Assassin's Creed Syndicate
Postoji li nacin da forsiram MSAA iz drajvera, da izbegnem MSAA+FXAA u igri?
Juce izasao 1.21 patch, pa probajte.
A i AMD je popravio bug sa ventilatorima na Crimson drajverima.
Zanimljivost:
Ovaj outfit, sto je bio na shotovima koji su procurili za AC Victory, je inace nepostojeci u Syndicate. :D
primetio sam da mi cpu ide preko 90% a i preko 95. Ima li jos neko na forumu sa slicnim cpu da mu ide preko 90%?
gledao sam neke klipve na yt neki procesori bas ne idu na preko 90% ali sam i video da su dosta klokovani.
Kupim account za PS4, skinem dok sam na poslu, uveče u 20h upalim, u 22h sam našao kupca kome ću da prodam acc. 2/10
Igra je fenomenalna najblaze receno i radi perfektno! Sta konkretno donosi ovaj novi patch 1.21?
1.21 Patch:
GameSpot je napisao(la):
Syndicate December 1 Patch Notes:
PC
Fixed infinite loading screen in Sequence 7
Fixed several geometry explosion and missing geometry issues
Fixed various render issues
Fixed several online issues
Minor UI improvements
Online
Fixed an issue where there was no rating for the final mission
Audio
Fixed an issue where the lip-sync was not synchronized with the cinematics
Fixed an issue where the subtitles weren't exactly matching the audio
Fixed some issues with some audio missing or being played incorrectly
Vehicles
Fixed some collisions issues for carriages and trains
Fixed some spawning issues with the vehicles
AI/NPC
Fixed some popping issues
Improved reactions for the allies
Improved reactions for NPC on the ground
Improved reactions for NPC on carts and trains
Improved navigation for NPC
Game System
Fixed some issues with the replay system
Fixed some balancing issues
Fixed an issue where the gun might be missing in the inventory after acquiring it in the "Whitechapel Conquest" mission
Fixed an unlocking issue with the Train Raids
Fixed an issue with the "Artisan" Trophy/Achievement
World/3D/Menu/HUD
The Time Anomaly icon was increased to have a better visibility on the map
Fixed some issues with the messages for the mission in the HUD
Fixed some icon issues
Fixed some lighting issues
Fixed some low resolution and corrupted texture issues
Fixed some level of detail issues
Fixed issues with props in the world
Fight
Fixed some issues during fights with NPCs
Fixed issues with counter attacks
Fixed some camera issues
Mission
Fixed an issue in the Fight Club
Fixed an issue where the player could not enter the Time Anomaly mission
Fixed some issues with the mission objectives and secondary constraints not updating properly
Fixed issues with the fast travel
Fixed some issues where the missions could be blocked after some cinematics
Fixed some issues with Crawford Starrick in the last mission, "A Night To Remember"
Behavior
Fixed some issues with the coerce system
Fixed some issues with the cover system
Fixed some issues with the parkour and navigation
Fixed some animation issues
Fixed some issues with the rope launcher
Fixed an issue where the player could sometimes fall under the map
Stability/Performance
Improved performance and stability
99% zauzece na malo klokovanoj 270, jedva 30 fps u nekim delovima... sve na low...
Koji procesor?
Koji drajveri?
Koja verzija igre?
:d
fx8320, crmison drajveri 15.11. Nema leba, mora jaca graficka. Ne znam koja je verzija.
Probaj da iskljucis neke opcije u .ini fajlu. Nalazi se valjda u My documents ili tamo gde ti je instalirana igra.
Mada, tako igra moze izgledati skroz bezveze. :D
@bajica, nemoguce buraz, obrisi drajvere sa ddu, i skini ove nove beta 15.11.1, digni ac na 1.21 verziju i stavi na medium postavke, meni radi sve super desi se da padne nekad ispod 22 ali uglavnom ide 35-42fps, nekad i 70 sve zavisi gde sta ima, klokovana 270ca, kao na slici, i cpu clocovan na 3.4ghz ali vidim da ti imas bolji pa ne bi trebalo da je to problem.. jedino onaj unpark cpu, probaj ako vec nisi to je meni dosta pomoglo i sa ac unity
Napisao sam u nekim delovima, tipa kad se popenjem na neku kulu, ili nedje po ulicama, nema snage mukica... Al nije svuda tako bedno. Gura i preko 30 :D
Moze neko da mi okaci readme fajlove za sve jezike? Nece da mi se instalira update zbog njih. Unapred hvala :)
Evo. :)
  • Readme.rar
    53.2 KB · Pregleda: 22
Pozz ja sam skinuo ovu igru ali imam samo eng i rus jezik. A ja ocu nemacki treba mi fajlovi da ubacim da ima nemacki i nikako da nadjem ako neko ima ili moze da mi pomogne bilo bi super pozz!
Nadji neko drugo, multilang, pakovanje igre.
Ako ne znas da nadjes takav torrent, javi mi se na pm. ;)
Evie je bas ostarila. :D
Poceo sam da igram ovo pre tri dana,na odmoru sam pa polako idem.
Moze da se igra,definitivno mi je bolji od proslog dela...
Grafika mi je super,koliko vidim optimizacija je dosta bolja nego na proslom delu,tecnije radi na istoj konfiguraciji.
jel ima neko drop fps sa ovim DLC jack the ripper meni na istim podesavanjima 10-15 fps manje u zavisnosti gde se nalazim
A ja se bas razmisljam vredi li cemu i da skidam ovih 15Gb.
E sad kad ti kukas sa 290...
oni su instalirani pre sam imao od 55 do 50 fps sada mi pada na 40-45 nesto je sigurno do optimizacije
Pojma nemam, moguce, ionako je patchovano:
Patch 1.31:
• Added DLC Jack The Ripper support
• Added additional parameter to AC.ini for disabling cloth motion 30FPS limits
• Fixed crash in multi-monitor mode in London
• Fixed FXAA with enabled MSAA
• Fixed changing of display in fullscreen mode issues
• Fixed flickering panel inWorld Map
• Fixed various render issues
• Fixed several online issues
• Minor UI improvements
In the AC.ini file located in “MyDocuments/Assassins Creed Syndicate”, modify the FlexibleMotionSimulationFPS parameter found in the "[OPTIONS]" section as follows:
• To enable the cloth setting: FlexibleMotionSimulationFPS=1
• To disable the cloth setting: FlexibleMotionSimulationFPS=0
By default this functionality is disabled. You may need to add the parameter manually.
Skidam da vidim...sta je za mene par fps.:D
