noviji, brzi cipset (SD845) a na kraju ce imati i duzu podrsku mada je LG tu najlosiji u poslednje 2-3 godine pa to niko ne moze bas da garantuje.
Ne vidim Huawei koji je za taj novac bolji od V35 pa ni uopste, posebno jer nemaju prednost ni u softveru/UI.
Ako nista onda je ta prednja kamera veliki plus jer je na V30 sramna za danasnji standard. Mogao bi da ode ovaj s8 na dobos ili u zamenu za V35 [emoji4]
videh juce V30, bas je mocna spravica. jako lagan i tanak telefon a veliki telefon, solidan ekran, kaze ortak da mu baterija jako dugo drzi. za ljude koji nemaju omiljenog proizvodjaca vredi uzeti u najuzi izbor.
Gledam da kupim ovaj telefon,jel bi hteo neko od korisnika ovog telefona da napise utiske o njemu.
evo i ovaj model stigao na 300 evra...vredi li danas u ovo doba 2019 godine :) ja još vozim v20, koliko vidim i nije neka velika razlika u odnosu na v30?
Mi 8 ti je oko 300e, ne bih ja gledao v30 pored njega.
Pitanje je šta ti je prioritet doduše, v30 je sigurno bolji recimo u audio segmentu.
Ja bih postavila isto pitanje? sada 2019, avgust. Čula sam od benč kolege da ima problem sa ekranom i bojama. Ako može neko da mi objasni šta je u pitanju, thx...
Lošiji oled , to jest lg oled.
ok... thx... ali... što to znači konkretno na praktičnom primeru objašnjeno? burn-in, mrtvi pikseli ili oni duhovi koje nikad videla nisam :) Šta ekranu može da se desi (opisano konkretno: to i to...) i kako se to vidi i da li se to dešava često, retko... i kako to proveriti na polovnom? Jel mu je to jedina mana? Pa on je super ako je to jedina mana? samo ako to ne znači da ću da ostanem bez ekrana... Za zvuk ne treba da pitam, sigurna sam zar ne?
Npr brzi burn in , plavetnilo ako se malo pomeri osa gledanja ekrana , ili ono najgore bela nije ravnomerno bela preko cele površine ekrana, neki čak pričaju i da se vidi kao neka prljavština na belom iako je 2k ekran.
Sve u svemu delimičan je rizik uzeti ga
Dovoljan je podatak na forumu što ga niko nema. Da iole valja bilo bi bar 10-ak ljudi koji ga koriste.
Možemo samo napamet da pričamo i ništa više.
Sve u svemu delimičan je rizik uzeti ga.
Pa ne zvuči baš OK. Kažeš "delimičan je rizik uzeti ga", pa šta je veći rizik V20 ili V30, prema tvom mišljenju?
To što ga nema niko na forumu govori više o tome da nije pristupačan u Srbiji. Nema niko ni Essential, pa oni malobrojni koji ga imaju, kažu da je dobar.
Zvanično nigde nije mogao da se nabavi One Plus nekad, pa su ljudi nabavljali. Tako da to ne pije vodu. Ako je dobar telefon ljudi ovde će nabavljati, pogotovo ljudi sa Bench-a.
OnePlus su nabavljali android geek-ovi (plus i nije bilo preveliko cimanje doci do OP telefona) a najveci (jedini) adut V30 je QuadDAC/audio kvalitet preko slusalica a prosecan bench clan u najboljem slucaju ima 5+ godina star PC sa ALC892 integrusom odnosno neki $250-$300 android telefon sa viper/power amp-om i kineskim slusalicama od 10-20$ tako da nije bas za poredjenje.
Ali se slazem da je V30 rizicna kupovina sto u sustini vazi za svaki LG bez validne garancije. G7 se bolje pokazao ali mu je primarna kamera ispod svih ocekivanja pa na tom polju zaostaje za ostalim uredjajima (KP, 350-400e).
Mada, postoji gcam port pa ko hoce moze da proba ali je glavni senzor svejedno najmanji u klasi (1/3.1'') a ni gcam port nije svemocan u kombinaciji sa malim senzorom.
E da, cuo sam se sa nekoliko prodavaca (KP) i rekose da se jedno vreme V30 relativno dobro prodavao. Neki kazu da je problematican model, neki da je sve ok. Kapiram da su ga najvise kupovali uporni LG fanovi, pre svega stari korisnici G2 pa mozda i G3 koje u sustini audio hardver tog telefona i ne interesuje previse nego gotive LG/dizajn, tanke bezele i sl.
OnePlus su nabavljali android geek-ovi (plus i nije bilo preveliko cimanje doci do OP telefona) a najveci (jedini) adut V30 je QuadDAC/audio kvalitet preko slusalica a prosecan bench clan u najboljem slucaju ima 5+ godina star PC sa ALC892 integrusom odnosno neki $250-$300 android telefon sa viper/power amp-om i kineskim slusalicama od 15-20$ tako da nije bas za poredjenje.
Hvala na konkretnom odgovoru.
Medjutim, kao što kažeš "...rizicna kupovina sto u sustini vazi za svaki LG bez validne garancije...". Osim G7 i podvarijanti, ovde ni nema LG-a sa validnom garancijom. Ako pogledaš vlasnike većine LG-a ovde na forumu, primetićeš da ih je bar 60% uzelo bez validne garancije, naročito G7 koji je super preskup sa "validnom" garancijom. Možda postoji pristojan servis koji sredi šta treba da sredi, ako do toga dodje? (Btw, koji je servis nadležan za LG?) Znači, ti ne preporučujuš V30 više zbog nepostojanja garancije, a ne zbog vrlo ozbiljnog problema sa ekranom? Mene ljudi prepali sa tzv. duhovima na V20 (koje btw nikad videla nisam a imala sam 3 LG-a) i ja odustala od kupovine, a sad i V30 ima problem sa ekranom. G7 ima bleeding screen. Pa jel ima neki LG koji nema problem sa ekranom? :) (ova 3 koja sam ja imala nikakav problem nikada nisu imali sa ekranom). Šta ti "duhovi" mogu da učine ekranu? Da prestane da radi ekran? Ili šta?
Ja uzeo G7 na Kp (znaci u praksi bez garancije), ali ovaj put sebi za dusu..Znaci bez zastitnog stakla i sa jednostavnom Nilkin maskom. Do sada sam oklopljavao telefone i prodavao bez da ih prakticno i dodirnem. Ovaj put svestan rizik i zato ga i koristim s namerom da ne prodajem u 10/10 stanju. Inace, dobar telefon (za mene).
Ja imam V30+, kupio sam ga u decembru. Za sada bez bilo kakvih problema, bez mrlja, burn ina i slično. Kad sam kupovao gledao sam da izbegnem notcheve, a ovaj je bio jedan od retkih koji ga nije imao a uklapao mi se u budžet.
Taj oled nije na nivou konkurencije i ima neke svoje mane ali sličan je kao u pixelu 2 xl kojeg i pravi lg, pa se koristi u daleko većem broju sa manje fame. Lg je firma koja je sama kriva gde je sad i za svoju reputaciju, ali ja i dalje imam lg g2, g4 koje sam podelio ukućanima i dalje rade odlično bez ikakvih problema do sad. Jedino sam g3 prodao ali i on me je perfektno služio. Ja sad ne bih kupio nov lg jer imam sad druge prioritete u kupovini, ali rekao bih da v30 opravdava cenu polovnog uređaja naročito što pruža vrhunsko audio iskustvo što ti je prioritet u kupovini.
Taj oled nije na nivou konkurencije i ima neke svoje mane ali sličan je kao u pixelu 2 xl kojeg i pravi lg, pa se koristi u daleko većem broju sa manje fame. (...) ali rekao bih da v30 opravdava cenu polovnog uređaja naročito što pruža vrhunsko audio iskustvo što ti je prioritet u kupovini.
Ja imam V30+, kupio sam ga u decembru. Za sada bez bilo kakvih problema, bez mrlja, burn ina i slično. (...)
Ja uzeo G7 na Kp (znaci u praksi bez garancije), ali ovaj put sebi za dusu..(...) Inace, dobar telefon (za mene).
Pa super... sto ljudi, sto mišljenja... :) Ok, dobro je dok ih ima ;) i treba tako... al' ste me svakako bacili u neodlučnost... i stopirali moje aktivnosti na planu potencijalnih gledanja pojedinih...
OK, hajde ovo pitanje: V20 ili V30 (V30+)? Zašto DA, zašto NE? Thx unapred :)
mozda je tu najbolji kandidat G7 zbog IPS lcd-a, V20 bih zaobišao u širokom luku.....
from komsa's XZ1
mozda je tu najbolji kandidat G7 zbog IPS lcd-a, V20 bih zaobišao u širokom luku..... from komsa's XZ1
Ok. A što ne V30 (V30+)? Šta njemu fali?
G7 je super... mislim zvuk, veličina, za mene... ali sam lično videla bleeding screen na tom modelu, pa me to malo odbija; naravno možda je to jedan od retkih faličnih modela i baš ja da ga vidim :)
iskreno ne znam sta bih rekao, LG bez prave garancije u slučajevima kao što su problemi sa ekranima pločama itd je baš problematičan za izbor....
from komsa's XZ1
problemi datiraju još od g3 ali da ne ponavljam priču, kao da nemaju kontrolu kvaliteta.... šteta za najbolji DAC u telefonima..... možda to nije dovoljno....
from komsa's XZ1
V20 bih zaobisao, stariji cipset trosi vise struje, baterija se nije pokazala, jedina prednost je sto je mozes lako zameniti.
V30 sam gledao pre nego sto sam pazario G7 i solidan broj polovnih na oglasima koji su imali burn-in i to me je odbio od njega iako mu je kamera bolja od G7.
Sto se tice light bleed problema kod G7 mislim da je on prisutan samo u prvim serijama te to ne bi trebao biti problem.
Sto se tice bootloopa ne secam se da ga je iko prijavio na G7/V30.
Sent from my LM-G710 using Tapatalk
