Valjda, minus. :D
Sada mi stoji ovako (crna + 5v):
A kada stavim na crvenu i zutu nece da mrdne tj ne radi :/
Zameni krajeve.
Crvenu iz fana na žutu, crnu iz fana na crvenu. (Za 7V)
to sam uradio i napajanje mi se ugasilo. Doduse to sam "prepakivao" dok je napajanje bilo upaljno. Probacu da ga ugasim pa tako da stavim pa onda da upalim
Edit: u tome je fora, moram napajanje ugasiti ne smem dok je upaljeno
Edit2: opet se gasi. Hvala na pomoci sutra cu nemam snage vise
Edit3: ne zalazite pijani u rudnik. Ostavite za sutra
Mozda odreaguje zastita u napajanju zato sto su ti ventilatori previse snazni potrosaci da bi se tako povezali. Povezivao sam kod sebe 2-3 ventilatora na taj nacin, ali to ukupno nije bilo ni cetvtina snage ovog jednog Delta...
LINK
Caution! There are people, who will say "You can't feed current back into your power-supply" and they are right!
If you plug something between the 12V and 5V lead, you have to be absolutely sure, that no current is fed back into the PSU. Which means, that you need to have other loads on that 5V lead, which suck out more current than you feed to that lead from the 12V lead.
For example: Your fan uses 100mA at 7V. You take 100mA from the 12V lead and feed them into the 5V lead. If you have a different fan (or whatsoever), that sucks out 200mA from the 5V lead and feeds them to ground, you're fine. 100mA are sucked out of the 5V lead, 100mA come from the 12V lead and 200mA go to ground.
Since usual fans only use 1...3W, you are usually perfectly safe with using the 7V trick there. There a lots of devices in typical computers, which draw much more power out. Peltiers or things with power consumptions running up to dozens of watts, require careful calculation of what goes out of the 5V lead and what's going in there from the 12V lead.
Pitanje za H81 BTC plocu - da li cu moci jednu grafiku da ubodem direktno u PCI x 16 slot a da mogu da izvucem iz susednog PCI x1 preko extendera? Grafike su Saphire R9 270 Dual-X.
Hladnjak od grafike koju ubodes direktno u PCI 16x16 slot ce ti prekriti 1x16 slot ispod i neces moci da ga koristis,tako da u toj varijanti mozes ici samo na 5 kartica.
Gde si mislio da drzis sve te kartice? Ja imam slican rig sa 5 x asus R9 270, u cuveni "Dimketov" rig mozes max 5 dvoslotnih kartica da stavis, ako razmisljas da stavis 6 komada treba ti produzen rig. Takodje proveri i duzinu kablova na napajanju.
Ako ces da kopas scrypt, gledaj karte da razdvojis sto vise jer ces imati problema na leto, u koliko ces kopati X11 koji manje muci hardver mozes slobodno 5 kartica da stavis u regularan rig.
Jasno, znaci treba mi i jedan PCi x16 na PCI x16 extender sa molexom.
Narucujem produzeni rig od nekog lika iz oglasa, nemam vremena da se bavim konstrukcijom.
Sto se tice duzine kablova napajanja to nisam proverio :( mogu samo da se nadam da ce biti dovoljna jer je napajanje vec naruceno (RaidMax RX-1200AE).
Ako kablovi ne budu dovoljno dugacki da dohvate 1 ili 2 poslednje karte imas one produzne 6-pinske kablove pa ces sa njima resiti problem. I obrati paznju da molex na ploci koji je blizi grafikama spojis sa prvim molexom koji ide iz napajanja.
Takodje obavezno undervoltuj karte na recimo 1,1V, mozes i nize,zavisi sta hoces da kopas.
ljudi jel imao neko iskustva sa Powercolor TurboDuo 280x?
jel valja to? koliko kopa, jel ima neko neku info?
OK.
I za PCI x16 na PCI x16 ista prica - extender isporucuje do 25W pa mora i taj da ide sa molexom?
Nema razlike izmedju 1x16 i 16x16 extendera sto se tice kolicine struje koju mogu da isporuce. Uzmi sve extendere 1x16 sa molexom, samo obrati paznju na duzinu extendera, trebace ti bar 2 komada od 30cm da bi mogao da razdvojis 6 karata.
Znaci sad da ga narucis, dobio bi ga u najboljem slucaju sredinom/krajem Jula. A tada ce diff biti barem ~15-20k. Sto znaci rok otplate istog 7-8 meseci minium. :)
Da li si probao sa poslednjim beta AB ?
koji napon bi ti bio zadovoljavajuci? jer ako ti treba 1.1V tip je postavio kako to treba da izgleda
ovako:
for 1100mV, the values should look like this:
01 00 24 00 00 04
00 00 00 80 10 00
00 80 00 00 6B 03
00 00 10 00 B6 03
00 80 10 00 8B 04
00 00 00 00 4C 04
04 00 24 00 00 04
00 00 01 08 00 00
00 00 00 00 52 03
01 00 00 00 B6 03
00 08 00 00 01 04
01 08 00 00 68 04
01 10 2A 00 00 05
00 00 4C 04 00 00
4C 04 48 00 1E 03
4C 04 48 00 42 03
4C 04 48 00 5F 03
4C 04 48 00 77 03
4C 04 48 00 FF 03
01 11 2A 00 00 05
00 00 8B 04 00 00
8B 04 3E 00 1E 03
84 04 3F 00 42 03
6B 04 43 00 5F 03
52 04 47 00 77 03
4C 04 48 00 FF 03
4C 00 03 01 FF FF
