Bojan.zex
-tt ???
sad procitao readme , inace mi nije navika
-tt ???
START MINING ON SMALLER POOLS! variance is a non-issue with >1 block per day and it helps securing the network : https://bitcointalk.org/index.php?topic=583449.msg8934745#msg8934745
We need a high hashrate to make it harder for BCX and others to 51% attack the coin. START SOLOMING NOW! Guide : https://bitcointalk.org/index.php?topic=792661.msg8929378#msg8929378
Also we recommend to not engage in transactions even hours before the attack because of the danger of a 51% attack : https://bitcointalk.org/index.php?topic=583449.msg8935496#msg8935496
A ja se baš pitam zbog čega je cena skočila na 340kjos malo i krece taj najavljivani napad
Za koliko ? Da znam da kupujem![]()
kako je prosao napad![]()
juce i danas nema isplata na dwarfu? jel sam propustio nesto?![]()
Jel prodajete Monero ili cuvate?
Ja do sada nisam prodavao iskopano ispod 0.004... a sad se premisljam...
Isto tako, bilo mi za da prodam na 0.0042 pa onda onaj pad... sad drzi oko 0.0034-36 ... ni sam ne znam sta raditi.
jel se nekom desavalo da posle transakcije iz simple walleta nestanu novcici ...adresa na mintpalu je ok imam tekstualni fajl koji kopiram samo menjam iznos...poslao sam
2014-Sep-25 17:38:34.908231 balance: 5.580882050000, unlocked balance: 5.580882050000
2014-Sep-25 17:39:18.558365 Read command: transfer 0 46aaTzGffy6MmCsY7rQ5CdSAbpPHPj5xkf7yDdfDZSs9YWWEvFhSSkjdr2veqC44q8dt3q1egrLdnZ3oecB1JSMF856eDwb 5.53 7807287facefa85e69d412cb4b2270ea6e4c35220b6644005cae10c31a7555b5
014-Sep-25 17:39:18.603395 transaction <7a687b548a016e1864bc2dec2941b14afba03ad67bb28712baa06d29ebacd35d> generated ok and sent to daemon, key_images: [<52cfa9113b4f87c2a1eadba866aa33cf116dd8cdd120ee90b72ebcb032b50924> <915e93cf3e94294ead387121531c9628cf4ceef1aabf48734c2884c29ed639f5> <9b86cc2c8b7beba6de5b5a5b25260b56e6d58c49d68f7b606760a187ebb00e81> <07399b4a1c087853ee9e19ed76c00a1b81331a158528539b7e46be8758e6ce6a> <86ada7435316fee94eecc98854bf026235851e352d64aa05897094d541c3e2d7> <4a2589972f40e4fe494e023df4fcfbbb1460837215d89ad8aa71a3847ebb4134> <6bdd71c0fae3f4359ed8ddd8b3e579acaa66bffe73958229933d63671befa560> <7bf8a0501b8821064fb45a07b3607604c61e708b61c88f0b4aac43ac3bf8d59a> <e8ac9bdb7ee4fe2e446a8a2f58725e1a39739c81489bbe25c7e5401555773be0> <dc0edc37477aad87d283f5cfc2a1df2120ab7f7fbe4fe4ef6bf56ca69e70725f> <d813226009c10f24a780fdaec7e7365ebf7c1f254af0b1027e8d0cfa4078df88> <36328a4d705f3542827ccebf4dc2a7e64e21bbefc09ca0a71c28a683fa9cd21d> <421bf5c4cede907ad4a634a2309794181f63bdabf26f4c5642b095a89f362b7c> <62db318215e8aabe1f03039895bbf249858e1f7f3cabc96f7e8675f8c7e46968> <a19f3852c37e5393cd4710a7815fce892034155a1fa3ca2ea7b9b0fdd8b2c106> <0e0301a4370dd99f6844231ddd97ae7d8cf9ec68cbe63a06b4540c22cce5121d> ]
2014-Sep-25 17:39:18.603395 Transaction successfully sent. <<7a687b548a016e1864bc2dec2941b14afba03ad67bb28712baa06d29ebacd35d>>
nema iih nigde novcici ni u novcaniku ni na menjacnici ni na blockchainu....?
pomoc ako moze ?
ja sam ovo vec jednom prijavio da mi je za jednu transakciju skinuo sa waleta kad sam poslao 20 xmr-a ukupno 20.15....
Moj neki utisak je da ne treba sada prodavati, bar dok se ne slegne prašina oko ovog attack-a koji se nije ni desio... očigledno da nije bilo panic dump-a pa mi logika govori da će cena ići gore.
Ja čekam 0.004+ pa šta bude...
PS. Dwarfpool:
#xmr #monero New servers for monero http://t.co/G2N0txGKno and http://t.co/fnG0zrycUJ.
Erebor and moria will continue to work on.
pomoc ako moze ?
