ninite.com ; instaliraj Malwarebytes ; odradi full scan.
Sad je zavrsio Malwarebytes, nema nista.. :/
Imam samo 4 aplikacije koje koristim, a od igrica samo kanter i to sam instalirao pre neki dan..
Tebra bolje da si mi rekao pazi sta gledas po net-u hahahahaha :D :D
Ekshli, ne mora da ima veze sa malware-om, zna desetka s' vremena na vreme da se pogubi sa asocijacijama fajlova.
Obrisao skriptu i vise se nista ne pojavljuje.. Restartujem komp posle, i pojavio se novi update 15042, skida se trenutno :-D :-D
Evo prvi put mi se ovo desilo, restore je uradio za oko minut, dva...
Izgleda bolje da radim upgrade sa iso fajla... Nesto je puklo...
lol
Sent from mTalk aka Craptalk
El ovo tacno :D
Windows 10 Build 15042 Has No Desktop Watermark and Expiration Date
http://winaero.com/blog/windows-10-build-15042-no-desktop-watermark-expiration-date/
kada se očekuje zvaničan redstone 2 za neinsajdere?
U aprilu.
ako neko ima problema oko upgrade-a izgleda je ovo fix...
Issue Details
Who: Insiders installing build 15042 to their PC
Issue: During the 15042 install, your PC may “hang” and become unresponsive at the Windows boot logo screen
Why: One of the required install processes may initialize but not complete or timeout, thus causing the “hang”
What to do: There are no lasting effects from this issue. Please see the workaround steps below to continue with your update
Workaround Steps
For users who encounter this issue, the following steps will allow you to work around this issue.
Manually reboot your PC if it “hangs” at the boot logo during the first attempt to install build 15042
Allow your PC to successfully roll back to your previous OS build
Log into your PC and open a Command Prompt (Admin) window:
Click Start
Type Command Prompt
Right-click Command Prompt (desktop app) in the results listSelect Run as Administrator
Click Yes to confirm
One line at a time, paste these commands into the command prompt window. Press enter after each line:
reg delete HKEY_LOCAL_MACHINE\system\setup\upgrade\nsimigrationroot /f
netsh int ipv6 set locality state=disabled
reg delete HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nsi\{eb004a01-9b1a-11d4-9123-0050047759bc}\28 /f
Close the Command prompt window
Reboot your PC
Re-scan for updates and re-attempt the install
Completing these steps will allow you to proceed and install build 15042 as expected. If you encounter any issues, please post up and let us know.
https://answers.microsoft.com/en-us...-9ede-4495-a155-adf5469b4963?tm=1487959098001
Evo kome treba ISO, ESD ili UUP poslednjeg insider build-a 15042
http://www.windowslatest.com/2017/02/25/download-windows-10-build-15042-iso-images/
Samsung to launch new Tablets with Windows 10 and not Android
http://www.windowslatest.com/2017/02/28/samsung-launch-new-tablets-windows-10-not-android/
Samsung shvatio da Android nema buducnost na tabletima ...
Pa da nema buducnosti,to tesko.Kad pogledas dokle je Samsung dogurao sa telefonima i tabletima koje pokrece android,dodavanje u ponudi i tableta koje pokrece windows nece sigurno biti gubitak za njih.
Win 10 tesko da ce propadne za pc,ako pukne windows prodavnica,ali ce to da se odrazi na tablete i telefone.
Jos jedna zanimljiva vest , mnogi ce reci da je MS zao ... itd ali zaista je ovo nacin da se aplikacije procesljaju pre nego sto dodju do krajnjeg korisnika... Store ima smisla i za PC.
https://www.neowin.net/news/windows...o-only-install-store-apps-to-improve-security
Windows 10 Creators Update to include option to only install Store apps to improve security
Krajnje je vreme da developeri presele svoje app na Store, nije ovo attack na win32 app nego da se zna gde je sta i da li je bezbedno za PC... Muka mi je od milion alternativnih " izvora "
Wow, korisnici će moći da instaliraju sve tri aplikacije!
To je samo dodato kao opcija,posto to Android i IOS imaju odavno.
Nije ovo zatvaranje windows-a,jer ce uvek biti veci broj korisnika koji koriste druge izvore za preuzimanje softvera i ostalih multimedijalnih fajlova.
Ali u sustini nije losa alternativa za aplikacije,jer na ovaj nacin aplikacije ne mogu da prave lom po registriju i po operativnom sistemu,a un/reistalacija nikad laksa-desni klik-unistall i obrise je u potpunosti.
NA OS X-u vam ne smeta Store, na W10 vama je Store nepotreban ... ko ce vama udovoljiti ...
Uporedi ponudu aplikacija na macOS Store i na Windows Store.
EDIT: I macOS Store ne instalira aplikacije koje korisnik nije odabrao niti dosađuje sa reklamama.
Ne instalira sam Store aplikacije, nego su one upakovane u buildu - preinstalirane... nije isto.
U start meniu mozes ugasiti ono sto je recommended ...
Mac OS ima store jos od kada , nije fer porediti , ali nije fer ni mrzeti MS sto je odlucio da sve bude u Store-u ... problem su opet developeri... trebali su W10 da razvijaju jos od faze kada su pustili Vistu, nebi vi danas toliko hejtovali Metro/ MOdern interfejs.
@Sasa012 postoje mnoge prednosti kada je u pitanju Store, neka samo odrade posao kako treba... Mnogi nisu ni sanjali da ce Edge imati ad blocker pa evo i to se ostvarilo :)
Prica je na koraku iznad i Chroma, koji ima poseban Store za extenzije, teme... A google kao platforma ima poseban Store i za android ...
Kod W10 to je sve na jednom mestu, od skoro i knjige (ebooks) . Stvari se menjaju na bolje.
Realno,ne treba gubiti zivce zbog toga i razmisljati o tome.Windows prodavnica je tu,mozes da je koristis ako te interesuje nesto iz nje,u suprotnom ne moras ni da je otvaras.Mozes da je obrises ako ti smeta,mozes da pobrises sve aplikacije ako ti smetaju.Ako ti smeta sto skida sama aplikacije,imas opciju da iskljucis da ti izbacuje reklame u start meni,da sama preuzima i nadogradjuje aplikacije.
Kao iskusan korisnik racunara mozes da odradis sve sa par klikova.Onaj ko se ne razume u racunare ce lepo da angazuje iskusnog korisnika i da mu pomogne.
Ma Store je sada dobro snabdeven kako je bilo na početku. Sideloading APPs nije ništa riskantnije nego desktop SW.
Ovo je dostupno samo u Enterprise i Education verzijama.
@dejan87dex
Twitter i Candy Crush saga ne dolaze preinstalirane ako me sjećanje dobro služi.
Kako u w10 maknuti sve preinstalirane ms aplikacije... Mail, xbox, i ostale... Uninstall je onemogućen.
