Moglo bi to jos bolje... Imas root?
Nemam root. Kako bih regulisao to da imam root?Moglo bi to jos bolje... Imas root?
Google servisi ti pojeli jedno bar 30-40% baterije.
Evo ti BBS log![]()
Custom ROM i Custom Kernel mogu i bez roota, cisto da se zna.+ greenify + custom kernel + brisanje bloata + moze i custom ROM neki + BBS + razni programi + tweak-ovanje + ......
Eh,kad bi mi neko sve to postavio na tacnu...pa da probam.13 meseca sam oslep'o od wp-a,uzas.
Sent from my SM-G900F using Tapatalk
Moja greska. Ovaj je ipak za G900H (exynos verzija)
Features
Support of anykernel concept (only latest kernels) - flash stock kernel before flashing Boeffla
Full integration with Boeffla-Config V2 configuration app (get it from http://www.boeffla.de) to configure all kernel settings
Additional governors: zzmoove (Note: not considered stable at the moment, you might face reboots!!!), intelliactive, intellidemand, wheatley, smartmax, slim, intellimm, nightmare, lionheart, pegasusq
Zzmoove supporting native hotplugging profiles
Additional schedulers: fiops, bfq, sio, tripndroid, zen
Many Hotplug tweak profiles (Default, Optimized, 1 core max, 2 cores max, 3 cores max, 2 cores min, 3 cores min, 4 cores min, 2 cores exact, 3 cores exact)
Wake up gestures implemented (double-tap-to-wake, swipe to wake)
Boeffla-Sound engine (Headphones and speaker volume configurable)
Configurable vnswap
zSwap configured fix to Samsung stock value of 1280 MB
True dynamic FSync (activated if screen on, deactived if screen off), configurable
Touch boost frequency configurable, touch boost switch
CPU Overclocking up to 2.84 GHz
CPU Voltages interface for undervolting/overvolting
GPU idle frequency 27 Mhz added
GPU governor selection support
Show GPU frequency usage per frequency in Boeffla-Config
Color control to adjust RGB color space + inverted mode
SD card read ahead buffer configurable (default increased to 1024 kB)
Ext4 File system tweaks (default to on, can be disabled)
System Tweaks predefined supported (default is off)
Android logger (logcat) configurable
Kernel logger (dmesg) configurable
Charge rates for AC charger, USB and wireless charging separately configurable (set charge rate to 0 to have stock charge logic back)
Charge information display support via Boeffla-Config V2 app
CIFS support (module, Important: make sure you unchecked option "Mount namespace separation" in SuperSU settings; do not mount inside /data or /storage)
NFS support (module)
NTFS support (module)
XBox support (module)
OTG-Ethernet support (module)
TCP Congestion changed to Westwood
Swap supported (but not recommended, zSwap used already)
init.d support (in /system/etc/init.d - set correct permissions!)
Default entropies increased
Automatic EFS backup
Full support for mpdecision for best compatibility and smoothness
(Important: use Boeffla-Config to configure min/max CPU frequencies + governors + schedulers only - or explicitely allow other apps/processes to overwrite this in Boeffla-Config settings, but expect weird side effects)
Integrated full busybox 1.23.1 (own compilation)
Auto-Root by kernel possible by request
Kernel initialisation log file (with history of 3 log files)
Emergency reset script automatically placed into /boeffla-kernel-data folder of your internal memory
Presets supported in Boeffla-Config by kernel (Extreme power, power, normal, battery friendly and battery saving)
Google gcc 4.8 toolchain used for best stability
Initramfs of latest Samsung firmware
Based on latest Samsung sources
Kernel runs with SELinux enforcing by default, just as Samsung stock kernel for S5 - but can be configured to work in permissive mode in Boeffla-Config settings
Knox and Samsung rom security warnings removed
Note: I do NOT upstream the kernel to higher Linux kernel versions anymore as this usually has zero benefit but likely introduces new issues + is a waste of effort in the end
