Well it does kick off cores by default when bcl gets triggered, which happens more often at low battery levels, if the cores got stuck offline that would cause you to have only 2 online at full charge with 2.7GHz. But again I also said it's likely the cores going offline as per what the thermal-engine-shamu.conf file calls for at low battery, and just getting stuck in an offline state. I've seen the cores stuck offline happen on stock kernel after hitting low battery and charging, and I seen it on other kernels that respect the throttling from that conf file. But I don't have that happen every time like what you said. It's random if they get stuck offline.
Si probao da obrišeš keš iz aplikacije?
Verovatnoca da se to dogodi je 1%
Može li objašnjenje za neuke?To baš nema mnogo smisla. Ali me ne zanima.
Više me zanima kad će Google da ima muda da reši fragmentaciju.
Najbrže objašnjenje, da "zaključa" android. Da nema toliko (nepotrebnih) varijeteta među proizvođačima. Više softverski, ali i hardverski. Što se realno neće desiti imajući u vidu dosadašnje poteze (puštanje Android one projekta niz vodu, Hangouts i SMS itd).Može li objašnjenje za neuke?![]()
