Umetnički izbor. Odnos stranica je stvar preference. Tako The Grand Budapest Hotel ima mešane odnose.
Upravo tako, zašto dakle da se uzbudjuješ oko toga.ne vidim kako neko moze da preferira nesto losije, dokazano losije za 7. umetnost? pre ce biti da je rec o licnom isterivanju pravde a preko grbace gledalaca. ali ok, njihova je serija, mogu da rade sa njom sta im se prohte. cudi me da je nisu napravili u crno beloj tehnici zbog veceg umetnickog dojma. slepcine 🙂
And perhaps the final contrast to the rest of high-end episodic television, The Wire for each of its five seasons has been produced in good old fashioned 4 x 3 standard definition. DP Dave Insley recalled, "The reason the show has stayed 4x3 is because David Simon thinks that 4x3 feels more like real life and real television and not like a movie. The show's never been HD, even 4x3 HD and that (SD) is how it is on the DVDs. There is no 16x9 version anywhere." As a viewer with an HD set I will point out that like much of SD television that makes its way to HD channels, it appears that HBO utilizes state-of-the-art line doubling technology. It may still be standard definition, but line doubled it looks considerably better on a high definition set than it would on a standard definition set.
Insley explained, "When the show started 2001 / 2002 they framed it for 16 x 9 as a way of future-proofing. Then a couple of seasons ago, right before Season 4 began shooting, there was a big discussion about it and after much discussion -- David, Nina, Joe Chappelle, the Producers, the DPs -- and we discussed what should be the style of the show. David made the decision that we would stay with 4x3. The DPs pretty much defined the look to be what it is now. And it's been consistent for the past two seasons."
Ja završio pre neki dan 1vu. Nije me oduvala (kao npr BB, HoC,.. ) ali je pristojno držala pažnju. Sviđa mi se kako postepeno saznajemo Bostonski deo priče... Oko 8ce je realna ocena.
Drugu sezonu krećem kad se završi emitovanje.
Ja da niste pomenuli da je Wire u 4:3 ne bih se toga ni setio, eto koliko je to bitno meni.
Poceo da gledam Bron/Broen, obecava skroz.
Ja. Pristojna serija, mada je humor opao vremenom. I sada je više formula.Prati li iko Modern Family?
Upravo. Mada sve u svemu ima materijala za ispratiti.Ja. Pristojna serija, mada je humor opao vremenom. I sada je više formula.
Gledao sam na preskoke nisam nikada bio odusevljen daj nesto novije , ako moze.Ako ti ne smeta to što su starije serije, odgledaj Buffy the Vampire Slayer i Angel-a.
Još uvek najbolje serije sa tom tematikom, po mom mišljenju. Najkvalitetniji dijalozi, najbolji razvoj likova, savršen spoj ozbiljnih tema i ismevanja žanra kojem pripadaju, uz gomilu referenci na pop kulturu koje su danas možda malo zastarele, ali su i dalje aktuelne.
