Koji dialer i contacts koristite? Meni najbolje izgleda Nexus stil, ali to nema na GP
Ja sam se iznenadio kako Mighty reaguje na kompu. Cim cujem da me neko zove na telefon u istom trenutku se pojavi na kompu da imam Incoming Call. Ne znam da li i sekund jedan zakasni. Odusevio sam se.
Eeeee, hvala, bio sam u guzvi pa ne stizem da procitam ovo sto si mi ostavio. ma MIUI je kriv, odmah sam skontao, nego sam se zainatio bio da sredim ovo, ali jednostavno nema sanse, ugasim aplikaciju u podesavanjima, stigne mi poruka, ona se opet aktivira. Definitivno svima preporucujem root, nije los MIUI, lepo to izgleda, dosta sminke, ali ima i dosta nelogicnosti, kao ova, a upravo sitnice umeju da nerviraju. Jesi li ti root-ovao tvoj jiayu?veljkoka ima problem je sa MIUI Rom-om...
https://www.google.rs/search?q=miui...0l4.1807j0j7&sourceid=chrome&es_sm=0&ie=UTF-8
Nije moguce zbog MIUI ROM-a. Ne postoji nacin da se ugasi fabricka aplikacija za poruke.Ako ništa drugo kada se disejbluje stock aplikacija to ne može da se dešava.
@veljkoka kako to da i to rešenje nije moguće kod tebe?
Very simply, AppMgr Pro III doesn't offer the option to move apps to the external SD card on jellybean on Bionic, and it looks like all the complaints in the Google Play (for many phones), are all being met with this response...
FAQ - "I cannot find the "Move to xxx" button from application detailed information window."
Moving app to SD is handled by Android. App 2 SD app only provides an UI for you to manage it. Currently, Android only supports the primary external storage for App 2 SD. If the device does not have a real primary external storage or the primary external storage is emulated from the internal phone storage. Moving app to SD function will not be supported by Android system. It's the limitation of hardware. Please get more information from device manufacture.
This is configured by manufacture. Nothing developers can do about this.
So it looks like they are slowly becoming a non-functional app, and are content to let the product die.
Are there any alternatives available that work on a Bionic with JB?
As explained in the faq it's not the developers fault. They only provide an app that makes it easier than going I to your applications and moving them one by one. To enable moving apps to sd on 4.0 and higher, you need to be root. As Google had decided to obsolete sdcards (for extremely good reasons) with a minimum 32gbs internal storage. Although the manufacturers are not playing along. If you don't have enough room on your device blame your manufacturer, not the developer.
Javio sam mu, pa ce mi reci je l' uspelo.
E sad, review-ovi na Play Store-u kazu da na Xperiama ne radi kako valja... Pa ako se neko seti neka kaze za jos neku.
Citam nesto da pojedini proizvođači onemogucuju tu opciju u ROM-ovima - wtf..??
SHOW BOX.. jel moram da downloudujem film/seriju ili mogu da gledam online?
kad nadjem zeljenu epizodu, imam opciju download i watch.. ako kliknem na watch, dobijem poruku da nije moguce gledati
Jesam ali je nav bar crn...
Koji je najzgodniji nacin za cuvanje bookmarksa?
Dobro bi bilo da se cuvaju kao html fajl i da je nezavisno od browsera.
